Old Apr 01, 2008, 10:51 PM
Autryville, NC
Joined Dec 2006
Experts weigh in...profile Bird of Prey
Don't think this one has been done yet.
Take a look and offer some sugestions. In 'flight mode' the Bird of Prey has some dihedral, so that's what I'll model. I'm convinced the box structure helps stabilize the model (base on eliworm's F-15, my Gripen, and my unpublished profile Berkut), so that's how I'll model this one. Power will be the tried-n-true Suppo 2212 APCe 6x4 combo. 30 inch span.
My questions to the quorum are:
1. What's a good angle to set the wings?
2. Will I need some vertical stab behind the prop?
Just starting to model this PM, so post up your thoughts.
Kevin
kwinters is offline Find More Posts by kwinters
Old Apr 01, 2008, 10:59 PM
My plans are in my blog
Rusty-Gunn's Avatar
Kotzebue, Alaska
Joined May 2006
I 'd guess the plane may want to topple over with the severe anhedral and most weight high above. Might give you some moments of sudden suprise maybe?
Looks to be a nice idea though. Give it a try and have at it. Its the best way to discover how it will work.
Rusty-Gunn is offline Find More Posts by Rusty-Gunn
Old Apr 01, 2008, 11:02 PM
Foam Wannabe
Joined Nov 2005
Edgerc has their Bird of Prey kit. It is sort of along the same lines:
http://www.edgerc.com/bop.htm
Ron
rcallison is offline Find More Posts by rcallison
Old Apr 01, 2008, 11:58 PM
Autryville, NC
Joined Dec 2006
No anhedral. The first picture has the BOP in flight mode - that's what I'm modeling.
KW
Old Apr 02, 2008, 01:03 AM
"It's a Quad" :O
thewz's Avatar
Temecula
Joined Jul 2004
Looks good but be careful with too much vertical surface area forward of the CG.
thewz is offline Find More Posts by thewz
Old Apr 02, 2008, 01:07 AM
CNC Cutter
birdofplay's Avatar
United States, IN, Indianapolis
Joined Dec 2005
Go take a look at the Harpy thread by Chara
birdofplay is offline Find More Posts by birdofplay
Old Apr 02, 2008, 01:17 AM
Autryville, NC
Joined Dec 2006
What adverse effect will this have to flight characteristics?
Will check out harpy thread.
KW
Preliminary layout video here.
Old Apr 02, 2008, 06:27 AM
Or am I...
Bournemouth, Dorset, UK
Joined Jan 2005
Look for my F-28 parkjet vids somewhere here in the vid forums or parkjets.com . I had too much in front initially and the vid shows what happens.
in a nutshell, the plane wants to weathervane backwards and becomes unstable in yaw.
im-sad is offline Find More Posts by im-sad
Old Apr 02, 2008, 08:00 AM
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
Check out the annehdral/dihedral on the BluBat: http://www.rcgroups.com/forums/showthread.php?t=401764
The optical illusion works well, and flight personality is tame.
Gene Bond is offline Find More Posts by Gene Bond
Old Apr 02, 2008, 04:39 PM
SG Talon... Super Genius.
Lenox, Michigan
Joined Nov 2005
I think that looks awesome Winter!
I was actually looking at my Star Trek Models the other day and thought it would make an awesome plane. Put a rudder on the thing to counter any extra yaw problems and i bet it will be great.
I think that perhaps this will be the summer of Space Vehicles for my Prototype shop. I feel a rash of Star Trek and Star Wars models in my blood.
Course it could be the Pon Farr.
SGTalon is offline Find More Posts by SGTalon
Old Apr 02, 2008, 11:20 PM
Autryville, NC
Joined Dec 2006
Thanks. Keep checking back. I'll start cutting foam this weekend.
KW
Old Apr 03, 2008, 02:31 AM
You sabotaged my plane.
eliworm's Avatar
Arizona
Joined Jun 2002
KW, very cool. Can't wait to see this one.
Jim
eliworm is online now Find More Posts by eliworm
Old Apr 03, 2008, 03:58 AM
Sopwith Camel's Cousin
Between my tx and crashed aircraft
Joined Mar 2006
If it turns out that you need more vertical stabilizer later on,
you could try to make the added stabilizer out of clear plastic
(with perhaps some thin CF rod as a stiffener if needed)
to minimize its visibility (cloaked ).
flying-llama is offline Find More Posts by flying-llama
Old Apr 03, 2008, 08:55 AM
Autryville, NC
Joined Dec 2006
Design work is 90% done. 15 degress of dihedral. Everything is slotted/tabbed to fit together except wing-to-nacelle. Should finish up tonight. I'll withhold posting plans unless someone is going to build alongside me.
Was thinking about pitching moments this AM. On my other flat foamies I placed the centerline of the motor ALONG the trailing edge of the wing. For this design, I placed the motor ABOVE the wing.
Q: Will this cause excessive pitching as throttle position is changed? Is vertical positioning of the motor significant or trivial for flat foamies? See attached picture and offer your thoughts.
KW
Old Apr 03, 2008, 08:58 AM
Autryville, NC
Joined Dec 2006
Jim -- thanks. I still fly your F-15 every day. I have a buddy who is modeling panel lines of the F-15. I'll print them onto vinyl graphics and attach them to my second plane (remember, I bought two from you). Also, I started playing with video, so I'll post some video on your thread when I can...
Llama -- good call. Hoping I won't need additional vertical stab, but I like the method you proposed. Flight testing will tell...
KW
Bird of Prey Kit? senor_paco Electric Plane Talk 13 Nov 19, 2011 11:39 PM
Culver Cadet in profile rc capo Parkflyers 0 Sep 05, 2002 12:48 PM
F/S: Carbon-winged Bird of Prey - NIB raturne Aircraft - Sailplanes (FS/W) 1 Aug 24, 2002 02:15 PM
One's location in profile Gary Retterbush Electric Plane Talk 5 Aug 16, 2002 08:59 PM
How's this for a great e-RC plane: a 7' RC Falcon -- as in the BIRD! J Cubed Electric Plane Talk 2 May 08, 2002 04:26 PM
