Old Dec 13, 2007, 09:38 PM
lthibault is offline
Find More Posts by lthibault
Luc
lthibault's Avatar
Joined Dec 2004
Kyosho Flip 3-D 40 Conversion
Information about the electric conversion of this beautiful airplane
lthibault is offline Find More Posts by lthibault
Old Dec 13, 2007, 09:54 PM
Luc
lthibault's Avatar
Joined Dec 2004
Flip 3D Conversion
Hi,
I was planning to convert this beautiful airplane for a year. Finally got the budget and time to do it.
Eflite Power 46 on board. I didn't want to order supplies from the hobby shop to mount the motor ($$$) so I found this solution: Lamp hardware! not very expensive and you can buy it at Canadian Tire or any hardware store...
ESC is a Phoenix 60.
Had to put some weight in the front to achieve CG.
Still need to complete with a MPI switch.
Made a few runs the other day and the plane flies very well. With a 4S 4200 Pack it has plenty of power for pattern flying with an APC 12X8 but I will try a 13X8 for 3D and acrobatic figures.
Old Dec 23, 2007, 12:01 PM
Luc
lthibault's Avatar
Joined Dec 2004
Reporting back from the field. I've put the MPI switch and a 13X8 propellor. Also using a 4S 4100 Lipo from HobbyCity.
Fantastic performance! I can easily fly for 10 minutes with lots of acrobatics and the battery is barely hot.
With Epower this plane is great. I'm planning to have a lot of fun with this aircraft.
Old Dec 25, 2007, 12:28 AM
wollins is offline
Find More Posts by wollins
"RC ADDICT" in Toronto!
wollins's Avatar
Toronto Canada
Joined Aug 2004
Could you give some more details on the "lamp hardware"? What is it?
wollins is offline Find More Posts by wollins
Old Dec 25, 2007, 05:16 AM
Luc
lthibault's Avatar
Joined Dec 2004
I'm referring to a threaded metal tube that is often found on ceiling lamps; the tube will usually go through a plate and a tiny bolt will be screwed on it.
They are sold with a variety of lenghts, i.e. 1 inch, 1.5 inch, 2 inches. They are easy to cut with a Dremel disk to fit your specific need.
Once the tubes were cut I added washers at each end to avoid plywood chipping. This way you can really put a lot of torque.
All this motor mounting was done with my regular hardware at a minimal cost.
Old Dec 25, 2007, 06:31 PM
Luc
lthibault's Avatar
Joined Dec 2004
Made a few runs yesterday and today, this plane is so crisp and precise, does exactly what you want, goes where you point it. Extremely large rudder and ailerons make manoeuvers a charm. With this setup I have enough power to get tired before the battery drains out.
Just found that I needed to bend the landing gear in order to increase clearance for the prop. The rain has washed out most of the snow on the lake and the ice is rough and uneven so I scraped a couple of propellors lately...
Old Dec 25, 2007, 08:50 PM
MICKEL is offline
Find More Posts by MICKEL
C.H.E.A.P.
MICKEL's Avatar
Chino Hills, CA
Joined Jan 2005
What is your AUW? I have a power46 and like to hear yours is performing great! This way I'll know what 4s can do with what weight.
MICKEL is offline Find More Posts by MICKEL
Old Dec 25, 2007, 10:14 PM
Luc
lthibault's Avatar
Joined Dec 2004
Unfortunately I can't weigh it. Sorry.
Old Dec 26, 2007, 03:27 PM
stevelmaa is online now
Find More Posts by stevelmaa
Renton, Wa.
Joined Feb 2006
I have a Power 46 sitting idle also and have also like d the looks of the Flip 3D, hmmm, curious also on what your weights might be. If you're ever curious and are lacking a scale, any of your local mail stores, eg. ups stores are usually more than happy to let you throw it on their mail scales.
stevelmaa is online now Find More Posts by stevelmaa
Old Dec 26, 2007, 10:18 PM
MICKEL is offline
C.H.E.A.P.
MICKEL's Avatar
Chino Hills, CA
Joined Jan 2005
Even the grocery store has digitals these days. The produce dept. ? I guess were feinding!!!!
Old Jun 11, 2013, 04:17 PM
DeadstickDuck is offline
Find More Posts by DeadstickDuck
Electric
United States, OR, Hillsboro
Joined Oct 2009
Time warp.
80oz with E-flite .32 on 4s4000mA 35C
DeadstickDuck is offline Find More Posts by DeadstickDuck
Old Jul 21, 2015, 01:21 AM
Electric
Joined Oct 2009
Another time warp!
Resurrecting and taking my Flip 3D 40 out of retirement. Going to update with new gear.
Plettenberg Orbit 25-16 592kv
Edge50 esc
4s3650mA Hyperion G6 HV lipos
4x Hitec 82mg
New covering scheme
flip 3-d & ys 63 bodymann Aircraft - Fuel - Airplanes (FS/W) 2 Apr 30, 2005 01:17 AM
Kyosho Flip 3D 25 and 40 information request test3 Sport Planes 5 May 03, 2004 09:54 PM
3-D Giles-202 conversion Steven D Sport Planes 18 Apr 16, 2004 07:29 AM
Magic 3-D Conversion Mark Gund Sport Planes 29 Oct 17, 2002 07:59 PM
Laser 3-D conversion Steven D Sport Planes 4 Jul 30, 2001 09:19 PM
