View Poll Results: 6mm Depron as an airfoil...
... will give you a high-alpha plane. 0 0%
... will crash your plane, soon after tossing it in the air. 0 0%
... is okay, but very inefficient. 0 0%
... is the best there is. That's why they sell 6mm Depron plates anyway. 1 100.00%
Voters: 1. You may not vote on this poll
Old Mar 24, 2015, 05:20 AM
The Netherlands, OV, Kamperveen
Joined Oct 2011
Build Log
Will a 6mm depron airfoil perform?
Well, it started out as a joke. I like Depron as material and often my friends like to call me the Depronator . For indoor there are these flatfoamies, often 3mm-Depron planes that actually float, often high-alpha, through the air. What if... a flat wing was built, 6mm-Depron-airfoil (actually none, just the flat plate), would it fly and perform like a wing with a curved or KF-airfoil?
Well, let's find out...
eric_laermans is offline Find More Posts by eric_laermans
Old Mar 24, 2015, 05:22 AM
Joined Oct 2011
As a starting point, I lay down some 6mm Depron plate and start cutting. I like to design during the build and I use a large ruler and a sharp hobby-knife.
Old Mar 24, 2015, 05:24 AM
Joined Oct 2011
Then I apply some roofing (Carbon-fibre) and glasstissue, but as little as possible. The wing should not be too heavy. No carbon-rod will be applied.
Old Mar 24, 2015, 05:25 AM
Joined Oct 2011
Some ultra-cheap Mylars will keep the roovings and GFK-tissue in place. Some weight will press the Mylars down. As little epoxy as possible will be applied.
Old Mar 24, 2015, 05:27 AM
Joined Oct 2011
Some glassfibre reinforced balsa will be used as verticle stabilizer, but I like to keep 'm small as to reduce drag. (We are talking high-performance here :-))
Old Mar 24, 2015, 05:30 AM
Joined Oct 2011
The RC Powers setup will hopefully keep the wing in the air (D2826-6 2200kV on 3s with a 6x4 prop and a 2200mAh 3s LiPo).
Old Mar 24, 2015, 05:32 AM
Joined Oct 2011
In an effort to keep drag to an absolute minimum, I let the servo's sink into the wing. I hope this is visible on the image above, The I used some glassfibre-tissue to cover the servos and guide the airflow gently over them.
Old Mar 24, 2015, 05:38 AM
Joined Oct 2011
Lean and mean, will this foamy fly. No high-alpha (will fail anyway), only realflight was the bet.
DutchRC - Nick flies his WingThing again :D - few tweaks applied :) (8 min 13 sec)
As I kept a safe distance, my friend Nick (aka The Stig) flew the wing last Sunday. Please feel welcome to comment,
Discussion 3D foamie plans--39.5" WS for 6mm depron kevbeer 3D Foamies 5 Dec 27, 2014 07:41 PM
For Sale DEPRON FOAM 27"x39" 6mm and 9mm jlloyd1995 Aircraft - Electric - Airplanes (FS/W) 0 Oct 18, 2014 08:43 PM
Question How do you think this "airfoil" will perform? NineZeta Modeling Science 24 May 26, 2014 09:53 AM
Discussion 51" Sbach 342 -- Full Fuse -- Airfoil -- 6mm Depron PinkYakRC Foamies (Scratchbuilt) 50 Aug 06, 2011 06:31 PM
Discussion Built-Up 40" Full Fuse Sbach 342 with Airfoil -- 6mm Depron PinkYakRC Foamies (Scratchbuilt) 8 Jun 21, 2011 12:33 PM
