Go Back   RC Groups > Aircraft - General > Video Piloting (FPV/RPV)
This thread is privately moderated by zaguruinzasky, who may elect to delete unwanted replies.
Old Jan 07, 2007, 01:18 PM   #16
Smoke on , go !
zaguruinzasky's Avatar
Send a message via MSN to zaguruinzasky
what is the normal range of a Futaba 9c or just of the radios in general ?
whats the videoTX/RX needed to safely cover the Futaba range?
how do I know when I'm going to fly over the max range to correct my flight direction in time?
Thanx guys
zaguruinzasky is offline Find More Posts by zaguruinzasky   Reply With Quote
Old Jan 07, 2007, 01:50 PM   #17
Thanx guys
I have flown to the limit of visibility with my Futaba and had no problems. One of the things that we used to do years ago was, if you lost the signal hold the transmitter as high as you can and hold it so that the antenna is sideways to the airplane. If it is a range problem rather than some kind of failure you will almost always regain control. Then you fly back toward yourself.
No experience with this personally, but Jettpilot and others say that if you lose video do a climb. That will usually get you a stronger signal. I lot of people have mentioned that the video signal is weaker near the ground than when you are high. This is supposed to be true even when you have a good line of sight to the airplane.
I have been pretty far away on only 50 mw video tx. I am currently flying 200 mw in my Easy Star (when I can get to fly it) I got an excellent signal at the limit of what my spotters would allow. My club has a strong policy of flying within certain bounds. We own our field and keep well within the boundaries to avoid complaints. The flying area is more than anyone normally needs for visual flying, but seems small when you have to keep turning with an Easy Star being pushed along by three times the power that it was designed for!
A lot of people seem to think that 500 mw is good, but that means more battery weight in the plane. I'd rather fly with the 200 and use my diversity rx and dual patch to make up the difference. When I need more range (unlikely) I can always upgrade to a more powerful video tx.
When I fly in Vermont there are few places I would care to fly far away since most of the area I fly in is heavily forested. I really don't want to come down far away in some unidentifiable seventy foot tree!
If you are in a place where you can fly far away without worrying about either losing your airplane or crashing into someone's house, car or whatever, then you might need more video tx power.
For myself. I will say that with my antenna well placed I have never gotten far enough away to have a problem even with only 50 mw. I have used an 8 dBi patch since my first good video camera and now I have an even better video rx with 11 dBi dual patch.
I would love to fly at this site again, but it is all overgrown now. It was a ski slope that closed down. This frame is from a video made about twelve years ago. You can see what I mean about trees! Where ever there are no trees you have houses. As you can see, there are not many houses, so you land on the ski slope or you shop for a new plane. With GPS in the plane you can write down the coordinates, but otherwise the risk is very high if something goes wrong.
Pete
  • Name: Uhu in Vermont.jpg
Description: This was the old Hobby Lobby Uhu. From here I could fly with the plane below me or above me. We had several fantastic flights here. Some of the bug bites took months to heal. This was the old Hobby Lobby Uhu. From here I could fly with the plane below me or above me. We had several fantastic flights here. Some of the bug bites took months to heal. 15.0 KB · Views: 967
PeteSchug is offline Find More Posts by PeteSchug   Reply With Quote
Old Jan 07, 2007, 02:36 PM   #18
Smoke on , go !
so it would be very usefull to have on video overlay two kind of bars indicating RX signal power and video signal power, just to know when it's time to roll back to base...
I hope some manufacturer will do this toy soon.
At the moment I draw a circle around my takeoff zone in google earth with a specific dimension (the radio range) just to learn where I can fly. Do you think 1 KM is realistic or too much for Futaba?
Does the video signal disappears progressively or now you see and one second later you don't see anything?
Thanx!!!
Old Jan 07, 2007, 02:53 PM   #19
Pull out early!
DiveBombDave's Avatar
The radio and video will be solid out past 2km (the ones I mentioned, Futaba and 500mw). Keep in mind that if you're out that far and get confused on the video, you lost your plane. Practice flying by video just in circuits around the field until you have all the bugs worked out and are more comfortable with the process.
DiveBombDave is offline Find More Posts by DiveBombDave   Reply With Quote
Old Jan 07, 2007, 03:08 PM   #20
Smoke on , go !
rgr that!
Old Jan 08, 2007, 01:59 AM   #21
JMSTECH's Avatar
Originally Posted by AnthonyRC
The TrackR1s should be in stock shortly, and this time there should be plenty to go around (I greatly underestimated their popularity!)
www.aeropix.ch/store
Ha ha ha... I knew it would be hit!
JMSTECH is offline Find More Posts by JMSTECH   Reply With Quote
Old Jan 08, 2007, 04:36 AM   #22
AndrésMtnez's Avatar
Good news, I´ll order two of them soon
AndrésMtnez is offline Find More Posts by AndrésMtnez   Reply With Quote
Old Jan 08, 2007, 10:22 PM   #23
Smoke on , go !
guys, I added a lot of links in my first post... have a look if ya want..
Old Jan 11, 2007, 11:28 AM   #24
Heres some more:
www.endurance-rc.com/realvision.html - Pan and tilt controller software
www.emagin.com - 800x600 OLED headset with butild in 3 axis head tracking
www.avtoolbox.com - video to VGA converters
Endurance is offline Find More Posts by Endurance   Reply With Quote
Old Jan 12, 2007, 09:24 PM   #25
typicalaimster's Avatar
Send a message via AIM to typicalaimster Send a message via MSN to typicalaimster Send a message via Yahoo to typicalaimster
Supercircuits.com has a few micro video cameras available. Twin did you ever have a chance to test one?
https://www.supercircuits.com/index....S&Category=445
typicalaimster is offline Find More Posts by typicalaimster   Reply With Quote
Old Jan 13, 2007, 12:02 PM   #26
There goes my hobby money
twinturbostang's Avatar
I use the KPC-S226 (aka KX-131). Haven't tried anything else except a cheapo camera/tx from WalMart. That was a piece of junk.
twinturbostang is offline Find More Posts by twinturbostang   Reply With Quote
Old Jan 19, 2007, 04:43 PM   #27
Thanks for the realy good links ! Well done.
Nimbus09 is offline Find More Posts by Nimbus09   Reply With Quote
Old Jan 19, 2007, 11:18 PM   #28
Just trying to get a nut.
scrtsqrl's Avatar
For video gear and some good deals on LiPo's, check out
www.microwireless.net
I've always had a good experience with them.
scrtsqrl is offline Find More Posts by scrtsqrl   Reply With Quote
Old Jan 21, 2007, 04:28 AM   #29
JMSTECH's Avatar
I like to contribute to the list as well.
Switches, voltage regulators etc..
http://www.dimensionengineering.com/
Antennas:
http://www.hyperlinktech.com/web/re09p.php
http://www.aircables.net/antenna-rubber-duck.html
Robotic parts, electronics etc:
http://www.robotmarketplace.com/store.html
Cheap servos, servo 180' extender:
http://www.servocity.com/
GPS controlled boat project, "The how to":
http://users.libero.it/riccardo.rocca/roboat.htm
On board electric generator for nitro planes:
http://www.sullivanproducts.com/GenesysMainFrame.htm
Audio/Video amplifier and distribution:
http://store.qkits.com/moreinfo.cfm/FK655
FOV calculator:
http://www.nto.org/whatusee_en.html
Free downloadable videos on "how to" - RC stuff.
http://www.downonthedeck.com/videos_instruction.htm
Awesome story of a GPS controlled plane crossing the Atlantic ocean:
http://www.modelaircraft.org/mag/mhill/hillindex.htm
Special Projects by the great Mr.RC-CAM!
http://www.rc-cam.com/projects.htm
Antenna Projects by YB2normal:
http://www.yb2normal.com/flightindex.html
Old Jan 22, 2007, 12:19 PM   #30
4mla1fn's Avatar
please add www.hittconsulting.com. he's got OSD stuff and i understand will have some new products of interest to us pretty soon.
also autopilot stuff at:
http://www.maxxprod.com/mpi/mpi-16.html
http://www.uavs.net/rcap.html
4mla1fn is offline Find More Posts by 4mla1fn   Reply With Quote
What camcorder for video ? Goleith Aerial Photography 7 May 08, 2009 04:52 AM
Discussion What to Buy for Indoor Season? stuka Micro Helis 0 Sep 25, 2006 10:48 AM
Question What to buy for T-rex micro, HB2 Lino Mini Helis 9 Jan 06, 2005 08:20 PM
What to buy for my HackerB20-31s Zagi miester 3D Flying 1 Apr 28, 2004 04:23 PM
What to buy for 2nd heli...? Arne KK rec.models.rc.helicopter 3 Apr 28, 2003 04:01 AM
Bored? Want to fight?
Join the RCGroups clan!
