LISF Bird of Time One Design Build Thread
Long Island Silent Flyers (LISF) is hosting a one design group build and contest. LISF has done this before, with great success, when we built the Bubble Dancer and now we're doing it again with the Bird Of Time.
We're just getting started on the group build of the Bird Of Time (BOT), taking our time and helping each other to bring as many models to completion as possible over the winter. Some members are finishing BOT models they've been working on, or starting a major overhaul, or ordering BOT kits or contemplating purchasing the ARF version of the BOT. No one is building from plans, yet, but we do have one member building a new wing from scratch. The point is we aren't setting a blistering pace. You have time to look around, think about it and then join us. Even if you don't enter the contest, we encourage you to participate: follow the thread, build along with us and have fun. LISF flies out of Stillwell Woods Park in Syosset, Nassau County, Long Island, New York. We are throwing the build and contest open to surrounding clubs. You don't have to be a member to participate. This is our Bird Of Time build thread. Expect to see a lot of information, photos and discussion right here. Here is a link to our discussion thread (updated 07-15-2011): One Design - Bird Of Time Group Discussion. This is the 100 foot view for the group build and contest. It contains a lot of information and the rules for building if you want to enter the contest. Check it out. Here is a link to our club's webpage: LISF Home Page. Most definitely check it out. We have a diverse group of enthusiasts with interests in all types of sailplanes and gliders. Twenty people are currently in the LISF Bird of Time One Design Build. We expect eight of them, and others, will be in the One Design Contest, too. Update: Check out the One Design Contest photos on page 49 of this thread. |
Will this be an AMA sanctioned event? you are opening it up to non club members. If you need a CD, I might be able to help if no one else is willing.
Will there be a fee for participating in the contest? will we be securing a date with the county (and all that goes with that) for the field? What date do you have for it? When the kit was purchased by the current owners, it was changed, I think to a 108" wing.. These initial changes were not well received. They made additional changes and extended it to 118" and supposedly simplified it a bit. Not sure of all of this but when I got my kit, this is what was told to me. |
Will there be a list of allowed changes? In the example of a not approved changes on the LISF forums, it lists the wing addec carbon and fiberglass. Is that allowed? Is the composite fuse the reason it is not allowed?
For example, can I remove plywood and use carbon instead? Can I change the shape of the fuse or must it be either the narrow or box style fuse listed in the plans? Can I lengthen the nose since newer equipment is lighter to offset the weight a bit? I have one of these Dynaflight kits but do not know if I'll get around to building it. Frank |
Los Angeles, CA
Joined Jun 2004
118 was the original size. Thornburg acknowledges this in an early article/review of the Dynaflite kit. 108 was/is a misprint seen in the Dynaflite kit.
Alternatively, and along with- prior to kitting/plans finalisation, there were apparently many versions built by Thornburg, and there may be misunderstandings from that. |
LI, New York, USA
Joined Mar 2003
This is Trevor's project, I am just helping out, but since the answeres to your questions are easy, I will jump in.
As for CD - has not been discussed but since this has been Trevor's idea, I would suggest Trevor for the job. I have been assisting him so he can count on me for that too. But I am sure he can use help. Has not been discussed, but probably not. This will be a typical club type contest. Both LISF and the Merokes have the required Nassau County Permits. If this spans outside these clubs we may have to look at a fee to cover the cost of permits for the field. Quote:
Date has not been set yet. Quote:
I am updating my coments here: This was published in the WE flying report and the LISF Forums. All the details are there. The link is in the first post and in the WE Flying report. But here it is again. http://www.lisfsoar.proboards.com/in...lay&thread=103 Rules of the OD contest build were changed 11/2 http://www.rcgroups.com/forums/showp...9&postcount=31 * OK for plans, kit or ARF build * OK for 108" nostalgia version or 118" current version * OK for carbon on the spar * OK to add spoilers, but they must be disabled for the OD contest * OK to fiberglass the kit fuselage and finish it as you please * OK to use either screws or rubber bands to hold down the wings * OK to choose your own electronics and layout * Decorate as you like Other mod allowances were added 11/2 * No skegs will be allowed in the contest (you won’t need one) See updated rules Quote:
Now you have motivation to get it built. |
At CRRC , they have an article on the BOT
http://www.charlesriverrc.org/articl...naflitebot.htm |
We have the link to the article listed under Reviews rather than under Build Threads, so it may not have jumped out at you. It's a good article: lots of detail. |
| Thread Tools | |
| Discussion Bird of time stabilizer? | jimgodsman | Electric Sailplanes | 4 | Oct 23, 2010 02:40 AM |
| Wanted Bird of Time narrow wood fuse. | jedear | Aircraft - Sailplanes (FS/W) | 1 | Oct 17, 2010 08:25 PM |
| 236" Bird of Time - design questions | AndersHoberg | Thermal | 22 | May 04, 2007 10:23 PM |
| Bird of Time ...One more Time | solo6796 | Thermal | 247 | Feb 18, 2005 12:17 PM |
