Old Sep 07, 2014, 07:39 AM
Crash=start of next project
CN I Dawg's Avatar
Joined Nov 2010
Originally Posted by bonsario View Post
Is there an antenna out which have this military style connector and is able to tilt?
I assume you mean BNC connector? Try this out http://www.readymaderc.com/store/ind...roducts_id=214
CN I Dawg is offline Find More Posts by CN I Dawg
Old Sep 07, 2014, 04:22 PM
Joined Apr 2012
Question: Possible to change PWM frame timing?
Got a small? problem. Trying to use a Futaba SBE-1 [PWM to S-Bus encoder] with the RX700LR, but it does not work. From the logic analyser it seems that the problem [might] relate to the longer PWM 28ms frame of the RX700LR that is just outside the specs of the SBE-1 [3 to 27.3ms]. Pulse width limits are ok, but it looks like the longer frame duration might be messing proper detection in the SBE-1. The SBE-1 works perfectly with a RX that outputs a PWM 14ms frame. Is there any way to adjust the timing of the PWM frame of the RX700LR?
Any other ideas/suggestions appreciated.
Cheers
jmrls is offline Find More Posts by jmrls
Old Sep 10, 2014, 06:27 AM
thomasscherrer's Avatar
Danmark, Hovedstaden, Ballerup
Joined May 2007
28mS is very normal for 12ch ppm,
suggest the s bus converter to fix their problem,
or use less channels, so it works.
thomasscherrer is offline Find More Posts by thomasscherrer
Old Sep 10, 2014, 06:41 AM
North vancouver, B.C. Canada
Joined Apr 2008
For last few months i try all canada and usa distributors to buy three nr rx with no luck
Always out of stock
David22 is offline Find More Posts by David22
Reply With Quote  (Disabled)
Old Sep 12, 2014, 08:53 AM
Joined Dec 2013
hi, i have a problem with one of my long range receivers. i did build a plane with a mfd ap in it (connected via ppm). when i made my bench tests i recognized channel 6 wasnt working, the ap didnt react on any channel 6 input. channel 1-5 was fine.
as i had two other unused long range receiver i tested them and they both work without any problem, 1-6 over ppm all fine. switched back to the first one, and again channel 1-5 work, channel 6 nothing.
the one with the problem is a normal v7 long range.
the two working ones are a v6 boostet lr and a normal v7 lr receiver.
Darky is offline Find More Posts by Darky
Old Sep 15, 2014, 08:59 AM
Joined May 2007
david.. email me :-) I sell you one of my own
Darky, I dont understand ?
you say the PPM output from the RX is missing ch 6 ?
and you did rebind ? after change channel setups ?
Old Sep 15, 2014, 12:35 PM
Joined Dec 2013
hi thomas,
i dont know if the chan6 is missing in the ppm, at least the autopilot doesnt react on it. with other receivers i have no problems, just with one of mine.
yes i did a rebind.
Old Sep 15, 2014, 06:05 PM
Joined Apr 2008
Very cool Thomas thanks
Homer is going to visit me and we plan on a road trip to fly fpv soon, extra UHF rx will be nice
http://www.rcgroups.com/forums/member.php?u=211684
Old Sep 17, 2014, 09:01 AM
Joined May 2007
THAT you need to find out..
it is easy to check if a servo react normal when plugged into ch6 connector,
if this is ok, your autopilot is bugging you.
SUPER david, give my best regards to Homer
Old Sep 18, 2014, 12:57 AM
Joined Dec 2013
hi thomas,
i will test that - strange thing is the autopilot is working with two other receivers perfectly fine...
Old Sep 18, 2014, 01:51 AM
Joined May 2007
could be trigger levels or timing or forgot binding,
if the wanted signal is on ch6 connector it will also be in the ppm signal,
a free audio channel scope software is very usefull for debugging such matters,
unless you got a nice digital storage scope ?
Old Sep 18, 2014, 08:05 AM
Whats the wrst that can happn?
AdamChicago's Avatar
Chicago, IL USA
Joined May 2010
Just ordered a DJI A2 and am a long time TSLRS owner and am wondering when TSLRS will be compatible with SBUS...."coming soon" per TSLRS webpage but when?
AdamChicago is offline Find More Posts by AdamChicago
Old Sep 19, 2014, 07:02 AM
Joined Apr 2012
Rebinding the TX with the RX with less channels [8ch] still produces a 28ms PWM frame [which actually makes sense, why should it have a variable frame timing], unless of course I am doing something wrong.
Wasn't S-Bus support planned for the RX700LR? Is there a beta firmware that could try?
Old Sep 19, 2014, 06:35 PM
Joined Sep 2014
hello
i have tx700 and M.I.G head tracker i can't find the cable that connect M.I.G to HT port of tx700
please advice
nami_ghadri is offline Find More Posts by nami_ghadri
Discussion Long range flight using new DMD 868Mhz RC equipment tron FPV Talk 500 Feb 25, 2014 02:22 AM
Idea Long Range RC pmarek UAV - Unmanned Aerial Vehicles 22 Nov 07, 2011 06:17 PM
Long Range RC Link? cloudy Radios 2 Aug 09, 2008 12:11 PM
long range radio system suggestions?? oracle_9 Thermal 15 Aug 09, 2008 10:44 AM
Discussion Long Range 2.4 Ghz Wireless RC Camera edplane Aerial Photography 8 Apr 18, 2008 08:24 PM
