Old Jul 21, 2011, 11:24 AM
JimHSoars is offline
Find More Posts by JimHSoars
United States, OK, Tulsa
Joined Jun 2003
Airfoil Coefficient of Lift vs. Angle of Attack etc. Plots Books
Hi Folks:
I am looking for a site on line or in print where I can look at the wind tunnel results for airfoils such as a Clark y or the Dr. Seligís S3021. Yes Iím designing an electric powered airplane for a beginner or a person who needs a forgiving plane for easy flying.
Also, I know that airfoil polars compare the Cd vs. CL but I donít know the name for the plot that includes a sectionís CL & pitching moment vs. its angle of attack (α) at various Reynolds Numbers (Re). Please post the name in this thread.
Thanks.
Jim
JimHSoars is offline Find More Posts by JimHSoars
Last edited by JimHSoars; Apr 04, 2014 at 11:08 AM. Reason: Add the word Books to the title for others searches.
Old Jul 21, 2011, 08:28 PM
BMatthews is online now
Find More Posts by BMatthews
B for Bruce
BMatthews's Avatar
The 'Wack, BC, Canada
Joined Oct 2002
Truly your best bet is to download and then pay for the unlocking codes for Profili 2. It comes with Xfoil bundled in but you can only access it with the unlock code. But it'll do all you want and then some for analyzing airfoils.
If you're doing a first trainer keep in mind that you actually do not want the slickest and most slippery airfoil. One that generates lots of drag at low angles of attack such as in a dive is actually a good thing. It avoids the model speeding up too quickly for your early flying skills.
BMatthews is online now Find More Posts by BMatthews
Old Jul 21, 2011, 08:52 PM
nmasters is online now
Find More Posts by nmasters
internet gadfly
nmasters's Avatar
Colorado
Joined Aug 2006
XFLR5 can do more analysis tasks than Profili and it's free. Not quite as easy to use though
nmasters is online now Find More Posts by nmasters
Old Jul 22, 2011, 09:51 AM
zwtipp05 is offline
Find More Posts by zwtipp05
Joined Apr 2011
You can also get xfoil on its own for free...http://web.mit.edu/drela/Public/web/xfoil/
Just won't be quite as nice to use
zwtipp05 is offline Find More Posts by zwtipp05
Old Jul 22, 2011, 10:58 AM
HerkS is offline
Find More Posts by HerkS
Herk
HerkS's Avatar
Virginia USA
Joined Jun 2007
Here is some of the Selig Wind Tunnel Data for the two that you mentioned.
The S3021 does not include tested data for Cm.
The Clark Y data does include Cm testing.
HerkS is offline Find More Posts by HerkS
Old Jul 22, 2011, 12:55 PM
internet gadfly
nmasters's Avatar
Colorado
Joined Aug 2006
Xfoil has a command line interface and doesn't do as much as XFLR5
Old Jul 22, 2011, 02:09 PM
MCarlton is offline
Find More Posts by MCarlton
Cromer,Norfolk, UK
Joined Nov 2006
I'd only add one thing, and that is that as a beginner, and one designing a trainer at that, are you going to build this in such a way that your wing will be 100% true to the section you select?
If its not 100% accurate, all those polar diagrams are somewhat irrelevant.
The more important factors here are basic design stuff, such as incidence, moment arms, areas, weights etc.
MCarlton is offline Find More Posts by MCarlton
Old Jul 22, 2011, 09:13 PM
B for Bruce
BMatthews's Avatar
Joined Oct 2002
... as it would be if you are using an open bay multi spar style of construction with covering on the wing. Such an airfoil between the ribs has only a passing resemblance to what the airfoil at the rib is like.
And again since it is a trainer/sport flyer there just isn't the burning need to achieve an exact airfoil anyway. Instead something with a pleasant manner and a gentle stall is far more important than the slippery "go fast" performance of the 3021 you're asking about in the other thread. The Clark Y shape is a step in the right direction but even it can be more "slippery" than what you want on a trainer.
On any other style of model an airfoil which comes with a bit of a built in headwind would be a bad thing. On a trainer it aids in providing a more constant speed sort of model. And that gives newbie and low time pilots a lot more time to contemplate their next move. The needs of the new pilot turns what should be a failing into a feature.
By way of example here's an airfoil I used on a small high wing sport model some years back. Truth be known it was used on a rudder only .049 powered model to have some fun learning to fly "the old way". The airfoil is a basic TLAR shape with a high point slightly ahead of and thicker than a Clark Y. In use it turned out to be a real winner. A decent enough glide and a nice pre-stall mush which tends to lower the nose nicely and restore flying speed. Only if forced will it reach the point of a straight away stall. It builds speed in a dive and holds it well through a series of rudder only maneuvers. Maybe TOO well for a trainer. The structure was D tube back to the high point then open with cap strips back to a trailing edge.
It would be fun to stick this into Xfoil and see what the charts look like. I can supply DXF output to anyone that may want to try it.
Old Jul 25, 2011, 06:47 PM
Joined Jun 2003
MCarlton:
Thanks for your comments. I have books by Howard Chevalier, Model Airplane Design and Performance for the Modeler, Andy Lennon's Basics of R/C Model Aircraft Design, Martin Simons' Model Aircraft Aerodynamics, and Carlos Reyes' Model Airplane Design Made Easy. The second two are currently lost in moving boxes some where. I am going to careful about that "basic design stuff" based on what I can glean from these books and RC Groups.
Jim
Old Jul 25, 2011, 06:53 PM
Joined Jun 2003
... as it would be if you are using an open bay multi spar style of construction with covering on the wing. Such an airfoil between the ribs has only a passing resemblance to what the airfoil at the rib is like.[...]
Thanks Bruce.
I have been thinking hard about making this wing a 'D' tube design for just this reason. Weight is an issue to this might make the airplane too heavy. I'll see.
Your airfoil sounds like what I'm after.
Jim
Old Jul 27, 2011, 05:40 PM
Joined Jun 2003
The other thread HerkS mentioned is Airfoils Related to the S3021.
Jim
Old Jul 28, 2011, 01:52 PM
B for Bruce
BMatthews's Avatar
Joined Oct 2002
Originally Posted by JimHSoars View Post
...Your airfoil sounds like what I'm after.
Jim
Maybe yes, maybe no. In my case it worked out nicely for the size and speed I'm flying. But is it the best? Not by a long shot.
My point is that sometimes and for some cases "close enough" is good enough. Look at how many successful RC tainers have been built over the many decades of RC flying. Few of them use actual tested and charted airfoils. And those that do tossed out the wind tunnel validity by using open structures with lots of covering sag in most cases.
A good airfoil for a trainer is one that has a nice soft mushy stall so that it gives the pilot lots of warning before letting go. It should also have a quick build up of drag so that the model doesn't tend to speed up a lot in a short time when it goes into a dive. A quick speed build up for most students equates to the controls becomeing extremely sensitive from the speed. And with that added sensitivity comes the likelyhood of overcontrol and a rather nasty recovery or even total disorientation due to the rapid response "yanking" the model's perspective out of the mind's eye of the student pilot.
This is likely why the most successful RC trainers have typically had some of the oddest looking and inefficient, by normal standards, airfoils of any type of model used in RC flying. Examples of this include the Carl Goldberg Eagle from many years back and the ever popular Telemaster and Senior Telemaster. These all used what I like to call "Florsheim" airfoils since they used a flat bottom with a top shape that looks like it came from tracing the outsole of the designers shoe.... Yet the needs of a good trainer turn the failings of such airfoils into desireable features.
Anyhow, it's some food for thought to further complicate your airfoil selection..
Old Aug 09, 2011, 06:11 PM
D Chapman is offline
Find More Posts by D Chapman
Joined Sep 2008
Bruce I would be interested in checking out you're airfoil
if you're still interested in posting a DXF file.
Dale.
D Chapman is offline Find More Posts by D Chapman
Old Aug 22, 2015, 02:03 AM
Spike Webb is offline
Find More Posts by Spike Webb
Joined Sep 2014
I realize this thread is old, but if anyone comes across it looking for info,
i'm using the gottengen 398, and it has great characteristics for electric powered flight of long duration, (4+ hrs electric flight no thermals)with gentle stall and does not build speed too quickly. it's nice and thick, and glides better than it should. i love it, and it's simple to build.
Spike Webb is offline Find More Posts by Spike Webb
Question Airfoil Ideal Angle of Attack Chuck Clemans Modeling Science 28 Jan 04, 2016 11:40 AM
Discussion Higher Angle Of Attack Symmetric airfoil vs. High Camber airfoil wing z-matrix Modeling Science 30 Sep 05, 2011 07:03 AM
Discussion Question on the attack angle for LIFT? sherlockshah Foamy EDFs 29 Apr 16, 2010 12:47 PM
Discussion Questions on angle of attack, airfoils etc... GreenAce92 Sailplane Talk 9 Jul 31, 2009 07:52 AM
Discussion Lift vs Lift Coefficient Calculations cad2blender Modeling Science 2 Feb 18, 2008 11:20 PM
