Old Jun 25, 2016, 08:39 PM
DroneRequired is online now
Find More Posts by DroneRequired
Australia, VIC, Melbourne
Joined Oct 2015
Help!
3s Lipo - 1 volt difference between cells!
Hi all,
After another flight on my Eachine 250 Falcon I tested my lipo to check if I could squeeze a few minutes more. But what my lipo tester told me was quite disturbing. It read:
Cell 1: 3.7, Cell 2:2.7 Cell 3: 3.6 Total: 9.9
I think the lipo tester might be out, but I;m scared to try and plug it into the charger.
What would you do?
DroneRequired is online now Find More Posts by DroneRequired
Old Jun 25, 2016, 09:04 PM
kamcoman is online now
Find More Posts by kamcoman
Douglasville, GA
Joined Sep 2004
Measure the voltage with a multi-meter to verify lipo tester accuracy.
kamcoman is online now Find More Posts by kamcoman
Old Jun 25, 2016, 09:25 PM
Joined Oct 2015
I don't actually have a multimetre, but my charger will give me a reading of the battery's total voltage but not each cell.
Old Jun 25, 2016, 10:13 PM
hoppy is offline
Find More Posts by hoppy
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
Plug it in and out a few times. Sometimes a little bit of contamination on the pins will give strange readings.
BTW, squeezing a little bit more out is a sure way to kill a battery as you now know.
Lipos should not be discharged below 3.7V/cell (resting v). 11.1V(3.7/cell) is a long way from 9.9V.
What charger are you using?
See sticky above about charging "dead" packs.
hoppy is offline Find More Posts by hoppy
Old Jun 25, 2016, 10:40 PM
Joined Oct 2015
I tested it again and the bad cell reads 3.2 volts, I charging the Lipo up now. Close call, I've learnt my lesson. Thank you for your help.
Old Jun 26, 2016, 07:12 AM
ggcrandall1 is offline
Find More Posts by ggcrandall1
ggcrandall1's Avatar
USA, GA, Marietta
Joined Aug 2005
There are several tools that every electric flier should have in the tool box.
1. Wattmeter. It's the only way you can tell exactly how much current your system demands. Without a wattmeter you can easily damage motors, ESC's and batteries.
2. Digital Volt meter. This is so that you can verify battery voltages. The cheap cell checkers are OK for a quick check but you need a decent DVM for varification.
3. A full function charger. It must balance charge, storage charge and discharge. It must report pack and cell voltages as well as charging current and mAh returned to the pack during charge. A good one will also measure Internal Resistance (IR).
Glen
ggcrandall1 is offline Find More Posts by ggcrandall1
Old Jun 27, 2016, 06:04 PM
Joined Oct 2015
Glen
Looks like I need to add few things to my shopping list.
Old Jun 27, 2016, 07:01 PM
USA, GA, Marietta
Joined Aug 2005
Glen
And if you haven't already done so, read this:
http://www.tjinguytech.com/charging-how-tos
Glen
Question Difference between 3s and 4s sinmore Multirotor Beginner 16 Apr 06, 2016 10:04 PM
Help! 1 Cell in 3s Lipo completely discharged(0 V). Need Help! Aarkay840 Batteries and Chargers 1 Mar 04, 2016 05:33 PM
Discussion Difference in v between cells in lipo DCZ Batteries and Chargers 2 Apr 17, 2015 02:30 AM
Discussion Physical difference(s) between different LiPo cells Tachikoma Batteries and Chargers 9 Sep 12, 2006 10:01 PM
