Old Jun 18, 2015, 07:04 AM
rank is online now
Find More Posts by rank
Gibraltar
Joined Jul 2013
New Product
Hobbyking's Quanum 3 Axis No Drift Head Tracker, Discussion & Mods
Here you go boys and girls, Hobbyking has introduced the budget 3 axis headtracker with no drift, for just $22.84 (for the discount, just wait for the special price pop up).
****** Quanum 3 Axis No Drift Head Tracker ******
Features:
• Full 3 Axis
• Easy GUI setup
• compatible with most radios with a trainer port
• remote zero button
• Drift free
Specs:
weight: 9g
Voltage: 2~4s (provided via the trainer port cable on Futaba)
Axis: 3 pitch, roll, pan
Included:
Quanum 3 Axis head tracker
Remote zero switch
Futaba/9XR/9XRpro trainer port cable
JR/FrSky trainer port cable
Based on the Diy HT project from rcgroups: http://www.rcgroups.com/forums/showthread.php?t=1677559
The price is very reasonable, considering the part's cost, included case, and (hopefully) the fact that the HT is pretuned out of the box
rank is online now Find More Posts by rank
Old Jun 18, 2015, 09:42 PM
gear-head is online now
Find More Posts by gear-head
United States, WA, Vancouver
Joined Jun 2002
Nice! I think I will be picking one up!
gear-head is online now Find More Posts by gear-head
Old Jun 18, 2015, 09:47 PM
ryane67 is online now
Find More Posts by ryane67
I'll fly (and crash) anything!
ryane67's Avatar
United States, MI, Orion Charter Township
Joined Mar 2013
darn it! I wish they would have released this three days ago, before my international order with my quanam v2.
ryane67 is online now Find More Posts by ryane67
Old Jun 19, 2015, 04:30 AM
mish1990 is offline
Find More Posts by mish1990
mish1990's Avatar
United States, NM, Albuquerque
Joined Jun 2013
Thinking of using this to fly my AXN floater. How sick would that be??? :-D
mish1990 is offline Find More Posts by mish1990
Old Jun 19, 2015, 05:01 AM
mad_milchmann is offline
Find More Posts by mad_milchmann
mad_milchmann's Avatar
Germany, BY, M
Joined Jan 2014
I had a similiar idea. Already ordered it for my Bix1 that I'm building as FPV Plattform right now
mad_milchmann is offline Find More Posts by mad_milchmann
Old Jul 20, 2015, 12:37 AM
hele559 is offline
Find More Posts by hele559
New Zealand, Canterbury, Christchurch
Joined May 2013
Whats the initial setup for this? I have one and want to get it the pan/tilt (no roll) working on the 2 aux channels on my dx6i, I have the pan and tilt plugged into my aux 1&2 on my 6 channel receiver and the head tracker set to Channel 5 and 6 in the setup software, and ideas?
hele559 is offline Find More Posts by hele559
Old Aug 18, 2015, 05:21 AM
Hajile is online now
Find More Posts by Hajile
Philippines, Calabarzon, San Pedro
Joined Jul 2012
I just got mine and tried plugging into the 9XR futaba port. But i'm not getting anything. I tried plugging it into the JR port and it responded. However, i the need to plug into an external 5v ubec. The futaba port was able to power the headtracker by itself.
A quick probe with the multimeter found that the white wire connects to the JR's data pin. But there's no continuity coming out of the board the futaba socket is mounted on. Does the 9XR need a modification? Either the signal wire coming out of the head tracker is connected to the wrong pin, or the trace on the 9XR is connected to the wrong socket
The headtracker is connected to pin4, but the white wire in the 9XR is connected to pin 1
To other users of the 9XR, do i fix the cable? Or the socket?
Hajile is online now Find More Posts by Hajile
Old Aug 18, 2015, 08:22 AM
Joined Jul 2012
After modding the 9XR, i finally got it to work.
Quanum Head Tracker Test (1 min 14 sec)
Apparently, fatsharks had the same issue with the radio.
PS: If you guys decide to get this, i would strongly recommend that you use the remote switch. The button on the main unit has a very pronounced 'click' and the vibration from that is enough to affect the sensors and wildly throw off your center.
Old Aug 25, 2015, 01:42 AM
NobodyFamous is offline
Find More Posts by NobodyFamous
Joined Aug 2015
Originally Posted by Hajile View Post
....PS: If you guys decide to get this, i would strongly recommend that you use the remote switch. The button on the main unit has a very pronounced 'click' and the vibration from that is enough to affect the sensors and wildly throw off your center.
Thanks for the tip. That explains a lot.
NobodyFamous is offline Find More Posts by NobodyFamous
Old Aug 25, 2015, 06:48 AM
Joined Jul 2012
It would help greatly if they were to make an update that takes the sensor value a fraction of a second *before* you pressed the button.
Old Aug 26, 2015, 08:54 AM
BWX_ is offline
Find More Posts by BWX_
Summer rules.
BWX_'s Avatar
United States, NY, Big Flats
Joined Nov 2013
That's amazing that it went back to center or close to it after whipping it around by the wire. Seems like a good deal..
BWX_ is offline Find More Posts by BWX_
For Sale Fat Shark MIG External Head Tracker (2 axis) macdaddy1199 FPV Equipment (FS/W) 0 May 27, 2015 01:52 PM
Sold DT-3K Zero Drift head tracker! Price drop bovick FPV Equipment (FS/W) 0 Oct 15, 2014 01:55 AM
Discussion Annyone tryed the SKY EYE 3-axis Geomagnetic Head Tracker Pro LKJ FPV Talk 7 Dec 26, 2012 09:26 AM
Discussion Skylark 3-Axis Geomagnetic sensor Head Tracker skylarkfpv FPV Talk 5 Dec 26, 2012 09:11 AM
