Old May 21, 2014, 11:20 AM
Joined Mar 2009
Jello can be generated entirely in-camera. This occurs in much the same way that your props appear to be spinning oddly when viewed as a video image....it all has to do with shutter speed.
Using a slower shutter speed your props will just be a blur, whereas using a higher shutter speed they will be capture in different spinning patterns. AFAIK the only way to directly alter the shutter speed on a GoPro is by using a neutral density filter.
Level Flight is offline Find More Posts by Level Flight
Old May 22, 2014, 10:04 PM
eurny666's Avatar
United States, FL, Gainesville
Joined Nov 2013
Hi Guys,
I don't know whether I'm alone with this but I had a lot of issues with my hero 3 Silver. As a mater of fact I have had it for 1.5 years and I use I mainly for FPV on my F330.
For instance, in the beginning I couldn't supply it while flying in FPV. It caused the H3 to be frozen and I had to remove the battery to get it back working. After some time the H3 was crashing even without being supplied, I was not usable. I then called the after sales service and they helped me fix it. (by updating the H3 and then formatting the SD card).
It had worked well for a while and then the issues came again.
Now I can use my GoPro for FPV but sometimes it crashes, and I cannot supply it while flying.
Has anyone of you experienced the same problems?
eurny666 is offline Find More Posts by eurny666
Old Jun 16, 2014, 11:11 AM
tymrunner's Avatar
Canada, BC, Vancouver
Joined Mar 2014
Does anyone know the USB AV out resolution of the hero 3 black. How many tv lines?
tymrunner is offline Find More Posts by tymrunner
Old Jun 16, 2014, 10:42 PM
Joined Mar 2009
Isn't it the same as your user selectable options? Would be good to know for sure. I could probably find out with a bit of searching . . . . .
Old Jun 17, 2014, 01:29 AM
tymrunner's Avatar
Joined Mar 2014
I don't know if your are replying to me or not, but if you are the answer is no. The recording option are HD and the A/V out is analog SD. NTSC is 480 and PAL is 576 TVL but can be a lot less. I am just wandering if it is comparable to a board camera.
Old Jun 21, 2014, 01:42 AM
United States, CO, Fort Collins
Joined Jun 2011
Hey guys I have a quick question. I just got a gopro hero 3+ black and typically I use a 30 pin connector cable that plugs into the back of my old hero 1 for fpv. This cable seems to not be working with the gopro 3 but works perfectly with the hero 1. However the cable supposedly can work with a gopro 3. Am I doing something wrong? The little black play box does not appear in the gopro menu when it is plugged in.
Sam
samsking is online now Find More Posts by samsking
Old Jul 08, 2014, 09:18 AM
Australia, VIC, Hallam
Joined Dec 2013
Quick Aerial Tour with Kangaroos using Phantom 2 + Zenmuse H3-3D Gimbal (1 min 49 sec)
GoProAirRecon is offline Find More Posts by GoProAirRecon
Reply With Quote  (Disabled)
Old Jul 16, 2014, 01:54 AM
Beware Of The Shills !!!
Chichester Sussex
Joined Aug 2007
Does anybody else's 3 lock up sometimes and won't switch on and the only way to unlock it / get it to respond is remove the battery??
Witterings is offline Find More Posts by Witterings
Old Jul 16, 2014, 08:19 AM
2Vision-Air
bakchos's Avatar
Canada, QC, Blainville
Joined Aug 2009
I get this when I use external power on my tarot gimbal
bakchos is offline Find More Posts by bakchos
Sold *SOLD* NIB GoPro HD Hero 2 Motorsports Edition plus NIB GoPro Wifi Combo Kit. jbj620 FPV Equipment (FS/W) 2 Jun 11, 2012 11:54 AM
Discussion FPV using GOPRO HD Hero 2 + bacpac WIFI Link69 Multirotor Talk 4 Feb 26, 2012 07:24 PM
Build Log HD FunJet v2 (mini) build log with GoPro HERO HD jbpilot FPV Talk 14 Oct 31, 2010 09:36 AM
Cool GoPro HD Hero Wide - 6.3 oz HD video camera nemo_uk Aerial Photography 5 Sep 27, 2009 09:40 AM
