Old Jun 18, 2016, 11:09 AM
dec0y13 is offline
Find More Posts by dec0y13
United States, ID, Pocatello
Joined Sep 2008
Help!
XJT module and DIY RX-F802
I may be doing to many new things at once.
I got an XJT module for my FrSky 9X radio (my radio has the Smartieparts Extreme board in it)
I'm trying to bind it to a RX-F802 receiver (ordered from Banggood)
I'm running stock frimware on the receiver, but hope to flash it once my gear arrives.
I thought I could bind it without flashing though?
I press the bind button on the XJT module and it beeps and flashes fine.
I get a solid Green light on the receiver when i attempt using the bind plug, and a Blinking green light without it.
(I understand blinking means unbound)
I've worked through a lot of the DIY flash forum, but I cant seem to find anyone using my setup.
So, HELP PLEASE
Where should my dip switches be in the XJT module?
Am I missing something in my radio settings? (Very likely)
Should I be doing something different? I'm not sure I'm ever getting the receiver in bind mode.
Do I have to Flash BEFORE it will bind?
**Banggood mentions D8 mode. I'm not sure what that means. (Compatible with X9D(D8 mode)/XJT (D8 mode)/DJI/DFT/DHT)
(Next, I wanna get it in PPM...I'm almost afraid)
dec0y13 is offline Find More Posts by dec0y13
Old Jun 18, 2016, 02:46 PM
dec0y13 is offline
Joined Sep 2008
I found it may be the Settings im my radio. With the XJT Module you need to set the protocalls correctly. I'm om PPM now but (according to the handbook) I need to set it up as "Pxx"
I'll test ti out when I get home.
Sold Frsky XJT module + 2x L9R rx + 7db patch marcus le renard Aircraft - General - Radio Equipment (FS/W) 0 Jun 02, 2016 06:12 PM
Discussion Rx-f802 frsky RX range and suitability for gliders nigelsheffield Radios 38 Oct 16, 2015 11:24 AM
Wanted Frsky XJT JR Module/Rx Beemond Aircraft - General - Radio Equipment (FS/W) 1 Aug 31, 2015 08:43 PM
For Sale Frsky Xjt JR module +LR9/XR8(2 rx's) 907fpvman Aircraft - General - Radio Equipment (FS/W) 0 Mar 03, 2015 03:39 AM
For Sale Turnigy 9x w/open RX software, led back light and FRsky xjt Module bmbryan3 Aircraft - General - Radio Equipment (FS/W) 6 Oct 13, 2014 06:48 PM
