Old Jul 11, 2015, 05:10 PM
mikeflyz is offline
Find More Posts by mikeflyz
mikeflyz's Avatar
Westlake Village, California
Joined Mar 2003
I was following a suggestion from one of my friends to skin only the upper surface. It is only to decrease thrust requirements. Yes, the open lower wing structure will have a drag penalty, but at low indoor speeds, the induced drag savings of a single surface wing is a little greater than the parasite drag penalty caused by the exposed lower wing structure.
Once I double-surfaced a peanut-scale moth and it was nearly unflyable.
My next project was the Waco, with only an upper surface (same power loading as the moth) and it was much better. So, the concept has stuck.
mikeflyz is offline Find More Posts by mikeflyz
Old Jul 11, 2015, 05:12 PM
LowlyElevated is offline
Find More Posts by LowlyElevated
Team PeasantCopter... kind of.
LowlyElevated's Avatar
United States, FL, DeLand
Joined Sep 2012
It probably turns the wing type into more of an undercambered airfoil as opposed to symmetrical or flat-bottom. An undercambered wing generates more lift, but has the penalty of drag. Which, really isnt too much of a penalty on indoor flyers because you want it to stay as slow as possible.
LowlyElevated is offline Find More Posts by LowlyElevated
Old Jul 11, 2015, 07:13 PM
BryanEW710 is offline
Find More Posts by BryanEW710
BryanEW710's Avatar
United States, OH, Cincinnati
Joined Sep 2010
Interesting! There so so much about micro aerodynamics that I don't know
BryanEW710 is offline Find More Posts by BryanEW710
Old Jul 14, 2015, 12:50 AM
davereap is offline
Find More Posts by davereap
davereap's Avatar
Ashford. Kent. England
Joined Feb 2005
the main gains are your weight saving.... and improved lift from the open under cambered wing
davereap is offline Find More Posts by davereap
Pictures: When planes were able to show off, at air shows Patrick Plawner Life, The Universe, and Politics 172 Dec 10, 2014 04:31 PM
Cool Show off your Parkzone Micro P-51!!! P-51C Scratchbuilt Indoor and Micro Models 938 Nov 20, 2012 06:49 PM
Discussion Show us those planes you really need to replace! JimTMich Parkflyers 8 Apr 26, 2012 11:05 AM
Discussion Show off those home made camera gimbals! ben1101 Aerial Photography 2 Jul 22, 2009 07:11 PM
