Jack, the depron is closer to 2mm than 1mm. Yes it marks up easily, and I
will do a few things to stop tears, there will be some tape on the leading edge of the wing to stop the tears that start near the wing roots and like wise some tape inside the fuse running a bit before and after the wing saddle for the same reason. But the adage applies - build to fly not to crash. OF, I don't know much about producing plans. From the drawings I do make there is always a lot of ad-hoc fudge and fiddle. On that first one I chose to use green and gray on the top side, mostly because I did not have any brown paint I liked at the time. Last time I was in Micheal's I spotted some small bottles of green and brown craft paint that should work well on this one. |
Joined Oct 2007
Thats ok, my plans ,I use my trusty pencil, ruler, compass, assorted odd things and then a few plan B fixes in the moment of the builds. You know the satisfaction, when it flys and you built it with your own two hands and with minimal swearing. Did you just go from a 3-view or did you use the TLAR method?
I've been working from 3 view's. I have one that is mostly from the first
plane, and another that is based on the second. The first plane had thicker landing gear spats and a less pointy spinner. As you can see from this series of photos I am using a series of 3 cylindrical pieces for the main part of the fuselage. I am not using formers on the inside, I force the curves by rolling the part over the edge of my desk, and then use a series of outside formers to help it hold shape while the glue is drying. I also use the outside former to help trim the end of the tubes as needed. I have mounted the motor in the front section and then attached it. I attached the front section with a bit of down because the three views look like that was how they built in the down thrust in the real one. I'll be opening up the wing saddle and using that hole to put the servos, radio and battery box in. I am also forming the buck for the canopy, I'll vacuum form it and the radiator housing. I don't know how I am going to form the landing gear spats yet. |
| Thread Tools | |
| Build Log Miles M20 Build | Veri-Gash | Scale Fuel Planes | 34 | Dec 03, 2012 05:30 PM |
| Sold Rare Miles M65 Gemini NIB | imodel | Aircraft - Electric - Airplanes (FS/W) | 3 | Mar 05, 2012 03:02 PM |
| For Sale Miles reed 120 weeks solution | rickj12 | Aircraft - Fuel - Engines and Accessories (FS/W) | 0 | Feb 28, 2012 06:51 AM |
