Old May 21, 2013, 11:10 PM
build, fly, crash...repeat
marksp's Avatar
United States, WA, Redmond
Joined Apr 2011
E-flite Power 160 - Tacon Bigfoot 160
Does anyone know if the included prop adapter that comes with the Power 160 bolts to the Tacon? My spinner requires tapped shaft and the Tacon adapter isn't tapped.
I'm hopeful to be able to order and use the eflite adapter.
Thx
marksp is online now Find More Posts by marksp
Old May 25, 2013, 01:02 AM
Relax, have a Cub
mewert's Avatar
College Place, WA.
Joined Apr 2004
Yes, it does.
mewert is offline Find More Posts by mewert
Old May 25, 2013, 10:10 PM
marksp's Avatar
Joined Apr 2011
Brilliant, thank you!
Old May 26, 2013, 02:50 PM
RC Erik's Avatar
United States, FL, Naples
Joined Oct 2011
Actually I found out the hard way it doesnt fit. I also have both motors and I the E-Flite 160 prop adapter is a different 4-bolt pattern than the Tacon 160. But its the same overall 12mm diameter shaft.
The picture shown of the Tacon motor is still using the tacon adapter. Here is a pitcture of the E-Flite one, notice the E-Flite one has a straight base while the Tacon one is angled towards the motor.
RC Erik is offline Find More Posts by RC Erik
Old May 26, 2013, 05:54 PM
marksp's Avatar
Joined Apr 2011
Crap!
Thanks for the heads up. Really appreciate the diligence. Unfortunately, that leaves me with the more expensive option which is a custom spinner. I was really hoping to use the E-Flite internally tapped 12mm adapter on my Tacon motor.
Old May 26, 2013, 05:57 PM
RC Erik's Avatar
Joined Oct 2011
What I did for my 73" SBach and 1/4 hangar 9 super cub was put the Tacon prop adapter in a drill press vice and drill all the way through, then tap out the hole to I think it was 10/32 or 5mm? I forgot. Just take the spinner bolt and match it up.
RC Erik's Avatar
Joined Oct 2011
Both times it wasnt perfectly centered but close enough not to cause any vibrations.
Old May 26, 2013, 06:09 PM
marksp's Avatar
Joined Apr 2011
Yeah, my brother has a machine shop in his garage, but he's 2 states away! My H9 1/4 PA-18 Super Cub came with a nicely painted spinner which requires a tapped adapter.
I may be able to get TruTurn to custom make an adapter, otherwise I'll have to get a custom spinner/adapter combo.
Cheers
Old May 27, 2013, 10:53 AM
Spokane, WA
Joined Aug 2009
You could sell the tacon and get an e-flite. I was able to get mine for $75 used. Or ship the adaptor to your brother. Cant be that much to ship back and forth.
pldawg is offline Find More Posts by pldawg
Old May 27, 2013, 01:52 PM
RC Erik's Avatar
Joined Oct 2011
You were able to sell your Tacon 160 motor for $75 used? Thats awesome considering they are $55 new.
http://www.hobbypartz.com/96m608-big...335-245kv.html
Old May 27, 2013, 02:20 PM
Relax, have a Cub
mewert's Avatar
College Place, WA.
Joined Apr 2004
Read the post again. He was referring to possibly buying a used Eflite 160.
Old May 29, 2013, 03:59 AM
Relax, have a Cub
mewert's Avatar
College Place, WA.
Joined Apr 2004
Here you go. http://www.rcgroups.com/forums/showthread.php?t=1900916
Old May 29, 2013, 10:45 AM
marksp's Avatar
Joined Apr 2011
Thx for the heads up.
I suspect I'll either pull the trigger on a new P160, or have TruTurn make me a custom spinner/adapter for my Tacon motor. Either way, I have to go new. Cheers
Old Oct 16, 2014, 07:11 AM
marksp's Avatar
Joined Apr 2011
Ended up getting a buddy to tap the Tacon adapter. Works well
For Sale tacon bigfoot 160 5335-245 big boy 57.50 shipped FLYBABE Aircraft - Electric - Power Systems (FS/W) 1 Jul 04, 2012 07:44 AM
Discussion TACON Bigfoot 160 Motor Questions dakoris73 Power Systems 4 Jul 01, 2012 09:40 PM
Sold Tacon BIGFOOT 160 245kv Rudderman98 Aircraft - Electric - Power Systems (FS/W) 2 Jun 19, 2012 04:49 PM
Sold Tacon Bigfoot 160 Motor birdy233 Aircraft - Electric - Power Systems (FS/W) 4 Jul 07, 2011 05:26 AM
