Old Aug 09, 2014, 08:27 PM
Joined May 2012
Zero UAV HighOne Quadcopter
Email: sales@zerouav.com
Zero UAV HighOne quadcopter is designed for professional aerial photographer and cinematographers, carries panasonic GH3/GH4 camera. Its lightweight, compact design makes it easy to take anywhere and create amazing aerials on the go. Equipped with our most safe dual redundancy autopilot, safty parachute, customized motors, advanced electronic speed controllers, 18inch carbon fiber propellers. HighOne gives you the safty, portability and profession you need to create high-level footage.
Zero UAV HighOne official video (1 min 33 sec)
HighOne
Specially designed for professional aerial photographers and cinematographers
Safe
Portable
Professional
High-end professional 3-axis brushless gimbal
Z1400 ( GH3/GH4)
It adopts the newest algorithm, which makes your shot
extremely smooth, supports multiple lenses which brings you
a top-level footage.
Portable and Professional
Special design with foldable frame arm, which minimize the
transportation volume, easy to carry in the smallest size for your
amazing traveling shootings
Most Safe flight with ZERO UAV Safty Parachute
Equipped
When flight angles reaches 70-90degree, the safty parachute
will be opened automatically controlled by GEMINI autopilot.
You can also control the parachute manually while flying in
manual mode.
High Functionality brushless motor and propeller
Specially customized for HighOne
Plentiful motivation enables a long flight time, A 60A
electronic speed controller (ESC) is built into each arm,
combined 6210 customized motors, 18inch carbon fiber
propellers.
All-purpose receiver converter
It’s compatible most PPM/PCM/2.4GHz RC Transmiter and
Receiver, provide you more free options.
Dual redundancy autopilot, the most safty
HighOne equipped with the most reliable professional
autopilot--GEMINI, exclusively guarantees safty flight
GEMINI comes with two independent controllers,and the status
of two independent sensors can be monitored on ground control
station at the same time, when any one occurs error or out of
control, the other one shall automatically start up working.
Phone Vibration to remind user when GPS interference or low
battery.
360degree panoramic shootings
Humanized one-key switching for 360 degree panoramic
shootings, easy to go for professional panoramic shots,
creates a new area of aerial photography and future of
unlimited possibility.
Powerful Ground Control Station
Support Android phone/tablet and PC as ground
control station to monitor/adjust the parameters
Comes with excellent functions such as
256waypoints, Blackbox, Voice broadcasting,
click/fly to point, Target Lock etc
Aerial Rocker-Arm Feature
Lightly move the TX stick, HighOne will
automatically fly the 3-D preset waypoints, shoot a
precise footage easily, which satisfied a high-level
requirements for professional users.
Convenient operation mode
Single mode & Dual mode
HighOne supports Unique Single mode created by Zero
UAV and traditional dual mode.
Single mode can operate your gimbal and aircraft at
the same time, specially developed for traveling flying
task, compared to traditional dual mode, it is more
convenient and easy to go.
What does HighOne Quadcopter Include?
Quad Frame x 1
Motors x 4
Propellers x 4
ESC x4
Z1400(GH3/GH4) brushless gimbal x 1
GEMINI dual-redundancy autopilot x 1
Traveling Case x1
OSD x 1
Receiver Converter x 1
All needed cables x 1
Option Purchase:
Video Transmitter (AVT) x 1
Data Link 900mhz x 1
Safty Parachute x 1
Specifications
Frame
Diagonal Wheelbase 720mm
Frame Arm Length 230mm
Frame Arm Weight 242g
Motor
Stator Size 61*10mm
KV 380rpm/v
Max Power 1200W
Weight(with Cooling Fan) 275g
ESC
Working Current 60A
Working Voltage 6S LiPo
Signal Frequency 30Hz-450Hz
Drive PWM Frequency 400Hz
Weight 80g
Propeller
Material Carbon Fiber
Size 18x8.5inch
Weight 34g
Gimbal Z1400 GH3/GH4
Camera Supported Panasonic GH3 & GH4
Lens Supported Multiple lenses such as Lumix G 14mm f/2.5, LUMIX G 20mm/F1.7,
Pasonic LEICA 25/1.4, OLYMPUS M.ZUIKO
DIGITAL ED12mm f/2.0 etc.
Flight Parameters
Takeoff weight 7.3kg-7.8kg
Power Battery LiPo 6S 10000mAh-16000mAh/Min 15C
Hovering Time 16min(@16000mAh&7.8kg Takeoff Weight)
Control Requirement
Tx Supported(FC) PCM or 2.4GHz,7 channels and above
Receiver Supported(FC) S-Bus; Common Receiver
Packing
Aluminum Case Size 430mm(L) x 390mm(W) x 590mm(H)
Zero UAV is offline Find More Posts by Zero UAV
Site Sponsor
Old Aug 09, 2014, 11:51 PM
Joined May 2012
Video shooted with panasonic GH4 camera
Zero UAV HighOne GH4+Mountain Bike Racing (1 min 27 sec)
Zero UAV HighOne GH4 +Aerials Shoot House (4 min 13 sec)
Site Sponsor
Old Sep 02, 2014, 06:21 PM
Joined Jul 2014
do you check your machines before you ship? i don't think so! my gps unit is faulty and i have been grounded and unable to fly since i reived it..
your customer service is not helpful
extremedean is offline Find More Posts by extremedean
Discussion Zero UAV HighOne Quadcopter Vivien Y Multirotor Talk 4 Aug 28, 2014 02:50 PM
New Product Zero UAV HighOne RTF Quadcopter Vivien Y Multirotor Talk 26 Aug 28, 2014 02:44 PM
Discussion Zero TECH HighOne RTF Quadcopter (the manufacturer) Linda Yin Multirotor Talk 28 Aug 19, 2014 08:34 PM
For Sale Zero UAV YS-X4 Auto Pilot System FC Flight Control GPS Multirotor Quadcopters SkyMonster Aircraft - Electric - Multirotor (FS/W) 6 Jun 16, 2014 02:35 AM
Discussion ZERO TECH “HighOne”any info? qixinghaitang123 Multirotor Talk 1 Mar 21, 2014 03:08 AM
