Old Sep 27, 2013, 11:49 PM
United States, LA, Houma
Joined Jun 2008
k marine dash 7009 11.5 inch racer
ive read a lot about this tiny micro....for $40 shipped.....hard to beat.
its hobby grade,everything is upgradable,370 brushed motor,9g servo.
this boat is advertised 20mph stock...youtube proven.
just had to have one.
once I received it....its tiny!
ive only pool tested this little bad boy....very impressed.
igotit is offline Find More Posts by igotit
Old Sep 28, 2013, 12:59 AM
Did you check the FAQ already?
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
Ah, another FT007's "sibling". This one is still MHz transmitter, right? Looking at the antenna. LRP sells this for a while under the name "Deep Blue One":
SoloProFan is offline Find More Posts by SoloProFan
Old Sep 28, 2013, 01:14 PM
Joined Jun 2008
yes the 7009 is still 49mhz,going to install 2.4 and lipos,brushless later on.
Old Sep 28, 2013, 02:27 PM
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
The MHz transmitter has one advantage. It works under water. With the FT007 when the boat dives under because it hits a wave for instance, signal is lost, as 2.4 GHz can't penetrate the water. As a result the receiver will memorize the last received command, which is probably full speed ahead, since that's what you do most with a speedboat. This can mean the boat will "play submarine" for seconds, as the motor is still turning, if signal is not restoring within a certain time, the motor will stop, and the boat will surface again. With a MHz type transmitter, which can control the boat under water, you can immediately stop the motor, and the boat will surface much faster, with less risk of it getting too much water inside, during the underwater trip.
Old Sep 28, 2013, 02:49 PM
Joined Jun 2008
that's good info to know about the different freq rx's
just had my first outdoor run.
beautiful weather,flat calm.
my range is about 40 ft,once I go past that range...boat shuts down.i have to walk closer to get the boat backin,motor will fluctuate rpms till im back within 40 ft.
its as fast as every other stock one,fun,agile.the stock rx /tx has got to go.
Old Sep 28, 2013, 02:58 PM
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
Shame the range is limited. But not unusual for cheap RTR stuff. The range with the 2.4 GHz system of the FT007 will be better, just expect the boat to stay under water for longer, if it decides to do a submarine imitation. I had mine even do some circles under the surface, as it happened in a turn.Was an odd sight, just like a strange fish.
Old Sep 28, 2013, 03:13 PM
Joined Jun 2008
I have a generic 2.4 ill install with a modern esc from my rc crawler for now.
my 2.4 receiver has a long antenna...maybe that will help....lol.
edit
ive installed my 24ghz rx/tx.....it has a failsafe feature,so when I loose signal the steering returns to center and throttle off.
also installed my axial esc f/n/r ,bench tested the boat.time to seal it up and go test ride.
while I was there I lubed the shaft,centered thesteering servo.
Old Sep 28, 2013, 05:46 PM
Joined Jun 2008
she works a lot better with the new gear installed....too bad I forgot to reinstall the screw for the water sensor ground.
this left a 1/16th open hole in the bottom of the hull.i noticed after 45 seconds of running she was getting slower and sittin a lower draft....lol.
so every 30-50 seconds she was 3/4 full of water.
still made a few good passť,rolled her once.shes not self righting at all.
tested range out to about 150 ft....no issues.
handling...I don't like the way she banks hard on turns,ill see what I can do about that,maybe some stabilizer fins.
Old Sep 28, 2013, 08:10 PM
Amp Abuser's Avatar
Joined Dec 2007
Looks like a good place to run an air boat
Amp Abuser is online now Find More Posts by Amp Abuser
Old Sep 28, 2013, 08:29 PM
Joined Jun 2008
that was the cleanest spot I found locally...lol.
the bayous are clogged with vegetation this time of year.
Old Sep 29, 2013, 01:14 AM
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
New gear seems a little heavy, you could get just the "brick" from the FT007 and bind it with a GT-2 or other Fly Sky compatible transmitter.
When trying to self right, you do first go into reverse, and then directly in full forward? At first I tried self righting with just giving full forward, but that won't work.
Old Sep 29, 2013, 08:58 AM
United Kingdom, England, Weston-super-Mare
Joined Jan 2004
I have the 'Fast Wave F1' variant of this little boat and the self righting works really well, as has already been said, reverse first. It may also be that the new gear that you have put in has affected the centre of gravity and weight therefore making it impossible to self right.
I can't wait to get the 2030 4200kv brushless in mine!
Livefast123 is offline Find More Posts by Livefast123
Old Sep 29, 2013, 10:26 AM
United States, TX, Leander
Joined Jun 2005
I have this same thought about my FT007.
AustinWolv is offline Find More Posts by AustinWolv
Old Sep 29, 2013, 12:23 PM
Joined Jun 2008
I only tried forward to self right....ill tr the reverse,then snap into forward method.
the gear I installed is pretty lite.
im happy with its current speed,not looking for faster.
Old Sep 29, 2013, 01:19 PM
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
Just forward won't work. I've been there as well, wondering and wondering at first with my Revell Tide Breaker (FT007 rebrand) why I could not get the boat to self right... Then I learned that I had to reverse first, then forward, to get the boat to swing around back up. Since then I have 100% succes in self-righting.
For Sale K&B 3.5 cc marine engine habcores Boats (FS/W) 0 Sep 17, 2013 09:33 AM
Sold ... cherokeenut Aircraft - Fuel - Engines and Accessories (FS/W) 0 Aug 05, 2013 04:17 PM
Sold 11.5 inch Graupner E-Prop set (2 CW/2 CCW) vcazan Aircraft - Electric - Multirotor (FS/W) 0 Apr 22, 2013 06:52 PM
Discussion 9.5 inch wingspan Dash 8-100 Joe Malinchak Scratchbuilt Indoor and Micro Models 8 Aug 27, 2012 01:09 AM
