Old Dec 09, 2015, 08:35 AM
milnei is offline
Find More Posts by milnei
Buckingham, UK
Joined Jan 2010
FS-T6 2 position switch to 3 position switch mod??
Quite possibly a stupid question, with a very simple answer.....
I've seen it's easy to de-solder one of the variable pots and fit a 3 position switch with resistors in place of the pot.
However, I'm hoping to retain both variable pots (to control both axis on a gimbal) and still have a 3 position flight mode switch for my Quantam Nova.
Now, I'm guessing as the FS-T6 is a 6 channel radio, I can't have both pots plus the 4 flight controls AND a flight mode switch as that's 7 channels. Is that right?
OR - is the flight mode switch not a 'real' channel, and 'IF' one of the 2 position switches could be modded to a 3 position switch, I could still have both pots and a 3 position flight mode switch?
OR - do I need to buy a 7 or more channel radio?
Thanks, Ian.
milnei is offline Find More Posts by milnei
Discussion Changing 2 to 3 Position switch on FF7 2,4Ghz Tx JoseLuis28 DIY Electronics 2 Nov 05, 2015 05:26 AM
Mini-HowTo FlySky fs-t6 3 position switch mod português QuartoDIY Radios 0 Apr 28, 2015 10:42 PM
Question Replacing a 2 position switch with a 3 position switch Ztubbz Radios 2 Mar 12, 2014 08:46 AM
Discussion 3 position switch instead of 2 position switch ??? vlatko DIY Electronics 3 Mar 20, 2011 07:48 AM
