Multistar High Capacity LiPo Batteries
Ultra high capacity LiPo batteries designed specifically for multi-rotor use.
Increase flight time without adding weight
Hobbyking's newest line of Turnigy batteries promises extended flight time with little to no increase in weight vs. the same mAh pack of a different brand. The Multistar line of LiPo batteries allow for an increase in the fuel tank by reducing the discharge rate; a 4s 4000mAh pack has a constant discharge rate of 10a and a burst rate of 20a. These reduced rates can be attained on multirotor platforms, making the Multistar LiPo's a suitable choice.
Hobbyking is claiming increased flight times up to 20%. The packs come prewired with XT60 connectors.
The Multistar high-capacity LiPo's are currently available in:
  • 4s 4000 mAh
  • 3s 4000 mAh
  • 3s 5200 mAh
  • 4s 5200 mAh
CLICK HERE for more info on Turnigy's Multistar LiPos
Features:
  • Ultra high capacity LiPo batteries designed specifically for multi-rotor use
  • Similar size/weight as batteries of much lower capacity, making these a direct drop-in upgrade for most multi-rotor aircraft
  • Provides increased flight times of up to 20% or more when compared to standard LiPo batteries of the same weight
  • Ideal for use with aerial video and FPV multi-rotor aircraft
Old Jul 16, 2014, 08:57 AM
Joined Apr 2014
Will these be in the US warehouse any time soon?
Pippy is offline Find More Posts by Pippy
Old Jul 16, 2014, 09:10 AM
RCGroups Editor
Matt Gunn's Avatar
United States, OH, Parma
Joined Jul 2009
Usually it takes a few weeks or a month for new products to reach the US warehouse.
Matt Gunn is online now Find More Posts by Matt Gunn
Old Jul 16, 2014, 10:17 AM
Empire Hobby Support Team
Joined Jan 2014
Yeah. At least...
Empire Support 5 is offline Find More Posts by Empire Support 5
Old Jul 16, 2014, 04:49 PM
United Kingdom, England, Herefordshire
Joined Oct 2012
Hey you got it very wrong, it's 10C (not A).. A 10C on 4000mah is 40A discharge, and 20C burst is 80A.. So that's not actually too bad! Make sure you read product page properly haha! better luck next time
geebles is offline Find More Posts by geebles
Old Jul 16, 2014, 05:14 PM
Certified Power Juicer
Jack_LaLanne's Avatar
Germany, Berlin
Joined Feb 2009
looking forward to reported actual weights of the packs
Jack_LaLanne is offline Find More Posts by Jack_LaLanne
Latest blog entry: FlyFly Hobby ASW28
Old Jul 16, 2014, 05:29 PM
RCGroups Editor
Matt Gunn's Avatar
Joined Jul 2009
Yea, mistake on my part. It happens.
Old Jul 17, 2014, 01:25 AM
Georgia
Joined Jun 2007
10C Lipos
Nothing new! A 10C lipo should be lighter than a 25C lipo!
The only advantage I can see is a slight weight reduction, unless there is also a reduction in price.
The run longer bit is misleading.
chuck75 is offline Find More Posts by chuck75
Old Jul 17, 2014, 01:51 AM
Made in Austria's Avatar
United States, NV, Las Vegas
Joined Dec 2013
It all sound nice, but don't you get more punch and less voltage drop out of higher C rated lipo pack, especially in multi-rotors? You would think that this lower C rated lipo would run warmer than a higher C rated one, which means you get somewhat less lifetime, and probably some puffing out of this lipo. I know the 40 amps are enough for most multi-rotors, but I have noticed that a higher amp draw rating is easier on the battery even though it's heavier.
Made in Austria is online now Find More Posts by Made in Austria
Old Jul 17, 2014, 02:51 AM
Ground Pounder
Gharddog03's Avatar
United States, CA, Fresno
Joined Nov 2012
〰Interesting〰
Gharddog03 is online now Find More Posts by Gharddog03
Old Jul 19, 2014, 10:46 PM
Joined Apr 2014
Will either of the 3s fit in a phantom 1 bay
ECFPV is offline Find More Posts by ECFPV
Old Jul 25, 2014, 12:33 PM
Squawk's Avatar
The Netherlands
Joined Jan 2011
Ok, maybe I'm misinformed.. but 10Amps isn't enough for most multi rotors, right?!?
Even the Phantom consumes about 7.5A per ESC/Motor. That times 4 is 30 Amps.
How is a 10 Amps Lipo going to provide that?
Edit: Oh, I see now it's 10C, not 10Amp..
Never mind.
Too bad it's too big to fit the Phantom 2 shell though..
Squawk is offline Find More Posts by Squawk
Last edited by Squawk; Jul 25, 2014 at 12:38 PM. Reason: reply based on wrong info.
Old Jul 25, 2014, 12:50 PM
Germany, Berlin
Joined Feb 2009
so anybody got theirs yet ?
Old Jul 25, 2014, 12:51 PM
deno6031's Avatar
Turkey, Izmir
Joined Oct 2011
I am even puffing 30c 5000mah 4s lipos, how should they hold up??
deno6031 is offline Find More Posts by deno6031
Old Jul 25, 2014, 01:32 PM
OFF TOPIC POSTER
Des Moines IA
Joined Dec 2005
WOW
what is your setup and how many amps are you pulling?
eckace1 is online now Find More Posts by eckace1
Discussion LiPo Battery Capacity mitch208 Batteries and Chargers 6 Nov 18, 2013 03:47 AM
Help! Two lower capacity batteries, or one of higher capacity? mateusviccari Batteries and Chargers 1 Nov 10, 2013 03:51 AM
Discussion Newbie to LiPos: What capacity battery can I buy? jpegjames Batteries and Chargers 13 Oct 16, 2013 10:29 PM
Wanted Wanted: High Capacity/High C 4s lipo or TWO 2s GeetarJoe Aircraft - Electric - Batteries & Chargers (FS/W) 4 Feb 18, 2012 12:34 PM
