Old Feb 09, 2014, 11:17 AM
Joined Feb 2014
Zenmuse H3-2D and Devo 8s
I'm building my first multi-rotor with camera. I own a Devo 8s and would like to use it with the Zenmuse H3-2D. I'd like to know if anyone has used this combination and if it works well?
Many thanks.
mardoudan is offline Find More Posts by mardoudan
Old Nov 25, 2014, 03:50 PM
Joined Sep 2014
The only feature I have found that you can pass from the Rx to the Gimbal (be it an H3-2D or H3-3D) is the camera "tilt". Assuming you are running a Naza FC system, this would be a direct channel from your Rx through the Naza, then across the CAN bus to the Gimbal Control Unit. You can control 90 degrees of tilt, and that's about it. The Devo 8s appears to have plenty of assignable channels, so it should work.
nvpowerdoc is offline Find More Posts by nvpowerdoc
Discussion DJI Zenmuse H3-2D Gimbal for GoPro DJI INNOVATIONS Multirotor Talk 5334 Nov 25, 2014 05:10 AM
Discussion DJI Zenmuse H3-2D DJI INNOVATIONS DJI-Innovations 102 Dec 02, 2013 11:27 PM
New Product ZENMUSE GOPRO H3-2D Brushless Gimbal ARRIVED at Aerial Media Pros TEST Footage Video patrick21x Multirotor Talk 25 Jul 19, 2013 12:51 PM
New Product Wow,Naza-M V2 /Zenmuse H3-2D ~Are Coming thanksbuyer Multirotor Talk 32 May 28, 2013 07:39 AM
Discussion My DJI Zenmuse H3-2D just arrived ! Edi4 Multirotor Talk 1 May 16, 2013 05:43 AM
