Old Mar 02, 2015, 04:51 PM
Joined Feb 2015
Got a TW today..haven't looked at it yet. Is there consensus on parts to replace out of the box ? Thanks.
highndry1 is offline Find More Posts by highndry1
Old Mar 02, 2015, 05:03 PM
HuskyDude's Avatar
Canada, BC, Kamloops
Joined Jan 2011
Yes...
You should do some back reading. Lots of good things to learn on here.Everyone is very helpful.
Oh and congrats on your TW.
HuskyDude is offline Find More Posts by HuskyDude
Old Mar 02, 2015, 05:12 PM
Clive66's Avatar
United States, CA, Fontana
Joined May 2011
You are better off just looking back thru the posts here & decide what looks like the modifications that make the most sense to you.
Re-hashing what has already been said wont help much.
The bigest problems have been the vibration issue & the ESC heat.
Clive66 is offline Find More Posts by Clive66
Old Mar 02, 2015, 05:16 PM
Prop-Snapping Excitement!
RexGalore's Avatar
United States, CT, Hartford
Joined Feb 2014
Page 54...
RexGalore is offline Find More Posts by RexGalore
Old Mar 02, 2015, 06:10 PM
eagleflyer
Joined Dec 2014
Spare Tidewater electric motor
Can anyone recommend a HK motor which can be a spare?
The lake where I am flying is a long way from a LHS, hence the need for a spare, just in case.
In earlier entries on this blog (#s 310, 311, 313) there was a picture of a red motor which was purchased as a spare, but it had a shaft size of 3.17mm or 1/8 inch. The existing motor that is on my Tidewater has a shaft size of 3 mm. It fits perfectly with the 3 mm e-flite prop adapter.
Also the mount that was shown with the red motor was a X mount while the one needed to fit the existing mount is three legged.
The specs for the motor are shown in various places but seem to be
28-17-1250kV (see flyzone.com parts listing FLZA6332) as well as 28-30-1300kV (see Tidewater Instruction Manual).
In Canada we are now paying 25% more for items in $US so I was hoping to find a HK substitute (free shipping too).
Has anyone had any luck in finding a suitable outrunner which has the correct shaft size and is adaptable for mounting without major surgery?
Barry Smythe is offline Find More Posts by Barry Smythe
Old Yesterday, 09:21 PM
Gravity is weak but persistant
Charlie P (NY)'s Avatar
United States, NY, Port Crane
Joined Aug 2009
Originally Posted by Barry Smythe View Post
I wish there was a way to start my DX6i timer when I first move the throttle. Cannot afford to go to a DX6.
I have made a little pre-flight routine that works to remine me. On my DX61 I have the timer on the throttle cut button. I also have a mechanical throttle "lock". A long rubber band looped over the carry handle & around under the front that is just tight enough to hold the throttle down. I do this because we fly a lot of seaplanes off a dock, and in handling the plane and transmitter (on a neck strap) there have been some painful bumps of the throttle.
When I remove the band I press the timer button. Works pretty well.
Charlie P (NY) is offline Find More Posts by Charlie P (NY)
Sold Flyzone Beaver, Flyzone C350 Corcalis, TH P-51 JimVanLoo Aircraft - Electric - Airplanes (FS/W) 0 Jan 08, 2013 02:15 PM
For Sale Anyone in the tidewater VB area interested in a slightly crashed E-flight Edge 540. Speedfreak Aircraft - Electric - Airplanes (FS/W) 1 May 12, 2006 03:13 PM
For Sale Tidewater Pronto jimmycashley Aircraft - Electric - Airplanes (FS/W) 3 Jan 15, 2006 05:45 AM
Discussion "Hardy Souls" contest, January 1, Tidewater, VA. D_Ryan Thermal 2 Dec 28, 2005 07:35 PM
Discussion "Hardy Souls" contest, January 1, Tidewater, VA. D_Ryan Sailplane Talk 1 Dec 28, 2005 11:30 AM
