Old Jun 14, 2013, 07:41 AM
Joined Mar 2013
Need a radio channel controlled MOMENTARY SWITCH
I have to find a radio channel controlled momentary switch that simply bridges a contact (No load applied). It is to take the place of a physical SPST momentary switch in a lighting control system.
I tried to use the Turnigy type switches, but they won't work when just trying to complete a circuit.
Jarold C is offline Find More Posts by Jarold C
Old Jun 14, 2013, 08:14 AM
Stuart
UK, Cardiff
Joined Dec 2008
Use the Turnigy switch to drive a relay ?
srnet is offline Find More Posts by srnet
Old Jun 14, 2013, 11:29 AM
bitchin86's Avatar
United States, UT, West Jordan
Joined Jan 2013
you could always use a micro servo to push the switch
bitchin86 is offline Find More Posts by bitchin86
Old Jun 14, 2013, 02:51 PM
Joined Mar 2013
Yeah, that's what i have now- high incidence of failure when making mechanical contact. The points fail because of vibration.
I'm trying to avoid a relay, but thanks for both suggestions.
Old Jun 14, 2013, 03:07 PM
United States, VA, Suffolk
Joined Aug 2011
Could you make your system work by receiving a 5v signal, or do the contacts actually have to be bridged? If you just need a 5v signal you could use an ATTiny micro-controller. I have one setup to translate a servo signal into an on/off signal for a lighting system, but you could easily program one to act like a momentary switch. If you want something pre-built look at this:
http://store.3drobotics.com/products...switch-v10-kit
It is the same idea, it would just need programming.
m056678 is offline Find More Posts by m056678
Old Jun 14, 2013, 03:31 PM
Joined Mar 2013
That might do it. I'll have to read more tonight after work! Thanks
Old Jun 14, 2013, 03:33 PM
Joined Mar 2013
You know, i wonder if there is a remote shutter switch out there that might do it?
Aren't some of them just an electronic momentary switch that bridges a contact?
Anyone know of one?
Old Jun 14, 2013, 05:08 PM
Joined May 2013
You mean like an analog switch.... Something like the ADG333 ( or MAX333 ) does just that, although it's a quad SPDT in a 20-pin DIP package. If to wires need to be shorted, however, and there is no need for it to remain floating. You can simply tie one down to GND, and switch the other to ground with an N-channel MOSFET -- small package, reliable and low power. Otherwise, something like the analog switches above might be necessary to retain some small isolation.
Martin Jay McKee
mckeemj is offline Find More Posts by mckeemj
Old Jun 14, 2013, 05:41 PM
Stuart
UK, Cardiff
Joined Dec 2008
I'm trying to avoid a relay.
Useful information to have included in your original post then.
Why are the points in a lighting system (whatever that means ?) being subject to vibration ?
Old Jun 14, 2013, 05:56 PM
Joined Mar 2013
The points in the mechanical micro-type switch go bad quickly from any type of vibration. They don't last in a plane, car, heli, or motorcycle. They are happy only in a stationary project (model trains). Even then they go bad after a couple hundred cycles.
Old Jun 14, 2013, 05:59 PM
Joined Mar 2013
Martin Jay McKee
That's what I'm looking for! Should work! Thanks!
Old Jun 14, 2013, 06:15 PM
Joined Mar 2013
Somebody in an electronics forum said i could just use a J-fet, but that was the limit of his answer. Makes sense, but my electronics education is sadly lacking and dates back to tubes. I did find an spst analog switch that i think will work- thanks all!
Old Jun 14, 2013, 06:23 PM
Joined Aug 2011
Martin Jay McKee
If I understand the datasheet for the MAX333, you would still need something to convert the PPM signal coming from the receiver to a logic high or low signal to feed in to the MAX333 (like an Atmel micro-controller).
Old Jun 14, 2013, 06:25 PM
Joined Mar 2013
Yep, a modified turnigy remote switch
Old Jun 15, 2013, 01:28 AM
Stuart
UK, Cardiff
Joined Dec 2008
Quite likely, or standard junction transistor.
Whereas an analogue switch might not work.
For Sale AR Drone 2.4 Radio control kit, NO IPOD Needed Now with remote switch for LED's ssgtmacgyver Aircraft - Electric - Multirotor (FS/W) 1 Aug 22, 2012 11:23 PM
Discussion need on off switch controlled by free receiver channel branflakes Night Flying 12 Feb 15, 2012 05:37 PM
Help! Looking for a dual momentary radio controlled switch crd Robotics 0 Feb 10, 2012 08:40 PM
Help! Help! - DX6- How To -Momentary Switch / DLG preset Switch flynfrog Hand Launch 0 Mar 22, 2007 11:28 PM
Help! DX6- How To -Momentary Switch / DLG preset Switch flynfrog Radios 0 Mar 22, 2007 11:08 PM
