Espritmodel.com Heli Air
Old Aug 04, 2012, 06:47 AM
Joined Mar 2012
Yes your right, will have to be eggs or OSD,,or maybe just popcorn
Was in reply to a post above
Nihal is offline Find More Posts by Nihal
Old Aug 06, 2012, 06:39 AM
BadBert's Avatar
Nederland, Noord-Brabant, Hoogerheide
Joined Mar 2007
mine operates just fine on 3s
BadBert is offline Find More Posts by BadBert
Old Aug 08, 2012, 04:51 AM
Joined Mar 2012
Thats good news, have you done any modifications to the OSD or is it stock ?
Because they do get hot with 3s even with wire heatsink or may be a undercharged 3s
Old Aug 09, 2012, 03:22 AM
Munich, Germany
Joined Nov 2003
Hmm,
don't understand, why it's getting so hot. Does it use so much power to heat up the regulator? What voltage does it REALLY need? I need 12V for the VTX, but I think about getting a SBEC to lower the voltage before feeding to the OSD. Maybe convert the voltage down to 7.2V? How good is the voltage regulator on the OSD, can it be fed from a switching voltage regulator? I'm thinking about the 7.2V SBEC from Hobbyking. Or is it better to just run it hot, isn't this a waste of energy and stress on the OSD?
UBEC 7.2V / 4.5A
or the smaller one:
UBEC 7.2V / 2.5A
- Oliver
Smeagle is offline Find More Posts by Smeagle
Old Aug 09, 2012, 07:39 PM
Detroit 2-stroke junkie
1320fastback's Avatar
USA, CA, Oceanside
Joined Jul 2008
Im having RX glitching issues:
Pretty new to FPV and OSD use but not to RC.
I have EZ* with a JR 610UL RX (72Mhz channel 55) out on the right wing, antenna is routed gently to the rear of wing and hangs. No sharp turns at all.
The ESC is directly in front of the motor centered on the fuselage up top.
The VTX (1.3Ghz @ 400mw) is on the left wing and its V antenna is further out.
The OSD (Genuine Remzibi) is on the out side of the fuselage under the canopy area.
My camera is where the stock canopy would go.
I am running a dual battery set up and power the OSD from the VTX battery thru the balance connector and only drawing 8.4Volts.
Before I got the OSD I had ventured out 1 mile (5280') with this set up repeatedly.
After installing the OSD I could only make it out to 4,400' before experiencing violent glitching of the elevator and rudder.
I have since added many torrent rings and twisted all the wires.
I moved the OSD closer to the RX thinking it was related to the VTX and the glitching now happens at 2000'
There is almost 24" clearance between OSD and RX.
Any help?
BTW, thanks for the candy Remzibi !
1320fastback is offline Find More Posts by 1320fastback
Old Aug 10, 2012, 02:24 AM
BadBert's Avatar
Joined Mar 2007
I have done no modifications whatsoever....
it is stock, and even locked up in the fuselage of my esky nemo....
it does not get verry hot! Not even with fully charged lipo's
Friend of mine also has the remzibi, stock, on 3s, and his does not get that hot either...
Old Aug 10, 2012, 07:38 AM
2^p - 1
signflyer's Avatar
United States, MO, Springfield
Joined Feb 2003
1320 - same flying site? Have you tried taking the OSD out of the equation again?
signflyer is offline Find More Posts by signflyer
Old Aug 10, 2012, 09:10 AM
Joined Mar 2012
Well thats very good news. May be because mine is new and has to sort of settle down,,,,,get baked a bit Something to think about and check
Thanks for the info
Regards
Old Aug 12, 2012, 04:13 PM
USA, CA, Oceanside
Joined Jul 2008
Flew at a different site today and had same issue out at 4,400'.
I removed osd and easily flew past where I had issues minuets earlier.
Both flights were at 500' and clear LOS to plane.
I am using 1.3 video and 72Mhz for RC control.
Old Aug 13, 2012, 12:10 AM
GLADUS63's Avatar
France, Limousin, Limoges
Joined Jul 2009
May be you create a ground loop when you insert the OSD, check that there are no ground between devices (OSD, camera, VTx...) if they share the same battery.
GLADUS63 is online now Find More Posts by GLADUS63
Old Aug 14, 2012, 01:14 AM
Australia, VIC, Melbourne
Joined Aug 2012
Great OSD! But is it really for a poor man? $100+
FirstPersonView is offline Find More Posts by FirstPersonView
Reply With Quote  (Disabled)
Old Aug 14, 2012, 01:54 AM
Munich, Germany
Joined Nov 2003
Right, there are some cheaper options. But I like this one better...
- Oliver
Old Aug 14, 2012, 02:34 AM
Joined Aug 2012
Cool OSD, I need a OSD and would consider to purchase this.
Old Aug 14, 2012, 03:24 AM
Joined Mar 2012
Well considering what componants you get with it at that price and what it can do, you wont go wrong with this one
Mail or PM Remzibi, thats what you should do.
I am very happy with my two Remzibi's,,,
Old Aug 14, 2012, 10:59 PM
USA, CA, Oceanside
Joined Jul 2008
Well tonight I had the time to make a Map of my wiring and like you said I found a ground loop in the Video/OSD system.
Fix was simply cutting one wire.
Going to try it out tomorrow (but close in) so will have to wait till weekend to see if its the issue.
Thanks!
Poor Man's Heat Shrink for Homemade Battery Packs... flytowner Parkflyers 28 Mar 12, 2010 11:45 PM
Poor man's Helistar Iain Micro Helis 25 Dec 01, 2005 06:15 AM
What to do? W/lb of poor man's F5B (long post) 96S14 High Performance 14 Sep 29, 2003 03:02 PM
Poor man's Super Slow Stick fun flyer? uglyplane Parkflyers 1 Jul 03, 2003 11:54 AM
Kyosho 180 Poor Man's Power Fix??? Don Sims Electric Plane Talk 41 May 12, 2001 09:23 PM
