Old Feb 19, 2015, 08:56 AM
Westwind76's Avatar
Canada, ON, Sault Ste. Marie
Joined Feb 2013
Back up battery
Looking for a way to wire a second battery into the first allowing the second to charge the first at about 1C while the first battery is used to power the motor. Thinking of using a small bec to provide the link between batteries but I don't know if a bec will allow power to flow in only one direction.
Can anyone she's some light on the issue?
Westwind76 is offline Find More Posts by Westwind76
Old Feb 19, 2015, 10:37 AM
Staffs, UK
Joined Nov 2003
If you have two batteries why not just wire them in parallel so the power is shared by them ?
Basically it's not possible to charge a battery while at the same time discharging it. All that happens is the "charging" current goes to the load and the "main" battery is discharged at a slightly lower rate.
Steve
slipstick is offline Find More Posts by slipstick
Old Feb 19, 2015, 03:04 PM
Bombs away! Err...landing
Ira NZ's Avatar
Upper Hutt, New Zealand
Joined Apr 2006
Steve
Yeah, to charge the first battery at 1C you'd have to have the second supplying the full draw+1C. No point if you're just using a pair of batteries. Now, something like a small gasoline generator or other relatively exotic setup where you're using the battery as more of a buffer...That might work. But complicated.
Ira NZ is offline Find More Posts by Ira NZ
Old Feb 19, 2015, 04:08 PM
vollrathd's Avatar
Joined Jan 2007
Application?
Out of curiosity, what is your application?
vollrathd is offline Find More Posts by vollrathd
Help! battery voltage drops quickly then jumps back up colliams Batteries and Chargers 15 Mar 07, 2014 12:48 PM
Discussion Battery Backer - second battery back-up solentlife Batteries and Chargers 9 Dec 31, 2010 08:22 AM
Sold Battery Back Up System - New Steve_O Aircraft - General - Radio Equipment (FS/W) 2 Aug 24, 2008 02:32 PM
Help! Battery Back-up! ToniGe23 Scale Sailplanes 2 Mar 12, 2008 09:20 AM
Discussion This car battery rechargable back up starter say alkiline sealed any.. treehog Batteries and Chargers 0 Oct 20, 2006 09:45 AM
