Old Aug 14, 2014, 07:11 AM
United States, CT, Stamford
Joined Mar 2011
Originally Posted by pipejax View Post
If it was mine and I could not or I can't or don't want to buy a replacement fuselage. And I did not want to experiment with taking apart the fuselage halves to get at the nuts on the retainer plate. Use the kiss method and glue the wing down directly to the wing saddle. I have done this and it works great.
I wrote to the guys at Dream-flight and they are sending me a replacement part. So, I will wait.
I am also thinking about buying another Libelle, in September, because I am sure to break this one more as I learn how to throw it.
pherz is offline Find More Posts by pherz
Old Aug 14, 2014, 07:54 AM
United States, UT, Sandy
Joined May 2013
I should add that in my overhand tosses my Libelle flew nice and tame. She seemed trimmed. But if I wasn't a more skilled and quick on the controls pilot it might have taken some hard landings. Be careful with even your first light DLG launches.
elkski is online now Find More Posts by elkski
Old Aug 16, 2014, 07:57 AM
Joined Mar 2011
Follow-up...
I just want to let you all know that I rec'd my new part today. George, from Dream-Flight, sent it to me, at no charge. I can now start my repair
Kudos to George and the other people at Dream-Flight!
Thank you George!
Old Aug 16, 2014, 11:01 PM
United States, MN, Rochester
Joined Dec 2006
So I like many had ordered 4 of the Hitec servos and had 1 that jittered. I'll send that one in for replacement but since they are on backorder I picked up 2 of the digital servos from DreamFlight.
Does anyone have a preference on what servos I might want to put where. The DreamFlight ones are digital so would they be better for the ailerons? Although I think the specs have them with less torque. I think I would have to tweak the cutout slightly in the wings. So I'm thinking of just using the Hitecs for the ailerons.
Then use the DreamFlights for the elevator and rudder. I haven't verified yet if I might need to tweak the cutouts slightly.
I also figure it's easier to swap out the aileron servos if I need to. I figure the Hitec might be more likely to need switching so another reason for the ailerons.
Any other thoughts?
kf0s is offline Find More Posts by kf0s
Old Aug 17, 2014, 03:08 AM
Cloudrider
Manchester UK
Joined Feb 2008
Hitecs
Probably not what you want to hear, but I'd swap out the other Hitecs too if that's an option financially.
Paul UK
Cloudriderurt is online now Find More Posts by Cloudriderurt
Old Aug 17, 2014, 06:09 AM
FabFlight's Avatar
Canada, QC, Saint-Rémi
Joined Sep 2013
I'd place a digital servo where accuracy and resolution counts most, that is at the elevator. But frankly, this is a foamy and these considerations are rather futile.
FabFlight is online now Find More Posts by FabFlight
Old Aug 18, 2014, 03:32 PM
Lokihaus's Avatar
Grafton, MA
Joined Mar 2005
So, I work here as an animator and already built myself a RedBaron.
When I stumbled upon DLGs and decided upon the Libelle I already knew what I was going to name it... Woodstock. I have a few dozen throws and just this weekend strengthened the wing saddle. Here's what she looks like:
Description:
Description:
The yellow is just krylon spray paint and the Woodstocks are stickers I printed out myself on sticker paper.... and yes, I cut out the black line work by hand.
Lokihaus is offline Find More Posts by Lokihaus
Old Aug 18, 2014, 05:52 PM
FabFlight's Avatar
Joined Sep 2013
Neat!
Old Aug 18, 2014, 08:41 PM
They Call him Dead!
YellowJacketsRC's Avatar
United States, SC, Pawleys Island
Joined Jul 2003
Anyone use the Power HD 44dsm servos? Will they work all around or jus the ailerons?
YellowJacketsRC is offline Find More Posts by YellowJacketsRC
Old Aug 18, 2014, 08:46 PM
They Call him Dead!
Joined Jul 2003
Also,
What's the word on the servos that Dream-Flight sells?
Old Aug 18, 2014, 10:00 PM
WAA-08 THANK FRANK!
JimNM's Avatar
Las Cruces, New Mexico, United States
Joined Jun 2002
Yellowjacket - I went with those servos all round. You will need to trim a little foam to fit them, but it is not a big deal. Those are a little bit rough - but the Libelle is not a precision machine by any measure.
JimNM is offline Find More Posts by JimNM
Old Aug 20, 2014, 09:01 AM
I'm Addicted Already
Charlotte, NC
Joined Feb 2011
I also use the '44s all around.
NCRealEstateGuy is online now Find More Posts by NCRealEstateGuy
Old Today, 01:11 PM
TMO
TMO's Avatar
Stonington, Ct.
Joined Nov 2001
Hi guys,
Sorry to jump in here, but I just found the thread. I'm a Dream-Flight dealer and I've flown/made a bunch. Just offering 2 cents about my favored setup. The following items lead to a stock aircraft at about 9.4 oz AUW. That's what my current one is and it's painted, plus fiberglass on wing saddle and pod.
SPMAR6335 AS3X RX. I initially resisted the gyro, but I've concluded that I am a better DLG pilot with it. Launch higher, cruise more efficiently, and use less aileron: all contribute to longer flights. Smartfone programming on this model RX allows easy field adjustments to suit conditions, or turning it all off, which I do in slope flying.
4 x EFLR7100. This is an analog servo built in exactly the same case as the Hitec HS35, which I feel is unreliable, expensive, and unduly spec'd. I haven't managed to strip one of the EFLR7100s yet, nor have a failure (knock wood). It is a drop in fit on both wing and pod. Very light- 3.5g. Arms are same, and even match up to the same holes.
Stock 300mAh Nimh battery. I've used everything up to 2S 550Mah through a UBEC. By the time you add the UBEC, and the associated weight penalty, I feel you are better off going old school, and adding the 20g to get it to balance. The servos prefer the lower voltage. Only had a duration issue once on slope- but I was up for over 2 hours elapsed, so...I was asking for it. To each their own here, but I have tried everything, and it's what I'm using.
I have a completion package up on my site with these items, plus whatever else you need to go from box to launch. Here (link)
Dream Flight does not allow its dealers to sell the Libelle online, which is why I don't have a Libelle category up, but since I see that they are out of stock for awhile, y'all could pm me if you were looking for one.
Happy trails,
Tim
TMO is online now Find More Posts by TMO
Cool Dream-Flight Libelle DLG MattyB Slope 1429 Aug 06, 2014 11:37 AM
Discussion http://www.dream-flight.com/files_download/Libelle.pdf hellmansam Hand Launch 35 Mar 30, 2014 09:03 PM
For Sale Dream Flight Alula jredingt Aircraft - Sailplanes (FS/W) 8 Mar 25, 2014 10:54 AM
Discussion Dream Flight DLG? Jwmflying14 Hand Launch 7 Feb 03, 2014 12:55 PM
Sold Dream-Flight Weasel Evo EPP ddruck Aircraft - Sailplanes (FS/W) 4 Nov 25, 2013 12:26 PM
