Old Yesterday, 10:52 AM
Joined Apr 2014
Havent got a build log on the CX thread im afraid. I can only work on it in the evening, tiny bits at a time (last night I shortened 3 servo leads), and before that, have replaced pretty much everything with Align bits, installed washers for almost every screw (they have small heads, just a tiny bit bigger than the holes and because of this they tend to chew themselves inside the cf without washers) Also needed to modify the motor mount for Turnigy 2627 motor (bigger than stock) and that took me a lot since it fits, but cannot slide back and forth to get the mesh right, so had to get it 100% right first try. Came out great. Not much time left for pictures really.
Apparently the esc still arms itself, and you have to define throttle positions immediately after initialising. I dont care if it arms itself, as long as I defined the throttle min and max pos. This is how ive done it, worked exactly like in the video. Probably thats what Plush esc`s do. I`m still wondering why the 12A doesnt do this (otherwise you wouldve known), or why the 18 and 25A work like this.
I know youve been complaining about the 977 esc doing the same, would be pretty sweet if this also worked on it.
How to Calibrate PPM Min/Max Value with BLHeli ESC (1 min 54 sec)
Ps sorry about your Devo. Info on how to fix it might be difficult to find as you dont know whats broken...blank screen could be anything. I would instead look for other broken 7e's on ebay (preferably just broken sticks) for a donor board. Have you tried the board in a preheated oven for 3 (?) minutes to reflow soldering? Whats to lose.
Hugo Stiglitz is online now Find More Posts by Hugo Stiglitz
Old Yesterday, 11:18 AM
joeclone's Avatar
Joined Jan 2013
The MCU has since blown a hole in it's casing so there's definetely a short somewhere on the board so need to trace it out and see how it goes.
joeclone is offline Find More Posts by joeclone
For Sale Xtreme Production Spin 8200Kv Brushless Motor for mCP X BL or 2s Power mCP X BladeScraper Aircraft - Electric - Helis (FS/W) 0 Nov 12, 2013 10:57 AM
Discussion Skyartec nano brushless or wl v922 crashp Micro Helis 7 Oct 10, 2013 10:12 AM
Help! Can I conver the Giant Scale 83" CMPro Cessna in to Brushless? lrplin Giant Electric Planes 29 Jul 16, 2009 08:58 PM
