Old Apr 04, 2008, 08:51 AM
Sailplane Mafia
gquiring's Avatar
United States, SC, Summerville
Joined Jun 2001
JR 9303 2.4 flash memory backup
I was reading the manaul for the 2.4ghz version of the 9303 and found this comment:
All preprogrammed data is protected by a flash
memory that guards against memory loss main
transmitter battery failure.
Does this mean the watch battey has finally been replaced with flash ram?
gquiring is offline Find More Posts by gquiring
Old Apr 04, 2008, 11:42 AM
Stress Be Gone
GBR2's Avatar
Snohomish, WA
Joined May 2000
Yes
GBR2 is offline Find More Posts by GBR2
Old Apr 04, 2008, 12:38 PM
Deletedfor proving Nauga wrong
Joined Mar 2005
And... there is a way to download the TX memory to your computer. So if you send it in for service and they clear it out... you can reload it.
You can also tranfer one or all model memories to another 9303
I need to dig deeper in the manual and find how to do it... It uses the buddy cord port.
fhhuber506771 is offline Find More Posts by fhhuber506771
Old Apr 04, 2008, 01:12 PM
most exalted one
BC Canada
Joined Aug 2002
And $100 serial device or $50 USB device approx, I believe.
4*60 is offline Find More Posts by 4*60
Old Apr 04, 2008, 01:21 PM
Joined Mar 2005
if it requires a special cable... its probably worth getting it.
Old Apr 04, 2008, 08:03 PM
You can call me FANBOY!
Goodlettsville, TN
Joined Sep 2006
Wow, that is kinda high.
http://jrradios.com/Articles/Article...ArticleID=1553
http://jrradios.com/Products/Default...ProdID=JRPA301
chrisf testpilot is offline Find More Posts by chrisf testpilot
Old Apr 05, 2008, 01:27 AM
most exalted one
BC Canada
Joined Aug 2002
Originally Posted by chrisf testpilot
And I bet the programmer and producer of this software is not as rich as Bill Gates or Paul what's his name, so "high" is relative.
Old Apr 05, 2008, 02:24 AM
Joined Mar 2005
Well... higher than I like... but I will still probably get it.
Old Apr 05, 2008, 06:59 AM
Sailplane Mafia
gquiring's Avatar
Joined Jun 2001
Is it still serial based or did they finally make a USB version? I have the older one for the PCM 10X and I could not get a USB to serial converter to work at the time. Most newer PC's don't have serial ports anymore.
Old Apr 05, 2008, 08:55 AM
Ivan MacKenzie
imack's Avatar
Toronto, Ontario, Canada
Joined Nov 2002
They have a new one, which is USB and cheaper to boot: http://www.horizonhobby.com/Products...ProdID=JRPA310 The software also looks better, so it's win-win-win.
Ivan MacKenzie.
imack is offline Find More Posts by imack
Old Mar 25, 2014, 05:21 PM
Joined Apr 2007
Jr 9303 Tx
Memory problem with TX, I can select the required model memory ok but after flying when I turn the Tx off then back on to fly again, the Tx reverts to the last model memory programmed not the one I used for the last flight.
Can any help with this problem
Stuartt is offline Find More Posts by Stuartt
Old Mar 25, 2014, 05:50 PM
Stress Be Gone
GBR2's Avatar
Snohomish, WA
Joined May 2000
Sounds like something is corrupted. I'd send it in to Horizon and not fly with it any longer till the issue is resolved.
Old Mar 26, 2014, 05:49 PM
United Kingdom, Slough
Joined Aug 2003
Transistor Q1 on the CPU pcb is blown. Very easy fix.
theaton56 is offline Find More Posts by theaton56
Article JR X9303 2.4 Transmitter Review rc2xs Radios 88 Aug 29, 2009 07:24 PM
New Product JR 9303 2.4 Disponibles en Mexico!!! alenys Mexico 34 Mar 28, 2009 10:17 PM
Discussion Jr 9303 2.4 gquiring Radios 5 Mar 15, 2008 10:05 PM
Discussion JR 9303 2.4 Shipping Yet Kevin Murray Radios 18 Dec 05, 2007 07:34 PM
Sold Christmas sale!! JR 9303 2.4 GHz system! airmcn_3 Aircraft - General - Radio Equipment (FS/W) 2 Dec 01, 2007 07:52 AM
