Old Dec 13, 2014, 09:56 AM
iqon's Avatar
United Kingdom, England, Doncaster
Joined Jan 2013
thats shocking, did you order anything else and was it loose inside big box.
iqon is offline Find More Posts by iqon
Old Dec 16, 2014, 09:26 AM
hot wings's Avatar
Joined Jul 2010
......the fuselage seems to be damaged after been tramped on...
hot wings is offline Find More Posts by hot wings
Old Dec 22, 2014, 06:30 PM
wibing's Avatar
Australia, ACT, Flynn
Joined May 2013
Originally Posted by hot wings View Post
Mine has arrived today...bad bad surprise...
the fuselage is broken is several parts......also canopy has several cracks and defects..
Oh no. That's no good at all.
I've just build my Airoso and it is a PITA to build. Had parts missing and nothing fitted at all. It was definitely one of the most painful builds I've done to date.
On the other hand, I've had my maiden over the weekend and it is a beautiful plane once in the air. Good luck on the build!
wibing is offline Find More Posts by wibing
Old Dec 24, 2014, 06:52 AM
hot wings's Avatar
Joined Jul 2010
Guys,
my experience with the Airoso has ended here.
I sent it back to HK.
Good luck with this pattern plane.
Cheers
John
Old Dec 24, 2014, 05:27 PM
United Kingdom, England, Chippenham
Joined Apr 2014
Hello all in the Airoso thread. Luckily mine arrived undamaged from the UK warehouse, although I have the feeling the box has been opened and rummaged around in. The box opening felt a bit second hand if you know what I mean.
I went for this mix of gear:
Turnigy Brushless ESC 85A w/ 5A SBEC
NTM Prop Drive 50-50 580KV / 2000W
Turnigy Digital High Torque Ballraced Servo 26g/3.5kg/.12sec
Servos seem to be a very nice fit. Motor looks a little small for the size of plane but previous posters have said it's ok. I think I'll be running 3 cells in parallel as I have a poor track record in looking after batteries, and the 6 cells are too pricey to ruin!
Overall I'm quite impressed, it's my first balsa model for many years and it seems pretty good.
Has anybody felt the need to beef up the motor mount?
Bedrock
Bedrock_66 is offline Find More Posts by Bedrock_66
Old Dec 24, 2014, 06:49 PM
iqon's Avatar
Joined Jan 2013
put supplied triangle at top and bottom, and additional cyno you wont need to take the front off again.
Old Jan 25, 2015, 05:30 PM
Joined Apr 2014
Anybody have tips on applying the transfers? I'm assuming they are waterslide type - is that correct?
Old Jan 25, 2015, 07:09 PM
iqon's Avatar
Joined Jan 2013
I just cut them out and stuck them on, have never tried with water.
Old Feb 05, 2015, 10:43 PM
wibing's Avatar
Joined May 2013
Hi Bedrock,
Do you mean 3 cells in series? 3S for that motor seems to be way underpowered.
I have the same setup and am running 6 cells on a 14x10 prop.
Old Feb 09, 2015, 06:03 AM
Morocco, Grand Casablanca, Mohammedia
Joined Jan 2012
Guys,
Make sure you beef up the U/C on this plane. Mine crapped out after the first couple of flights, including pretty smooth landings. The aluminum gear is way too soft. Bought a carbon fiber set for the plane but have not yet fitted it. My motor was an NTM 4248-650 with an 12x8 3 blade prop. Combo on 5S 4000mAh LIPO works really well, plenty of power and Harrier like takeoff 'leaps'.
Flies like a charm and does most all of the old F3A routines perfectly. Lands smooth as silk, but does not like rough fields - see U/C above.
Good luck.
Peter
RCTurbine is offline Find More Posts by RCTurbine
Old Feb 09, 2015, 09:36 AM
"Get off the runway!"
Da Big_G's Avatar
United States, TX, Hutto
Joined May 2012
Hobbyking east warehouse has the Airoso on sale for $116. I bought 2. There are 2 left. Don't trample when leaving... .
Da Big_G is offline Find More Posts by Da Big_G
Old Feb 18, 2015, 06:51 AM
wibing's Avatar
Joined May 2013
This is the landing that I'm using with the Airoso. Thanks Pindro for the recommendation. It fits exactly, really rigid and is a good height.
http://hobbyking.com/hobbyking/store..._90_size_.html
Old Feb 28, 2015, 07:10 AM
Joined Apr 2014
thanks for tip
shame I'm too late as it's out of stock...grrr
Old Mar 02, 2015, 03:40 PM
horja's Avatar
Romania /Bucarest
Joined Dec 2007
Airoso completely desapointed
I received my Airoso it is not long a go.
Completely desapointed.
Quality it's ....A lot of area not glued ...... Wing tube way to big.......balsa soft and low quality and...... so on
Sorry to say but .....
I also order servos Corona DS238MG after reading here about.
The servos were ok but unusable because faulty arms way too large to porper fit.
So .... take care
horja is offline Find More Posts by horja
Old Mar 02, 2015, 06:03 PM
Joined Dec 2012
Garbage in, Garbage out! I told you HK like all of the rest consider the USA a "dumping ground" for THEIR JUNK!
TN Walker is offline Find More Posts by TN Walker
Help! Hobby King Shipping Damage Fiasco... Demon 6 HobbyKing 21 Jan 16, 2013 08:54 PM
Help! Can anyone Help Me out? Hobby King Fiasco Demon 6 HobbyKing 55 Jan 12, 2013 08:19 PM
Discussion Hobby King P31 HobbyKing 7 Jan 04, 2013 07:32 PM
Sold Hobby King Multi-battery charging adapter for UMX-type batteries K_B Aircraft - Electric - Batteries & Chargers (FS/W) 1 Jan 03, 2013 08:02 AM
