Old Jan 29, 2016, 09:58 PM
FlyinHiAgain is online now
Find More Posts by FlyinHiAgain
AvidAirAce
FlyinHiAgain's Avatar
United States, LA, New Orleans
Joined Mar 2015
After the hours of building this kit to my specs and other countless hours swapping out messed up retracts and an atrocious horizontal stab I finally almost have her done .
Do yourself a favor kids and order this jet from any other place but MotionRC. Unless you want the entire plane croc-skinned ready for you with damage to "pick a moving part" go with a company that has good quality back up spare parts cause Motion sure as hell doesn't for the F86.
I speak from experience and can tell you I thought the paint job would be amazing and this a pretty jet.
Up close it's not. You can see the horizontal stab deformities from across the room and there's no getting away from that croc-skin across both wings... which just so happen to be warped.
Get it together Freewing and Motion. This is too much money to look like a secondhand LX out the box.
Plan to post flight footage this weekend. Just in case your wondering I'm running RoaringTop 6s 4500mah 35c packs. By far the lightest lipo for the F86 I could find for $30 less then the recommended 4000mah 60c admiral. ...that's another subject altogether. My Roaring Top's weigh 625g and deliver the 90 amps needed for my inrunner setup without barely getting warm. Break em in tho just like any other lipo.
Peace.... and my apologies for the rant.
FlyinHiAgain is online now Find More Posts by FlyinHiAgain
Old Jan 29, 2016, 10:04 PM
Kevin Greene is offline
Find More Posts by Kevin Greene
United States, TN, Jackson
Joined Mar 2007
Originally Posted by cloud9000 View Post
It's the outrunner version.
Tartago - thanks...need to flare a bit more for greasier landings
You did a great job flying it all of the way to the ground...You just need to back off of the throttle to get the nose up on final and ride the throttle to about 2' off of the ground...Reduce the throttle and initiate the flare...That plane will settle in like a butterfly with sore feet!!!...And after the mains touch you can hold back on the elevator and add a little throttle and the plane will do the nicest wheelie for as long as you like......
Kevin
Kevin Greene is offline Find More Posts by Kevin Greene
Old Jan 30, 2016, 03:22 PM
urrl is offline
Find More Posts by urrl
In the pipe 5 by 5...
urrl's Avatar
United States, FL, Hollywood
Joined Aug 2010
Short clip of F-16 morning flight
F-86 and Stinger Flights (5 min 21 sec)
urrl is offline Find More Posts by urrl
Old Jan 31, 2016, 04:26 PM
AvidAirAce
Joined Mar 2015
https://www.youtube.com/watch?v=RmWvDpiIJeI
That Stinger is pretty quick man. No way that's the stock 6s ryt?
Old Jan 31, 2016, 05:46 PM
cloud9000 is offline
Find More Posts by cloud9000
United States, CA, Dublin
Joined May 2009
Kevin
Thanks for the tip Kevin!
I just need more practice landing this as it is only my second EDF I've owned. I usually fly warbirds and got the hang of greasing tail draggers pretty good. Here's one I'm proud of from this morning
Freewing 1400mm P51 Mustang repainted as Big Beautiful Doll
Freewing 1400mm RC P51 Mustang - Greased Landing (0 min 34 sec)
cloud9000 is offline Find More Posts by cloud9000
Old Jan 31, 2016, 09:16 PM
AvidAirAce
Joined Mar 2015
If you can land a tail dragger trike gear should be a none issue.
Old Jan 31, 2016, 11:00 PM
mkpatrick is offline
Find More Posts by mkpatrick
mkpatrick
Joined Mar 2011
https://www.youtube.com/watch?v=d5eMZAvEuyQ
That's one to aspire to....
mkpatrick is offline Find More Posts by mkpatrick
Old Feb 02, 2016, 05:08 PM
Tartago is offline
Find More Posts by Tartago
Plane crazy
Tartago's Avatar
Joined Apr 2006
Originally Posted by Alpha10 View Post
It does not sound better in any way.
Exactly, the inrunner is MUCH smoother due to the superior balancing etc... Anyone that tells you any different is biased. Inrunners ALWAYS sound and perform better IME.
Plus, I've run the stock setup on a buddies F86 and I almost fell asleep. I was 80-100% throttle for the entire flight just to keep it in the air. It was terrible.
I have the in runner and a mate has the out runner version. Side by side the out runner whoosh is much pure.
The inrunner still has a electric motor sound.
The stock flies great on my mate's plane. My plane has about 20% more punch, that's all.
Tartago is offline Find More Posts by Tartago
Old Feb 06, 2016, 08:37 AM
jhamm is online now
Find More Posts by jhamm
USA, NY, Rochester
Joined Jan 2003
Gyro mounted
Finally decided how to cram everything in.
This is an awesome jet
jhamm is online now Find More Posts by jhamm
Old Feb 06, 2016, 09:35 AM
jhamm is online now
USA, NY, Rochester
Joined Jan 2003
Custom Cockpit
Does anyone know if there are any custom cockpits that will fit this jet that will not break the bank. I checked with HK and they don't have any.
Thanks for the info.
Old Feb 06, 2016, 05:46 PM
urrl is offline
urrl's Avatar
Joined Aug 2010
Harry's morning flight
Harrys F-86 (2 min 56 sec)
Old Feb 07, 2016, 10:00 PM
fishface5 is online now
Find More Posts by fishface5
United States, NE, Lincoln
Joined Oct 2014
Job well done, My F86 is my go to jet during this winter
fishface5 is online now Find More Posts by fishface5
Old Feb 08, 2016, 03:27 PM
Garyss is offline
Find More Posts by Garyss
Joined Aug 2006
There has been some discussion in various parts of this thread about modifying the cockpit area to improve things, but it's mostly homemade. Photos of the full scale F-86 are resizeable/adaptable with a good printer.
One poster re-positioned the pilot to a more appropriate stance in the cockpit. Here are some copied photos within this thread. You can access all photos by going to thread tools and clicking on "attachments". I apologize of you already know this. If interested you might track down the poster from the pictures and PM him for more info, etc.
Garyss is offline Find More Posts by Garyss
Old Feb 08, 2016, 04:19 PM
jhamm is online now
USA, NY, Rochester
Joined Jan 2003
Great! Thanks
Old Feb 09, 2016, 07:50 AM
weedsnager is offline
Find More Posts by weedsnager
weedsnager's Avatar
United States, IN, St John
Joined Mar 2011
Your the first person I've heard complain about Motion Rc.
They don't build the planes. They hold them in a warehouse and ship them. How is it their fault ?
weedsnager is offline Find More Posts by weedsnager
Discussion Freewing 80mm A-6 Intruder EDF tdford Foamy EDFs 2259 Apr 12, 2016 05:05 PM
For Sale ZDFly F-86 80mm Jet 4s Chopper1 Aircraft - Electric - Jets (FS/W) 0 Nov 15, 2013 11:19 PM
Sold F-16 and F-86 80mm edf airframes drats Aircraft - Electric - Jets (FS/W) 3 Jul 03, 2012 03:13 AM
For Sale F-16 and F-86 80mm edfs drats Aircraft - Electric - Jets (FS/W) 3 Jun 28, 2012 10:24 PM
Discussion Starmax F-9F Panther v Freewing F-86 Sabre AlphaWhisky Foamy EDFs 1 Jan 22, 2011 08:23 PM
