Old Jul 17, 2014, 12:21 PM
Joined Jul 2014
Hi
Ranger EX, GoPro 3 (5 min 29 sec)
Seven66 is offline Find More Posts by Seven66
Old Jul 17, 2014, 01:50 PM
Joined Jan 2011
Originally Posted by Arxangel View Post
Hi, here is the front of the package of the tape:
Thank you Arxangel
costasp is offline Find More Posts by costasp
Old Jul 17, 2014, 02:02 PM
Arxangel's Avatar
Bulgaria, Sofia-grad, Sofia
Joined Feb 2012
Originally Posted by Seven66 View Post
Nice!! Is the gimbal OK after going into the taller grass on the landing? I'm thinking it might have nosed over!!
Arxangel is online now Find More Posts by Arxangel
Old Jul 17, 2014, 06:02 PM
Joined Feb 2012
Cool. Ive been waiting to hear more from people using gimbals with this plane.
epyonxero is offline Find More Posts by epyonxero
Old Jul 17, 2014, 08:22 PM
Joined Apr 2014
Hello all,
I've read this entire thread, thanks for all the great info on this sweet plane Arxangel and others!
Got my Ranger from Cambriahobby and it had some extra items arrive in the box; a 12V step down regulator, a volt meter with low voltage alarm, and a World Cup flashlight/bottle-opener/key-chain. Anyway, I still need to select a motor. I'm getting the ET Vector which works up to 6S so I don't want to go higher than that. What do you guys think about these 6S motors? I don't have that calc program some of you have mentioned so I don't know what pitch propeller to get.
Scorpion SII-3020-780 V2 800W
Turnigy Aerostar 4340-500kv 900w (liking this one)
Turnigy L3040A-480G 1000W
Turnigy 3025-850kv 1300W Helicopter Motor
Arxangel, you mentioned using Tiger MT2820-7830KV 668W motor, I found a chart for this at 5S using an 11x4.7 and 13x4 APC props. Both of those max out the wattage, I don't know what a 10 inch prop would do or what pitch to get if I go with this motor. I haven't even seen charts for the other motors so same boat there but at least they can handle more watts. What do you think?
Lazer707 is offline Find More Posts by Lazer707
Old Jul 17, 2014, 09:40 PM
Living Large On Lake Sinclair
United States, GA, Eatonton
Joined Nov 2009
Very nice video Seven66..gimbal seemed to work very well. Would you share brand, type etc. Thanks
flyifr is offline Find More Posts by flyifr
Old Jul 17, 2014, 09:45 PM
Joined Nov 2009
Lazer707....the 800, 900 would need a larger prop than the stock Ranger EX can take to be setup correctly. You should look for something in the range of 1000 - 1200 which will allow you to use either 3s or 4s with 9x prop or 10x prop. BTW, it is tough to find a motor in this range....all out of stock in a lot of vendor sites.
Old Jul 18, 2014, 01:50 AM
Joined Apr 2014
Hmmm..... Arxangel said the best efficiency for longer flights would not come from 4S with this plane but I don't have the experience or knowledge to know. I found ecalc (yeah!) and have been plugging in different motors/props. I'm noticing with with too high a pitch prop it says
"The airflow at the propeller blade will stall. Therefore the static thrust and max. current may not be reached."
Now I'm thinking 5S, perhaps Turnigy D3548/6 790KV with 10x6 prop. Ecalc says 2619g static thrust and 611 watts. Just noticed Hobbyking says its max thrust is 1650g. I'm so confused, lol.
Old Jul 18, 2014, 02:54 AM
Arxangel's Avatar
Joined Feb 2012
Originally Posted by Lazer707 View Post
Hello all,
The T-motor for 6S I have is the 830Kv one, so I think you've added an extra "7" in the Kv rating, and I've flown it on 6S and a 10x7SF prop, and it comes down ice cold, so I wouldn't worry about overloading it, unless you plan on flying full throttle all the way.
When it comes to eCalc, and I've said this before, there isn't a single setup that I've tested there, who's results have turned out to be correct. For me eCalc has gotten everything wrong - multi-rotors and planes alike, so I tend to not to use, or trust it.
That aside, using a SF prop would ensure that you will have ample thrust even in those tough situations and at low RPM, the E props would need a lot more speed to become efficient, and generally lack static thrust.
As for 4S, at least on my Ranger efficiency has not been optimal - 8S and 10S setups yielded much better results, although I have not yet tested a 6S setup on the Ranger.
Old Jul 18, 2014, 06:22 AM
Joined Jan 2011
And here is the bar code:
its very strong.
I have to find something to peel off the tape from plane
Old Jul 18, 2014, 07:21 AM
Arxangel's Avatar
Joined Feb 2012
Originally Posted by costasp View Post
its very strong.
Told you.
Old Jul 18, 2014, 07:45 AM
Joined Jul 2014
Gimbal: http://www.ebay.com/itm/DJI-Phantom-...item417fd55376
Landing gear upgrade:
Discussion FPVMODEL.COM Ranger-Ex FPV Specific!!!! fpvmodels FPV Aircraft 79 Jul 10, 2014 10:23 PM
Discussion Ranger Ex UAV Platform AstarJoe FPV Aircraft 203 Jun 17, 2014 05:09 PM
Build Log Hexacopter 650mm build thread - full fpv jacekj Scratchbuilt Multirotors 1 Mar 31, 2014 09:06 AM
Careful! "Dragnipur" Build Log - Dollar Tree, twin boom, inverted V-Tail FPV platform polyfractal Foamies (Scratchbuilt) 51 Nov 27, 2012 08:00 AM
Discussion Best long range platform for fpv? xrisnothing FPV Talk 10 May 20, 2010 12:02 PM
