Old Jul 23, 2015, 06:02 PM
kiwi_craig is offline
Find More Posts by kiwi_craig
Slideways at warp speed.......
kiwi_craig's Avatar
New Zealand, Auckland
Joined Mar 2014
add the 913 tail blade for allot more tail authority, trim to get neutral hold
kiwi_craig is offline Find More Posts by kiwi_craig
Latest blog entry: V930 CF driveshaft
Old Jul 23, 2015, 06:19 PM
OrangeBird is online now
Find More Posts by OrangeBird
Wow, the sky is clear
OrangeBird's Avatar
Canada, QC, Chicoutimi
Joined Aug 2012
Originally Posted by jakeaheli View Post
Im going to have to order a couple from BG this time.
Is it possible to fit a brushless motor there without changing the PCB? Or a better motor/ tail setup perhaps?
Jake
Hi jakeaheli
If you prefer a Walkera tail assembly, view photos #10 -11 -12 - 13 by remlen
See photos
Also :
Walkera Master CP parts
Also :
Walkera brushless, how to install
http://www.xtreme-production.com/xtr...oducts_id=1546
For V912 add brushed to brushless signal converter
1 - add Brushless Converter
2 - add Brushless ESC
3 - add Brushless Motor
OrangeBird is online now Find More Posts by OrangeBird
Old Jul 24, 2015, 12:33 PM
OrangeBird's Avatar
Joined Aug 2012
Hi Guys
Is anyone among you test this converter: brushed to brushless converter ?
I ordered one to try it........( 07-27-15 )
Old Jul 25, 2015, 09:21 AM
Brian MG is offline
Find More Posts by Brian MG
Joined Jul 2015
New guy that needs a little help
Have been following this board for a few weeks. You guys provide some great tips and mods for the v912. thanks
I have the v912 brushless and yesterday was out flying and crashed it nose first into the ground. Noticed at first flybar was bent but got it straight. Looked over it and everything seemed ok. Turned off and back on went to throttle up and the motor seemed to be working fine but it wouldn't lift off the ground. I gave it full throttle and the motor was going like crazy but know lift. Would the motor be the problem or maybe pcb board?
Brian MG is offline Find More Posts by Brian MG
Old Jul 25, 2015, 09:49 AM
OrangeBird's Avatar
Joined Aug 2012
Hi Brian MG
From your description, I would change the motor first, and if the problem is not resolved, it would be the PCB.......
Old Jul 25, 2015, 10:15 AM
JW57RC is online now
Find More Posts by JW57RC
Fueled by coffee & LiPo
JW57RC's Avatar
United States, FL, Venice
Joined Apr 2014
Could you tell be the sound if the main rotor was going the "normal" speed?
If you can't tell, then after a significant crash, you might have any number of problems. The V912 is big enough to visually inspect for most problems. This list is a portion of my normal pre-flight for every session:
1. Check the teeth on the main gear. If there are any damaged teeth, replace the gear.
2. Closely examine your blade linkage. If one of the dogbone connectors is broken, stuck or missing you don't WANT to get it in the air!
3. Is the main shaft damaged or are any connections loose?
4. Examine the blades for nicks or cuts, or any bends. Do they move on the pivots correctly? Are either out of "normal" alignment?
5. Take a good look from the tail looking straight forward. The tail boom should be exactly straight and should be exactly in line with the main rotor shaft. While there look for damage, dirt or misaligned tail motor mount or blade.
It is still possible that you have a bad motor or PCB, particularly if the motor ran after the crash (did you engage throttle hold before hitting the ground?).
I hope the damage isn't too bad. Let us know what you find.
JW57RC is online now Find More Posts by JW57RC
Old Jul 25, 2015, 10:25 AM
OrangeBird's Avatar
Joined Aug 2012
Hi JW57RC
Yes, good verification ........
I will add in my blog....( section # 9 )
By....
Old Jul 25, 2015, 10:44 AM
Brian MG is offline
Joined Jul 2015
I turned the throttle off just as it hit. I did notice the servos seem to work fine one minute then maybe not the next. I did look over it numerous times and did not see anything wrong that you listed above,
Old Jul 25, 2015, 05:12 PM
TomHardcastle is offline
Find More Posts by TomHardcastle
Joined Jan 2013
Hi All,
I ordered the aluminium head for my V913 but the company I ordered it from sent me the one for the V912. I have just added it to ebay (UK buyers Only) i anyone is interested:
http://www.ebay.co.uk/itm/3016965786...84.m1586.l2649
TomHardcastle is offline Find More Posts by TomHardcastle
Old Jul 28, 2015, 03:06 PM
jakeaheli is offline
Find More Posts by jakeaheli
jakeaheli's Avatar
Joined Feb 2015
Originally Posted by OrangeBird View Post
Hi jakeaheli
See photos
Also :
Also :
Hi Orangebird,
Thanks for the suggestion. Is there someone who has already modded their V912 with the Walkera tail setup??
I want to know just to make sure i take that route and if its really worth the trouble. Any videos??
Jake
jakeaheli is offline Find More Posts by jakeaheli
Old Jul 28, 2015, 03:09 PM
jakeaheli's Avatar
Joined Feb 2015
Just a thought is it worth learning how to fly CP on a Walkera Master CP or still go with the V977?
I've been looking to find a decent beginner CP heli - something not that tiny, cheap to repair and tough.
Jake
Mini-Review WLtoys V922 6-Channel CP Flybarless Helicopter Mini-Review FyreSG Micro Helis 8314 Jul 08, 2015 07:18 AM
Discussion WLToys V912/NEX helicopter jameschen072 Micro Helis 41 Jan 27, 2015 10:17 AM
Mini-Review The Walkera SUPER FP review (4 Channel Flybarless fixed pitch helicopter) jameschen072 Micro Helis 471 Mar 14, 2014 10:28 AM
Sold Two (2) Nine Eagles Solo Pro V 4-Channel Fixed Pitch 45 Flybar Coaxial RTF Helis ShaneXman Aircraft - Electric - Helis (FS/W) 4 Mar 09, 2012 10:23 AM
