Old Jan 03, 2015, 07:40 AM
bbenner is offline
Find More Posts by bbenner
BOATBring Out Another Thousand
bbenner's Avatar
United States, ME, South Bristol
Joined Sep 2013
Build Log
Dual Benner 48" builds 1 R/C, 1 static
Heres the start of 2 builds, the rc boat is mine and the static to match a guys boat. Ive gotten the rails and deck framing started on both. The rc will have the same G160 motor Im using in the Lowell hull and a 4" Rivabo prop, the plan is to have a 29" launch off of it.
Brent
bbenner is offline Find More Posts by bbenner
Old Jan 03, 2015, 08:09 AM
louie R/C NUT is offline
Find More Posts by louie R/C NUT
no such thing as to many boats
louie R/C NUT's Avatar
United States, NY, New York
Joined May 2010
Off and running
Brent are you also making me those pieces as well for mine if you could make that as part of mine also I appreciate it I'm limited to the cutting I can do in my place .
louie R/C NUT is offline Find More Posts by louie R/C NUT
Old Jan 03, 2015, 08:38 AM
bbenner is offline
bbenner's Avatar
Joined Sep 2013
Originally Posted by louie R/C NUT View Post
Off and running
Which pieces Louie? The rail spacers are mostly from the scrap of the larger sticks, I am keeping a stick material list for it. The sheet pieces will be cut as close as I dare to leave room for any difference in the way things go together, same for the deck sheets.
Brent
Old Jan 03, 2015, 10:39 AM
Joined May 2010
Ok Brent that's good I can sand and shorten if needed .
I need it as close to a kit as possible will make it easier for me on this end .
Old Jan 03, 2015, 11:34 AM
bbenner is offline
bbenner's Avatar
Joined Sep 2013
Some progress on the static model. Deck all framed and sheeting started.
Brent
Old Jan 03, 2015, 12:27 PM
bbenner is offline
bbenner's Avatar
Joined Sep 2013
Louie do you want a piece of sheet cut for the stern rail? Both of these models are going to be open stern boats.
Brent
Old Jan 04, 2015, 07:59 AM
bbenner is offline
bbenner's Avatar
Joined Sep 2013
Start of the wheelhouse panels.
Brent
Old Jan 04, 2015, 09:47 AM
bbenner is offline
bbenner's Avatar
Joined Sep 2013
What they look like before I start cutting. Thats alot of lines to put on 4 panels.
Brent
Old Jan 04, 2015, 10:18 AM
sound sailor is offline
Find More Posts by sound sailor
Plures Naves Quam Mentes
sound sailor's Avatar
United States, NY, Westchester
Joined Jul 2011
Lookin good Brent!
I like to layout the house etc on cheap poster board and when I like it on there I cut it out and place it on the boat to see if it needs any tweaking before committing any material. Of course if you have scale plans than you can just go from them.
Below is the poster board I used when I did Moonglow. You can see where I found I needed to add 1/2" to the bottom of it.
Just a thought
Bill
BTW I know you like to use balsa but if you use something like sentra or other composite you can cut in one piece eliminating seams to fill and sand.
sound sailor is offline Find More Posts by sound sailor
Old Jan 04, 2015, 12:21 PM
Umi_Ryuzuki is offline
Find More Posts by Umi_Ryuzuki
Sea Dragon-Lover
Umi_Ryuzuki's Avatar
PDX, OR
Joined Dec 2002
That's building quick, and coming together nicely.
Umi_Ryuzuki is offline Find More Posts by Umi_Ryuzuki
Old Jan 04, 2015, 01:06 PM
bbenner is offline
bbenner's Avatar
Joined Sep 2013
Pile of panels!
Brent
Old Jan 04, 2015, 01:07 PM
bbenner is offline
bbenner's Avatar
Joined Sep 2013
This is where it starts to slow down lol, a lot of fitting and epoxing to do.
Brent
Old Jan 04, 2015, 04:06 PM
chum444 is offline
Find More Posts by chum444
lots of water; some of it thin
chum444's Avatar
United States, MA, Woods Hole
Joined Aug 2012
Originally Posted by sound sailor View Post
Lookin good Brent!
Just a thought
Bill
Bill,
I use the same technique. I usually mock up almost everything in poster board. However I don't use sentra which as you point out requires more work.
Other Bill
chum444 is offline Find More Posts by chum444
Old Jan 04, 2015, 04:32 PM
bbenner is offline
bbenner's Avatar
Joined Sep 2013
Lookin good Brent!
Just a thought
Bill
I used to cut cardboard ones but found I could go faster cutting the balsa ones big getting the first just right and cutting the second. I get the seam between the sheets pretty close but I fiberglass everything on so they dont show much anyway.
Brent
Old Jan 04, 2015, 11:23 PM
bbenner is offline
bbenner's Avatar
Joined Sep 2013
Midnight building.
Brent
Wanted NIB K&B .48 R/C Engine, complete Gene Chernosky Aircraft - Fuel - Engines and Accessories (FS/W) 0 Feb 04, 2014 09:19 PM
Sold Pair of British Merco's A .61 Dual Glow Head R/C & .35 R/C stevster Aircraft - Fuel - Engines and Accessories (FS/W) 2 May 07, 2013 04:25 PM
Gallery Academy 1/48 scale Merkava r\c Tank conversion with Video modfly RC Tanks 5 Jan 09, 2011 12:21 AM
For Sale Billings Lifeboats 1:40 NIB (2) r/c convert. static vrylowflyer Boats (FS/W) 0 Aug 12, 2007 04:08 PM
