| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||
#61 |
HELP!
I'm completely new to this part of the hobby. Will this ant. be beneficial to me? http://www.rcgroups.com/forums/showp...&postcount=279 Also, does putting this sort of ant. on a tripod greatly increase range/clarity? |
#62 | |
Well you can check out these guys http://www.aircables.net/antenna-rubber-duck.html for those omni directional antennas. If you plan on flying close then those are just fine. But if you plan on going far then get a flat square "patch antenna" like a 8db or a 14 db. The higher the db on the patch, the farther you will fly successfully but also the narrower the reception beam gets. (that means you have to point those things at the plane as much as possible.) Omni on the other hand; you do not have to point them at the plane, just don't fly too far. If you want to use Omni and go a "little" far then look into a 9db antenna. (higher db) I flew with a 14 db patch and got around 2.5 to 3 km with no video loss! (Could of easily gone further but my wing folded!) I flew with a 10db omni directional and suffered video signal break at approx .5km but at least I didn't have to point the antenna at the plane. So both have their ups and downs but it all depends on your flying habit. You can absorb more info on Crash9 website. http://www.fpvvideo.com/ He's done a great job compiling a lot of valuable FPV info for newbies. ![]() PS I assume you checked out the first page of this thread? It list all the places to shop for anything to do with this hobby.
#63 |
Happy FPV flyer
High gain omnis are usually unsuitable for our application, you won't want more than 5dBi, I'd suggest sticking to the 3dBi.
The problem is that retaining the 360° horizontal coverage means reducing the vertical one. With a 9dBi you'll end having about 10° beamwidth above horizontal, no need to say you'll always be flying way above that so it's just useless. |
#64 |
There you go skunkworks2006.... thanks for correcting on the omni Kilrah!
So does a 3db omni get 1000 meters on the RX?
#65 |
Thanks for the help guys.
Yeah, I did check out the first page, but I was just looking at these locally and wanted to get better range. I went ahead and picked one up. Here's what I discovered: range was about doubled. I set the omni at about a 30 deg angle and it seemed to work pretty good in the park with a few fuzzies and cut-outs. On the patch ant... what kind of angle of reception do they have? I fly mostly park flyer foamies and really don't need more than .5 miles of range to have fun. I realize however that I always want more range than the airspace I plan to fly in. |
#66 |
One more quick question: What could I do to the cam Tx to increase range on this camera? http://www.radioshack.com/product/i...rentPage=search
Is it possible or beneficial to increase or change the tx antenna? |
#67 |
anyone?
cricket.....cricket...? |
#68 | |
FYI, the RadioShack link goes to their home page. Runout74 |
#69 |
Whoops. Sorry.
Here is the link to the manufacturer http://www.swann.com.au/s/products/view/?product=483 The camera has just a tiny ant. and the tx is all built in. I've been getting fair reception in "park range" but I'd like to extend the range and thus the reception at the fringes. Any help would be appreciated. Thanks. |
#70 |
Cleanroom Ninja
skunkworks2006,
I doubt you are going to gain anything by changing the TX antenna. We don't want those to be directional since the plane's orientation is going to be changing. It's a tradeoff as others have said, higher gain=narrower signal. The only thing I would do is to focus on the ground antenna. A patch antenna is your best bet. The Goof Proof Patch Antenna is the cheapest way to go, and has great performance, but you need to be able to put it together. Take this advice as you want, but I wouldn't spend a whole lot of time or money trying to get a whole lot out of that system. I went that route last year and wasted both time and money, and eventually wound up with a 900MHz system from Rangevideo that works GREAT! It doesn't matter if you go with 2.4GHz or 900MHz, the cameras and TX/RX Rangevideo, Blackwidow, Futurehobbies, and others sell will give you orders of magnitude better quality with orders of magnitude less fuss. I wish I had gone that route in the first place myself...but I'm glad I did now. I know you spent the money on the Radio Shack system, but IMHO that's what E-bay is for. ![]() All that said, I have a 200mW 2.4GHz E-Bay system that I never used beyond hooking it up and testing it out on the ground and a 2.4GHz 14dBi patch antenna from Rangevideo that I've never used that I'm considering selling if you (or anyone else) is interested. It seemed to work fine, except that it picked up some interference from the DX6 I had at that time and I didn't want to take a chance of interfering with the DX6 while the plane was in the air so I went with a better 900Mhz system. Tim |
#71 |
Thanks Tim,
I was just so darn anxious to get started. ![]() It actually works pretty well in the park with my 7db omni mounted horizontally, but I'm just not confident at any longer distance with the set-up. I'll look into the patch ant. The Goof Proof looks like a nice project. PM me with the details about your 2.4GHz system. I'm certainly interested if I can squeeze it out of my budget. |
#72 |
what the...
Has anyone checked out Boostervision.com? It seems like a good site, and cheaper than most too, but no one has even mentioned it in this forum! Should I take this lack of mention as an ominous sign, or can I consider it as a viable fpv system such as the proven one from RV, futurehobbies, etc? Any opinions?
#73 |
Smoke on , go !
thanks for the link, just added to the first post list.
#74 |
Good Day all!
Im very keen to by a fpv set up for model aircraft and have found Fat shark very helpfull. Does anybody have any comments on their set up that they are selling. Is it good? I would like to set up a head tracker system for this. I am using a JR 2610 at the moment, any ideas on ways to set this up? Thanks guys |
#75 |
I have been in contact with fatshark on goggles and camera set up. Are there any other places on the net that provide this sort of thing i could contact?
Any set up somebody could recomend? Thanks |
| Thread Tools | |
| What camcorder for video ? | Goleith | Aerial Photography | 7 | May 08, 2009 04:52 AM |
| Discussion What to Buy for Indoor Season? | stuka | Micro Helis | 0 | Sep 25, 2006 10:48 AM |
| Question What to buy for T-rex micro, HB2 | Lino | Mini Helis | 9 | Jan 06, 2005 08:20 PM |
| What to buy for my HackerB20-31s | Zagi miester | 3D Flying | 1 | Apr 28, 2004 04:23 PM |
| What to buy for 2nd heli...? | Arne KK | rec.models.rc.helicopter | 3 | Apr 28, 2003 04:01 AM |
