Old May 18, 2015, 11:52 AM
santanig5 is offline
Find More Posts by santanig5
santanig5's Avatar
United States, NJ, Roxbury Township
Joined Nov 2014
Help!
AT3511 750Kv Outrunner Brushless Motor
Hello,
I crashed my TOP RC FW-190 the other day and bend the motor shaft, when I attempted to straighten it I broke it at the threads! Can the shaft be replaced or is there something that can be attached to what remains or do I need to buy a new one?
Thanks in advance,
GJS
santanig5 is offline Find More Posts by santanig5
Old May 20, 2015, 08:05 AM
Ron van Sommeren is offline
Find More Posts by Ron van Sommeren
homo ludens modellisticus
Ron van Sommeren's Avatar
Netherlands, GE, Nijmegen
Joined Feb 2001
See shaft.
Vriendelijke groeten Ron
Ron van Sommeren is offline Find More Posts by Ron van Sommeren
Old May 20, 2015, 11:56 AM
jackerbes is offline
Find More Posts by jackerbes
Jack
USA, ME, Ellsworth
Joined May 2008
Originally Posted by santanig5 View Post
Hello,
Thanks in advance,
GJS
Easy, peasy!
Outrunner Disassembly and Stripping - Gimbal Motor Rewind - www.rcgroups.com/forums/showthread.php?t=1823636
Making and Replacing a Brushless Motor Shaft - www.rcgroups.com/forums/showthread.php?t=1240725
Here is a good source for shafts that can be easily modified or cut to length if needed:
http://www.headsuphobby.com/Motor-Shafts_c138.htm
They even tell you how to install them:
http://www.headsuprc-info.com/motor-...tructions.html
Jack
jackerbes is offline Find More Posts by jackerbes
Old May 21, 2015, 05:08 AM
santanig5's Avatar
Joined Nov 2014
thanks, unfortunately my motor looks like this and does not disassemble in the same way.
Old May 21, 2015, 12:27 PM
Jack
USA, ME, Ellsworth
Joined May 2008
It looks like it was made by the same people that made the DAT-750...
See if this helps you:
hexTronik DT750 Motor Rewind for Multicopter - www.rcgroups.com/forums/showthread.php?t=1892195
Do you want me to take it apart for you?
Jack
Old May 22, 2015, 01:38 PM
santanig5's Avatar
Joined Nov 2014
Jack
Thanks Jack, it looks like the shaft is part of the housing. I ordered a new one!
If you were closer I just might have you do it!
GJS
Old May 22, 2015, 06:41 PM
Jack
USA, ME, Ellsworth
Joined May 2008
GJS
Maine is pretty close to New Jersey.
There should be a set screw on the side of that raised area that the shaft emerges from, with that screw removed (1.5mm hex wrench needed) the shaft is a pressed fit into the dome. Work carefully as I described at the links to press the old shaft out without damaging the dome or magnets.
I put a shorter shaft in those motors and use prop savers on them or set screw or collet type prop adapters. Those threaded shafts are just not worth a darn for mounting props.
Jack
Sold 4 x hexTronik DT750 Brushless Outrunner 750kv free_diver Aircraft - Electric - Power Systems (FS/W) 2 Mar 05, 2015 09:58 AM
Question Bearing Size for BC3536-11 750KV Outrunner Brushless Motor TheQuestor Multirotor Electronics 3 Jun 10, 2014 02:00 AM
4 x Brand new RCTIMER BC3536-11 750KV Outrunner Brushless Motors anixs Non R/C Items (FS/W) 15 Sep 21, 2012 08:39 PM
Discussion Is the A3536-11 750KV Brushless Outrunner good motor Michael64 Multirotor Talk 2 Aug 29, 2011 06:16 AM
Sold DT750 Brushless Outrunner Motors 750kv airflap Aircraft - Electric - Power Systems (FS/W) 0 Dec 26, 2010 08:03 PM
