Old Sep 16, 2014, 12:29 AM
Los Angeles, CA
Joined Mar 2004
Question
EZ Star
Not sure if this is the place to ask this question
I have a Multiplex EZ Star. When I throttle up,
The plane climbs really fast even on 1/2 throttle.
What can I do to ease off the extreme climb?
lv2soar is offline Find More Posts by lv2soar
Old Sep 16, 2014, 02:09 AM
Condescending Pedant
Joined Aug 2013
The motor power determines rate of climb. The elevator determines speed. If the plane climbs too fast, put in some down trim. This will cause the plane to speed up so if it flies too fast, cut back on the throttle and take out the down trim. It's sort of a balancing act.
Mike Dubovsky is offline Find More Posts by Mike Dubovsky
Old Sep 16, 2014, 09:08 AM
United States, NY, Queens
Joined Oct 2005
1) Adjust the elevator for level flight at 50% throttle. Use the clevis for adjustment so that the trim is at neutral.
2) Rebalance the plane by moving the CG forward.
Leo L is online now Find More Posts by Leo L
Old Sep 16, 2014, 09:51 AM
Y=C+I+G
cmdl's Avatar
United States, CA, Rosemead
Joined Jan 2012
as Leo wrote - trim for half throttle. also, you can do the dive test to check CG: http://www.rc-airplane-world.com/tri...-airplane.html
cmdl is offline Find More Posts by cmdl
Old Sep 16, 2014, 10:06 AM
Los Angeles, CA
Joined Mar 2004
Thank you guys for the info
For Sale ez supra fly or star nib billderry Aircraft - Fuel - Airplanes (FS/W) 0 Jul 29, 2014 02:54 PM
For Sale EZ Star II which only a mother could love nk4787 FPV Equipment (FS/W) 3 Jul 05, 2014 09:15 PM
Sold New FPV Setup for EZ Star. 900Mhz 500mw. Dual Output Video. KX191 cam. EZ Pod. Batts. LESLIEx317537 Aircraft - General - Miscellaneous (FS/W) 9 May 13, 2009 12:05 AM
Discussion An EZ Star becomes hard star - very hard Mihai Foamies (Kits) 0 Apr 10, 2008 11:38 AM
