Old Apr 22, 2015, 02:42 AM
That_JetGuy325 is online now
Find More Posts by That_JetGuy325
United States, CA, Hesperia
Joined Jan 2015
Het 90mm F-18 Elevator Upgrade??
I'm looking to buy the HET 90mm Fully Composite F-18. I currently have the HET 90mm F-16 which I had to do significant modifications to in order to make the jet safe to fly (elevators & fuselage). The F-18 has always been one of my favorite jets and I would love to own one. Im afraid I do not have the proper equiptment to make the modifications like keithtsr did with his F-18. Would anyone be able to help me out and make me a set of hardware for the full flying elevators like keithtsr's or similar? I will be running the jet on 12s. The hardware will be at my cost plus labor. Any suggestions are much appreciated. Here is the link to keithtsr's setup-
http://www.rcgroups.com/forums/showt...1864447&page=9
That_JetGuy325 is online now Find More Posts by That_JetGuy325
Old Apr 22, 2015, 06:46 AM
CoolerByTheLake is offline
Find More Posts by CoolerByTheLake
Do it Right, the first time!
CoolerByTheLake's Avatar
United States, MN, Hermantown
Joined Dec 2008
As long as you put it that way...
I started working on a larger KMP foamy (L=64.5". WS = 47"..JF90 on 12s ) awhile back , and I too had read Keith's thread. I came up with this set up.. Using similar methods as Y/A does for it's F-18 kits.. here: http://www.rcgroups.com/forums/showp...3&postcount=58
I don't know how much room you have to work with, but you surte could modify it some to fit yours. Parts used--control horns--http://www.sierragiant.com/prod14.html ....Bearings (2-sets ) ...http://www3.towerhobbies.com/cgi-bin...?&I=LXD093&P=7
And the 1/4" rod from here. http://www.onlinemetals.com/ Chose which ever metal suits you-- Titanium, Stainless Steel. I got some flack on what I chose- everybody said it would bend- but if it bends in 6", something else went wrong, and its not coming home!.......http://www.onlinemetals.com/merchant...192&top_cat=60
It's still in construction so I cant say how it works-but I recently got one of the last Y/A F18 single kits around-- so who knows if or when it might.
I just figured if it was good enough for Y/A to do there's that way --way not .
No fancy tooling needed here. Good luck.
Cooler
CoolerByTheLake is offline Find More Posts by CoolerByTheLake
Old Apr 22, 2015, 07:15 AM
Big Fred1 is offline
Find More Posts by Big Fred1
Joined Feb 2014
Jetguy, I have a new in box HET 90mm F-18 Blue Angels for sale. Might save you a bit. Fred.
Big Fred1 is offline Find More Posts by Big Fred1
Old Apr 23, 2015, 12:03 AM
Joined Jan 2015
Thanks, CoolerByTheLake…. some helpful information. I may go that route if I am unable find someone that can make me a setup closer to factory.
Pm sent to Big Fred1
Old Apr 25, 2015, 06:51 PM
Joined Jan 2015
Has anyone used modified wood blocks instead of aluminum for the elevator assembly without the formers attatched?
So to make things clear, the example of the Y/A F-18 mounting style but without the formers. I just do not want the rod running through my ducting.
Old Apr 25, 2015, 08:10 PM
Joined Dec 2008
On the Y /A , the rod does not run through the ducting! .. They only go as far as the
inner former About 4+ inches , give or take.
Go back to this-- http://static.rcgroups.net/forums/at...mounts%20-1.jp
yes it does show it going full length- BUT only to keep bearings centered, then they are cut off.
Old Apr 25, 2015, 08:25 PM
Joined Jan 2015
Ohh…..My mistake, I see it now.
Thanks again lol
Sold 90mm EDF Jets (F-18 and EuroFIghter) FS + backup F18 kit! JET FAN + HET!!!! NickFox Aircraft - Electric - Jets (FS/W) 4 Mar 24, 2015 02:46 PM
Sold Nib Het 90mm all composit F -18 with Retracs Louis D Aircraft - Electric - Jets (FS/W) 6 Feb 26, 2015 10:56 AM
Sold REDUCED!!!!!EXCEED RC 90MM F-18 Diamond Back Viper ARF UPGRADED ELECTRONICS Forrest Gump 23 Aircraft - Electric - Jets (FS/W) 4 May 17, 2014 10:27 AM
For Sale REDUCED!!!!!EXCEED RC 90MM F-18 Diamond Back Viper ARF UPGRADED ELECTRONICS Forrest Gump 23 Aircraft - Electric - Jets (FS/W) 2 Apr 30, 2014 05:35 PM
Discussion Need Info on New 90mm HET F/A- 18 Sniper.308 Electric Ducted Fan Jet Talk 30 Dec 31, 2008 02:49 PM
