Old May 12, 2015, 06:52 PM
ToastLover is offline
Find More Posts by ToastLover
ToastLover's Avatar
Germany, BY
Joined Feb 2015
Identifying an SMD part on a Vtx
Hi,
A few months ago I crashed with my FPV wing into the snow and since then I only got a fraction of the range I had before.
I compared the video transmitter (ImmersionRC 600mW) to my other one and found that one smd part near the antenna output looked damaged.
So I'd like to switch it out to see if that's the fault.
Name: 2015-05-12 18.09.51.jpg
Description:
This is a picture of the working receiver. (well, until yesterday when I ripped off the antenna connector during a bad landing )
The part I'm searching for is the little blue thing near the bottom left corner.
It looks like it's made of ceramic with something blue on the top.
Another feature that distinguishes this part from a capacitor is that it looks as if two little wires are wrapped around it.
It doesn't look like an inductor but I don't know much about this RF-voodoo.
I hope someone here knows more about this stuff
ToastLover is offline Find More Posts by ToastLover
Old May 12, 2015, 07:55 PM
Martin Y is online now
Find More Posts by Martin Y
400' ..... NOT
Martin Y's Avatar
Canada
Joined Jan 2009
That is a RF inductor. It supply's power to the Rf amp. With any luck the IC is not shorted. But..........if IC is shorted, not cheap or easy to replace.
Martin Y is online now Find More Posts by Martin Y
Old May 19, 2015, 08:32 AM
ToastLover's Avatar
Germany, BY
Joined Feb 2015
Well, the RF inductor seems to be okay.
I'm using the transmitter in my miniquad now so the remaining range is sufficient.
Discussion Chipped SMD capacitor on naze32. Trying to identify replacement jollib Multirotor Electronics 7 Apr 23, 2015 07:39 PM
Help! Identify an electronic component on PCB FyreSG DIY Electronics 24 Aug 03, 2014 03:03 AM
Help! FlySky TH-R9B receiver: identifying SMD component WackyWindsurfer DIY Electronics 4 May 08, 2014 01:50 PM
Help! Racewood 900MHz video tx - need to identify damaged SMD component altek DIY Electronics 6 Feb 27, 2012 10:46 PM
Help! Can you help ID'ing an SMD component on an AR6400 Rx. KC Radios 2 Apr 04, 2010 12:47 PM
