Old Nov 23, 2014, 01:35 PM
United States, OR, Corvallis
Joined May 2014
mCPX V2 Feathering Shaft
ok, so I have a bent feathering shaft again, and am attempting to remove it. Both this time, and my first time, I cannot get the little Philips screw to come out. It is jammed into the shaft tighter than anything.
So, what tricks have you found to get that screw out?
I figure my options are to throw the whole head assembly away, to perhaps cut the rotor hub apart to expose the feathering shaft so I can then cut it and hence save the $10 blade grips, or employ the trick you are going to tell me about
Suggestions?
HeliFlyer14 is online now Find More Posts by HeliFlyer14
Old Nov 24, 2014, 11:07 PM
RWT
Joined May 2008
[QUOTE=HeliFlyer14;30020039]ok, so I have a bent feathering shaft again, and am attempting to remove it.
Since no one chimed in, it should have locktite on it. If you heat it with a soldering iron or something it would help it come out.
RWT is offline Find More Posts by RWT
Old Nov 25, 2014, 04:44 PM
Joined May 2014
my soldering iron touches the plastic blade grips, so any heat would also cause them to melt. I ended up cutting the main rotor hub apart to expose the feathering shaft, then just used some cutters to cut it in two. This way at least I could save my blade grips.
We'll see when it comes time to replace the feathering shaft I now have in place, as I am the one who put it in, so I know the history. It seems the factory assembled versions are impossible to take apart.
Discussion Link toAlign 450se V2 rotor head and feathering shaft ? dankar04 Mini Helis 1 May 17, 2014 09:48 PM
Discussion MCPX Feathering shaft deebee Micro Helis 1 Jan 03, 2014 02:52 AM
For Sale Align t-rex 700 pro dfc main shaft and feathering shaft helifreak592 Aircraft - Electric - Helis (FS/W) 0 Nov 02, 2013 07:14 AM
Discussion Modded Mcpx blades to prevent feather shaft bending d12bn Micro Helis 0 Mar 15, 2012 12:31 PM
Found mcpx feathering shafts with hardware, hub dampers, linkages of both kind. CorgiCowPockets - xxDExx Aircraft - Electric - Helis (FS/W) 0 Jan 23, 2012 12:07 PM
