Old Feb 25, 2015, 12:09 PM
Registered Abuser
ziomatrixacs's Avatar
Joined Oct 2006
Trex 450 ball link replacements
Hi all, I have one of the old TRex 450xl's from 2006. I was getting it ready to fly again but noticed a few of the plastic ball links are cracked. I want to replace all of the links for safety but parts are not being made for it any more. Can I substitute the plastic rod ends from the newer TRex's in? I have been out of the loop for a few years so I am not sure what if the size of the ball links are the same. I sure would hate to have to dump perfectly fine bird over $2 in parts.
ziomatrixacs is offline Find More Posts by ziomatrixacs
Old Feb 25, 2015, 01:13 PM
just gotta mess with it!
2Doggs's Avatar
North West Louisiana
Joined Nov 2009
I don't think they changed the size of the links - but you can check the ball diameter. Current 450's use 4.5mm linkage balls. The Thunder Tiger Mini Titan E325 uses smaller links, but I'm pretty sure yours will be 4.5mm. If you're in the US, Value Hobby is a good source in the absence of a local hobby shop.
Good luck, and get it flying!
2Doggs is offline Find More Posts by 2Doggs
Latest blog entry: Nano Tech 1800mah 4S 25-50c
Old Mar 01, 2015, 07:52 AM
Registered Abuser
Joined Oct 2006
I got a set of ball links for the TRex 450 pro. They are about 2mm longer than the original ones but the ball size is the same. I can trim the length down with a dreme with no problem. But if I recall right, one end of the stock linkage is permanently threaded on (I could be confusing it with my Caliber 30 though)
Question What brand ball link pliers to use with Trex 450? generalbacardi Mini Helis 2 Aug 17, 2008 01:22 PM
Wanted Ball Link Plier for Trex 450 XL localbuyer Aircraft - Electric - Helis (FS/W) 3 Feb 26, 2007 12:56 PM
Discussion Trex 450 Elevator servo ball-link touching A-bracket lauri Mini Helis 4 Aug 12, 2006 10:49 PM
Discussion Trex Ball Link Replacement Idea! Will Trex 600 parts fit? djdaveq Mini Helis 2 Jul 16, 2006 10:21 AM
