Another nice option would be the step style drills often used for sheet metal work. It's like a tapered reamer but it has steps on it at some incrementally different cutting diameter. In using it for reaming a prop I'd go in from both sides to meet with the side wanted in the middle. If the hub is very thick it may have a step in it from the next larger size but you'd have a good 1/8 wide portion where the size is the one you want. Used in other ways the size needed could be cut at only one side or the other and the other left tight or opened up as needed.
The big advantage with them over the use of a tapered reamer is that if you cut a little too deep the hole is still the right size over some portion. Just that the portion with the right size is a little shorter than it would be other wise. WIth a tapered reamer if you go a little deep then the hole is opened up too far as well. Here's a page from Aircraft Spruce showing what they look like. You'd have to do something about a handle. Also you may need to search for a metric one for electics. http://www.aircraftspruce.ca/catalog...tstepdrill.php |
If you go too far for the tape trick to work ( should only need 2 or 3 wraps of electrical tape) then you need a lot more control . Also by that time too much have have been removed from the hub to be used safely.Start with more wraps than you need, and remove/cut accordingly. |
Certainly a tapered reamer is what I've used before too. And like you guys I never really had any problem with it. Sneak up on the fit and it's not hard to achieve a light press fit which works very well.
The Uni-Bit option just popped into my head for some reason when I put the posts about the stepped reamers and the taper reamers together. Seemed like a nice way to go if a guy could find the one that worked with the engines or motors that are used the most. |
Drilling plastic on a drill press is always a risky operation. It's just way too easy for the drill to snatch and spin the prop. So any time I drill a prop out using my drill press there is ALWAYS a block of something clamped in place to hold against one of the blades for WHEN it grabs and tries to rip itself out of my grip.
The Uni-Bit chip slot is steeper angled so it MAY prove to be less grabby. But I would not bet my fingers on it. Use something to stop the prop from moving in case you can't hold it. |
| Thread Tools | |
| Discussion Anyone have good UK source for lite ply? | maddog7 | The Builders Workshop | 4 | Aug 30, 2011 07:03 PM |
| Discussion Good UK source for breakout boards? | Katch | Multirotor Talk | 0 | Aug 08, 2011 06:20 AM |
| Question source for 1/2 round plastic shapes for a mold | ScorpionRacing | Composites Fabrication | 16 | Jul 06, 2011 09:53 AM |
| Question Good online source for sheet styrene? | Led Zepplin | Scale Electric Planes | 13 | May 20, 2011 01:34 AM |
| Discussion Good Source for Epoxy found | hoppy | Foamies (Scratchbuilt) | 0 | May 06, 2011 05:06 PM |
