Old Feb 25, 2013, 12:39 PM
Minnesota
Joined Jun 2007
I want a motor-less plane.
Ive been kicking around the idea lately of how to use a model rocket engine to lift a small plane into the air. I figure Ive got a few weeks left of frozen lakes to safely test one of these out, so I want to give it a go.
I want to build a small glider. Im thinking no bigger than 3ft ws. I want small because I want to use the smallest rocket motors possible. DollarTree foam board will be the material. I also have some carbon fiber arrows from walmart. I will look to fiberglassing the fuse/wing for strength.
The first thing I want to do is build the glider as a glider. I would like to get the CG of the glider set and be able to give it a good toss and have the controls work. After that I can figure out launch methods for the model rocket engine. Im not to interested in the flight times as of yet. If I can get this thing lifted up and beable to spend a few minutes gliding back down, thats a win for me.
hot glue is offline Find More Posts by hot glue
Old Feb 25, 2013, 01:42 PM
ApachePilot
ApachePilot's Avatar
United States, MI, Barryton
Joined Oct 2006
You may want to begin here:
http://www.instructables.com/id/Rocket-powered-glider/
http://www.jonrocket.com/EDMONDS.html
http://www.hobbylinc.com/htm/est/est2186.htm
https://www.discountrocketry.com/-c-...2ded2d8635dac8
http://www.randrmodelaircraft.com/Delta%20Star.htm
ApachePilot
ApachePilot is offline Find More Posts by ApachePilot
Old Feb 25, 2013, 03:03 PM
TonyS
Central Arkansas
Joined May 2010
Estes produced a rocket powered airplane kit about 10 years ago, called the Strato Blaster. It could be powered with Estes rocket motor or a Cox .049 motor module. Mine is hanging on the wall behind my monitor.
Manual here -- http://www.spacemodeling.org/jimz/estes/est2090.pdf
Video of flight as designed here --
Estes StratoBlaster Flight in McDonough, GA (1 min 54 sec)
Video of modified plane here --
Estes Strato Blaster R/C Plane (2 min 6 sec)
TonyS
tonystro is offline Find More Posts by tonystro
Discussion Beginner plane LESS affected by Wind arancini Beginner Training Area (Aircraft-Electric) 50 Jan 21, 2013 08:20 AM
Discussion My NTM 3000kv motor seems to have a ton less power than it used to. Why? Koo Power Systems 23 Jan 11, 2013 10:12 PM
Discussion So I' m want a Banana Plane. Which is less worse? BEELZEBOB Electric Ducted Fan Jet Talk 2 Jun 05, 2010 06:16 PM
My own design Sensor less/ Brush less/ Slot less Motor and driver Takao Shimizu Power Systems 84 Jul 28, 2005 04:35 PM
CD ROM motor specs for 8oz and less planes sloper steve Power Systems 30 Apr 24, 2004 10:34 AM
