Old Jul 22, 2014, 09:21 AM
Team 3DHS / Team JR
Bivens's Avatar
United States, TN, Knoxville
Joined Apr 2010
HV is fine for 7955's....so even at 8v it should perform perfectly..
Bivens is offline Find More Posts by Bivens
Old Jul 22, 2014, 10:26 AM
I live my life 8oz at a time..
arnav's Avatar
United States, FL, Miami
Joined Nov 2011
yeah, this is more than a buzz it is vibrating due to the motor continuously running inside (at least this is what it is sounds like).
arnav is offline Find More Posts by arnav
Old Jul 22, 2014, 02:45 PM
3D Addict
alfabeast's Avatar
Merrimac, MA
Joined Jan 2006
guess 8s is the way to go
Well I thought I had ok performance on 6s and A60-6xs. I was hovering low letting the wind push me downstream. When I torque rolled the wind blew the nose over a little and I punched out, but didn't have enough ooomph and smacked the tail. So 8S here I come .... based on what I have seen on this forum, Soon as the hobby fund is replenished.
alfabeast is offline Find More Posts by alfabeast
Old Jul 22, 2014, 03:17 PM
FoamyFactory.com
Tim H.'s Avatar
USA, TX, Fort Worth
Joined Nov 2001
I just got my DM4330 back from having it rewound to 216 kv. I'm going to try 12s on the Edge. Not sure when I'm going to get to it, but now I don't have any excuses to work on it.
Tim H. is offline Find More Posts by Tim H.
Old Jul 22, 2014, 03:59 PM
Barefoot Birkinsomething
rcbirk21's Avatar
United States, CA, Hayward
Joined Aug 2004
you may want to check the quality of the batteries. i just noticed after 2 seasons with my 6s5300 packs they are not holding voltage like they used to. caught me off guard, but i was getting about 10-15amps less than what i expected on a freshly charged pack.
rcbirk21 is offline Find More Posts by rcbirk21
Latest blog entry: Joe's Battery Contraption
Old Jul 22, 2014, 04:31 PM
Not as Good as The Kid
Aeroplayin's Avatar
South Pasadena, FL
Joined Sep 2009
20x8 Xoar. Zoom, Zoom...
I just swapped out the Hacker A60-7S with the A60-8S just so I could try the 12S setup with the 21x10 Falcon. About the same Watts and thrust as the 20x8, but a bit more torque. Both go to about 70A. The plane doesn't need more power, but I'd like to see the difference in torque. I had the 21x10 on 10S originally and it hung on the prop just a bit better, but the 12S and 20x8 was way better at the top-end. No contest.
So now this may be the best of both worlds, and I can even try the 22x8 on 12S... it does clear and I've already flown the prop with the 10S setup. I'm not sure what the throttle response is going to be like, but we'll soon see.
Good suggestion... just picked up enough 40C 6S 3300 for my 12S setups to last me until Christmas with a 15% off coupon from Hobbypartz. Free shipping over $100 as always.
Aeroplayin is offline Find More Posts by Aeroplayin
Old Jul 22, 2014, 05:05 PM
3D Addict
alfabeast's Avatar
Merrimac, MA
Joined Jan 2006
fresh gensace 5300's and glacier 5000's - all low mileage. I feel the need for speed.
Old Jul 23, 2014, 05:51 PM
arnav's Avatar
Joined Nov 2011
Xoar PJA 20 x 6 for the DLE-35? Props are the very last thing I have left to order...
Old Jul 23, 2014, 05:58 PM
United States, NY, New York
Joined Aug 2011
I'm using the falcon 20x7 and vess 20B
If you want to move gradually then start with 19x8
Torchy is offline Find More Posts by Torchy
Old Jul 23, 2014, 06:15 PM
arnav's Avatar
Joined Nov 2011
I don't, but if you think it is better for the engine I will...
Both your falcon and vess seem to have a higher pitch than the recommended x6 pitch (which does make sense to me). I am using a 17x6 on the 20RA, so it seems like the pitch should increase a little when you go up to a 20" prop if you go by the "half the diameter rule."
Old Jul 23, 2014, 08:53 PM
Joined Aug 2011
The last thing I would want do is to impose on others. Though in my 5 year experience, I have learned that breaking in an engine with right prop will give you some extra assurance in prolonging the engines life. For the others who disagree, then my only argument would be is it "won't hurt" if you do.
The 20x6 in my experience won't give you the speed range one would expect from an edge. Particularly if you are into a mix of freestyle and 3d. High energy maneuvers requires some speed to compensate for the awesome light weight frame we have. The 6 pitch also made me feel as if the engine wasn't loaded enough.
Try the falcon as it fits smack in the middle and get a Vess or a xoar 8 pitch for the sake of trying it out. My setup is used in an environment with 80's to 90' F and 100 meters above sea level.
All the best!
Old Jul 23, 2014, 11:13 PM
arnav's Avatar
Joined Nov 2011
Sounds good. I will get both a 6 and an 8 and see which one I like better. Thanks for all the suggestions.
Discussion 60 inch edge 540 vs 48 inch extreme flight extra 300 & edge 540 vs 3dhs slick 51 & 59 CRFan1 3D Flying 40 Mar 04, 2012 02:45 PM
Sold 3DHS 41" Edge 540 PNP $225 gonzoman5 Aircraft - Electric - Airplanes (FS/W) 10 Oct 05, 2011 10:53 AM
Wanted 3dhs Edge 540 47" (red bull scheme) SmokeDogg Aircraft - Electric - Airplanes (FS/W) 13 Sep 29, 2011 02:19 PM
Wanted 3DHS Edge 540 47" (Red Bull Scheme) SmokeDogg Aircraft - Electric - Airplanes (FS/W) 0 Sep 24, 2011 01:58 AM
Wanted 3dhs edge 540 47" (red bull scheme) vhuang168 Aircraft - Electric - Airplanes (FS/W) 2 Sep 08, 2011 10:13 PM
