Old Jul 27, 2015, 09:57 PM
Hondajet is offline
Find More Posts by Hondajet
" Plain Crazy! "
Hondajet's Avatar
Australia, WA, Joondalup
Joined Oct 2008
Originally Posted by oscarmok View Post
Am still having binding issues with the left gear.
Have no issues when out of mount yet when mounted with pitch mod it locks up. Have carved a amount of foam to free up along with screw tension. Any help would be great as to what else to try.
It has to be a physical issue then oscar.... if it only just does not work mounted in your modified Gear Well for the angle rake forward.
You will have to work backwards once it is mounted taking it out bit by bit, by moving it upwards with the screws loosened gradually in stages until it works.... then find out what physical change in position caused it to work by relieving the pressure off it somewhere .
Also, if your depth of the wheel well is so that the whole wheel is hitting the top of it before the retraction cycle finishes....thus causing the gear mechanism of the motor and jackscrew to screech a little and place stress on it by not contacting the micro switch, and relying only on the circuitry timer inside to stop the motor cycle..... that also might be your problem?
Hondajet is offline Find More Posts by Hondajet
Old Yesterday, 02:27 AM
jiggz is offline
Find More Posts by jiggz
"its not a hobby its obsession
jiggz's Avatar
United Kingdom, Meopham
Joined Jul 2014
If the retract wheel is hitting the well and is missing the micro switch con tact and relying on it cutting out this could prove fatal in flight ...I have had total power outs where the gear stalls on retraction and the surge relieved the RX of its needed amps causing the RX to just power out ..what comes next in that situation I'm sure everyone can imagine ..a plastic bag is generally needed to carry the bits home
jiggz is offline Find More Posts by jiggz
Discussion wanted taiyo zero a6m zeke a6m5c mitsubishi thingy alsaplenty Parkflyers 2 Apr 15, 2009 01:26 PM
Looking for Mitsubishi A6M Zero 3-Views KSU Flyer Scale Kit/Scratch Built 5 Jul 18, 2008 09:50 PM
Discussion My 8" Mitsubishi A6M Zero gguy Scratchbuilt Indoor and Micro Models 19 Nov 14, 2007 01:08 PM
Mitsubishi A6M Zero JetTech Parkflyers 6 Nov 01, 2004 09:53 AM
