Espritmodel.com Heli Air
Old May 21, 2013, 09:52 AM
Joined Oct 2011
Micro brushless gimbal
Since AlexMos's ingenious idea (http://www.simplebgc.com) many gimbals for GoPro and heavier cameras were designed.
I tried to check the concept from micro side. I was really surprised that tiny 2.6g motor can handle keychain 808, #16 HD camera. Now waiting for roll motor, and new PCB board (designed myself to reduce weight). Total weight of the gimbal, including camera and electronics is expected to be less than 40g! (now about 40g, second motor will be compensated by new PCB)
For this test I'm using Martinez board and open source firmware.
The gimbal is attached to Ar Drone v.2
Have a look at first test, video quality is not that good because of re-compression. Insert shows ArDrone's camera (USB record)
[URL=http://youtu.be/otTO-glUc8g[/URL]
Test micro BLDC (brushless, AlexMos) gimbal (pitch only). Ardrone v.2. (4 min 14 sec)
Update (05-28-13) Test of 2 axis gimbal and new board
[URL=http://youtu.be/FDD1ExUTHEI[/URL]
2 axis micro gimbal test (video 2) (3 min 35 sec)
obelix662000 is offline Find More Posts by obelix662000
Old May 21, 2013, 11:19 AM
Joined Dec 2010
finally, some innovation
timecop is offline Find More Posts by timecop
Reply With Quote  (Disabled)
Old May 21, 2013, 01:21 PM
United States, CA, Baldwin Park
Joined Jun 2004
wow this is cool. Good job
TonyTypeS is offline Find More Posts by TonyTypeS
Old May 21, 2013, 04:33 PM
Joined Dec 2011
Now that's very interesting. Great work. I'm currently working on some micro quads and this could be perfect for one of them.
eirikso is offline Find More Posts by eirikso
Old May 21, 2013, 05:34 PM
Joined Jun 2012
ummmmm interesting
neobot is offline Find More Posts by neobot
Old May 21, 2013, 06:20 PM
Joined Dec 2010
What did you end up doing with motor? Had to rewind (ugh) or did the micro have enough resistance not to matter? Subscribing.
Old May 22, 2013, 04:31 AM
Joined Mar 2010
cool
FlyingMcCoy is offline Find More Posts by FlyingMcCoy
Old May 22, 2013, 09:11 AM
Joined Oct 2011
Even worse, with 0.05 mm (AWG 44) wire (12 V version)
Old May 22, 2013, 08:15 PM
I'm New
unfaix's Avatar
United States, TX, Arlington
Joined Mar 2012
build pictures
unfaix is offline Find More Posts by unfaix
Old May 22, 2013, 08:37 PM
Flying Wood For Fun
irun4fundotca's Avatar
Canada, ON, Sydenham
Joined Jan 2012
sweet i was waiting for something in the boardcamera realm
irun4fundotca is offline Find More Posts by irun4fundotca
Old May 23, 2013, 12:32 PM
First quadcopter in space 2014
Full_Tilt's Avatar
United States, FL, Jacksonville
Joined Aug 2012
I was planning on building a little brushless gimbal for an 808 as well. I was thinking of using the CF2822 motors because theyre very cheap and sorta light but that little motor youre using would be much lighter. How much can the be had for, and from where?
Full_Tilt is offline Find More Posts by Full_Tilt
Old May 23, 2013, 09:55 PM
Joined Oct 2011
Hobbyking AP-02 7000, relatively expensive $18
http://www.hobbyking.com/hobbyking/s...tor_2_3g_.html
Old May 23, 2013, 11:09 PM
Joined Jan 2013
this seems a great fit for 3d printing because of the low weights you could really get things done on the thin side. and lets hope we can find some good motors i dont think i could rewind a motors this small. maybe we can trick the guys over at www.flytyingforum.com to do it for us.
GoneSilent is offline Find More Posts by GoneSilent
Old May 24, 2013, 09:29 AM
Joined Dec 2010
I don't think anything on this scale is worth 3D printing, the quality/resolution is horrible.
Old May 25, 2013, 07:48 AM
Joined Oct 2011
I did mistake in my previous posts ( corrected): the motor is AP-02, not AP-03
Yippee! Simple Brushless Gimbal Controller--FPV MODEL fpvmodels Multirotor Talk 3003 Yesterday 01:17 PM
New Product J&K-GAY 2-axis Brushless Gimbal (controller + brushless motor + frame) PNP $112 lao Multirotor Talk 6 May 26, 2013 01:44 PM
Discussion When will Mini/Micro Quad meet the Brushless Gimbal Cam boiko Mini Multirotors 1 May 21, 2013 01:42 PM
Help! DIY Brushless motor gimbal, need help sourcing parts for gimbal hexa Multirotor Talk 13 Apr 13, 2013 03:08 PM
