Old Aug 22, 2015, 05:27 PM
Toodle is offline
Find More Posts by Toodle
Joined Aug 2014
Zipper wing wagging problem
I have, what looks like, an original Goldberg Zipper with an Astroflight 05 geared electric motor. The problem is that the wings wag (oscillation about the roll axis) with a period of two to three seconds, which is annoying. The balance is about right (6" back from the LE and it glides very nicely with a little down elevator) Any ideas on how to stop the wagging?
Toodle is offline Find More Posts by Toodle
Old Aug 22, 2015, 11:48 PM
mlbco is offline
Find More Posts by mlbco
Palo Alto, California, United States
Joined Jan 2003
Sounds like a poorly damped dutch roll mode. Increase the size of the fixed vertical stabilizer and it will stop oscillating.
Steve
mlbco is offline Find More Posts by mlbco
Old Aug 23, 2015, 04:24 AM
Sundancer is offline
Find More Posts by Sundancer
I like real wooden aeroplanes!
Sundancer's Avatar
South-west France
Joined Sep 2007
Yes, sounds like dutch rolling. If the model has the original dihedral (i.e. as a free-flight model) then some designs, when flown under radio, do demonstrate this characteristic, in these case an increase in vertical tail surface area can help. I note that you say that the glide trim needs some down elevator; if you re-trim so that the glide is right with neutral elevator by moving the CG forward, you might find that also reduces the dutch rolling.
Sundancer is offline Find More Posts by Sundancer
Old Aug 23, 2015, 10:36 AM
Bobimp is offline
Find More Posts by Bobimp
Joined Sep 2006
A classic case of Dutch rolling! Lots of these vintage polyhedral models do this, and the suggestions made will go some way to curing it. Let`s not forget that most if not all of these vintage type models were designed for free flight with maximum endurance, and some don`t take kindly to having their normal flight path interfered with! It`s the price worth paying for the elegance of these models in the air!
Bobimp is offline Find More Posts by Bobimp
Old Aug 23, 2015, 11:18 AM
Sundancer's Avatar
South-west France
Joined Sep 2007
And, of course, I forgot to say - keep the rudder movement down and have some exponential. The secret is to fly them with very gentle rudder inputs to avoid the rocking starting up in the first place.
Old Aug 23, 2015, 11:30 PM
Geoff Potter is online now
Find More Posts by Geoff Potter
Joined Sep 2011
Had a Mcoy 60 in mine ,Dutch rolled all over the country first few flights ,couldn't keep up with it and had to shutoff after about 5 secs engine run . My friend Lionel said to put in more washout in the outer panels ,instant fix . Beautiful aeroplane , just to hard to build as against a Playboy . Will build another one day. .
Geoff Potter is online now Find More Posts by Geoff Potter
Old Aug 24, 2015, 12:18 AM
mlbco is offline
Joined Jan 2003
Geoff,
This probably worked because it unloaded the wingtips where dihedral was the largest resulting in less effective dihedral for the entire wing. Reducing dihedral or increasing fin area are the 2 major factors in stabilizing the dutch roll oscillation.
Steve
Old Aug 24, 2015, 03:28 AM
Joined Sep 2011
Yes Steve, it most definitely did work like that . That is the only option available. Out here in Aus we are not allowed to deviate from the plan ,ie ,fin ,diaheadral alterations . So one has to make the model fly as it should ,looking like it should ,and built like it should be .
Old Aug 24, 2015, 04:22 AM
Sundancer's Avatar
South-west France
Joined Sep 2007
I must say I hadn't thought about adding washout to the tips, but it makes sense. A good fix where rules prohibit reduction in dihedral or increase in fin area, or for an already completed model where these changes would be hard to implement
Old Today, 04:14 PM
Toodle is offline
Joined Aug 2014
First, I want to thank all of you who have taken the time to respond with helpful suggestions. I tried to put in some washout with a heat gun, but the old covering is so brittle that it won't hold a preset. So, at the suggestion of Jerry P. (a real pro and nice guy), I added the TE thickeners shown below to achieve some washout.
With the thickeners, Jerry's tutoring, and a soft touch on the rudder, the plane flies OK now. Thanks again!
Old Today, 07:52 PM
gerryndennis is online now
Find More Posts by gerryndennis
New Zealand, Canterbury, Christchurch
Joined Jun 2008
I'm glad you got it sorted out Toodle,
I was talking to a mate of mine the other night. He has a large Zipper with an OS 91 surpass.
He has it trimmed for the climb and let's it fly free flight style, spiralling up to altitude. There's no way he can touch the controls during the climb, but it's fine in the glide which confirms what others have said and what you've found.
He uses the model for competition work so it's fine like that, not so good for a sports model though.
Cheers,
Dave H
gerryndennis is online now Find More Posts by gerryndennis
Sold Wing Warrior Zipper NIB quartercase Aircraft - Sailplanes (FS/W) 3 May 27, 2015 01:08 AM
Sold Wing Warrior Zipper 36" EPP flying wing. MicroRotors Aircraft - Sailplanes (FS/W) 5 Oct 16, 2014 01:46 PM
Sold Repost-Zipper flying wing llamame1950 Aircraft - Sailplanes (FS/W) 0 Apr 12, 2014 09:06 AM
For Sale Zipper Flying Wing llamame1950 Aircraft - Sailplanes (FS/W) 3 Mar 08, 2014 10:11 AM
Question Wing Wag-wag-wag mando Flying Wings 14 May 17, 2005 09:24 AM
