Old Apr 13, 2016, 03:06 PM
jumo004 is offline
Find More Posts by jumo004
jumo004's Avatar
Joined Apr 2010
20mm EDF
Hope to test this over the weekend.
Using a 8mm BL tail rotor motor for the MCPX heli.
... tiny little sucker ...
jumo004 is offline Find More Posts by jumo004
Old Apr 13, 2016, 04:23 PM
Quorneng is offline
Find More Posts by Quorneng
Joined Feb 2007
That looks very neat.
Tiny yes but how much thrust and weight?
Quorneng is offline Find More Posts by Quorneng
Old Apr 14, 2016, 08:53 AM
jumo004 is offline
jumo004's Avatar
Joined Apr 2010
I'm going to try and get some numbers for this, as is, and then cut off the tail cone and try it again. I would like to get 30g of thrust on 2S.
I'm going to attempt to balance the fan. Working with something this small is going to be a challenge, that's for sure !
Old Apr 15, 2016, 05:11 AM
AntiArf is online now
Find More Posts by AntiArf
AntiArf's Avatar
Joined Feb 2013
30 grams would be good. Something like this would be good for a small scale model, where the weight really matters and the payoff could make a difference. From what I remember, I probably didn't get any more than 30 grams of thrust from my EDF30 Vampire, using a much heavier Feigao motor, BA 2.5gm servos, and GWS Pico receiver years ago. Still flew well, but done again with modern gear and built lighter, I could see the potential for an ultra light BL fan, in a scale app which weighs a bit more than a profile and requires BL power. FWIW something like this could even be practical in models like the foamie UMs out now. Not as fast, but would be easier to fly and land at the lighter weight. Shaving off 10 grams of battery and motor weight makes a lot of difference on these small models. Could make them better indoor candidates.
AntiArf is online now Find More Posts by AntiArf
Old Apr 15, 2016, 09:46 AM
jumo004 is offline
jumo004's Avatar
Joined Apr 2010
I'm really not sure what I would put this in. I'm at a loss with what electronics to use, would I use a brick or separate components or should I use actuators (of which I have no knowledge) ?
Another thing is that it might require some complicated build techniques such as a molded foam fuse.
Of course this all depends on the thrust I can get out of it ...
But it's all fun !
Thanks.
Old Apr 15, 2016, 08:49 PM
mcross is offline
Find More Posts by mcross
For Sale-everything over 250 g
Souderton Pa. USA
Joined Mar 2002
30 grams on 2s shouldn't be a problem. Here's a couple 1s 20's I did a few years age. Thrust was about 20 grams.
http://www.rcgroups.com/forums/showthread.php?t=1159390
Nice to see some experimenting going on!
mcross is offline Find More Posts by mcross
Old Apr 16, 2016, 01:42 PM
jumo004 is offline
jumo004's Avatar
Joined Apr 2010
All things considered I'm happy with the balancing ... I didn't even think I'd get this close.
I think I got lucky !
20160416 141949 (0 min 24 sec)
Old Apr 16, 2016, 03:12 PM
pdawg is offline
Find More Posts by pdawg
Need 4 Speed!
pdawg's Avatar
United States, OH, Dayton
Joined Apr 2004
Jumo004,
Very slick micro balancer!
pdawg is offline Find More Posts by pdawg
Old Apr 16, 2016, 09:49 PM
AntiArf's Avatar
Joined Feb 2013
It is a nice little part there. Seems far better than a single rod setup. The problem with those arrangements is that they have to be beyond Swiss Watch precision, to get good results with parts this small. With this setup, even if it's not 100% perfectly straight or level, you start to see a pattern when observing the rotor roll across the bars, which will show you which side is heavy/light.
Old Apr 17, 2016, 08:42 AM
jumo004 is offline
jumo004's Avatar
Joined Apr 2010
Originally Posted by pdawg View Post
Jumo004,
Thanks !
Yea, after a few tries you get the hang of it ...
One problem I had with this setup was that the rods were slightly magnetized and that effected the cross bar roll. I'm still not sure how that happens, maybe I bought them that way or maybe it happened when I polished them but with this tiny (.032 dia) cross rod it doesn't seem to be a problem.
In my 'never ending quest' to balance these small fans I made this setup.
It works okay .... but I like the other one a little better.
Old Apr 17, 2016, 11:56 AM
jumo004 is offline
jumo004's Avatar
Joined Apr 2010
.... disappointing ....
What I should do is make a more aggressive fan (higher pitch). That would help for sure also I think the bushings have to be replaced with bearings and I'm wondering if a higher KV would help.
I ordered a GP Ammo 10-15-11500kv motor. It's 2mm bigger in diameter then this motor so I'm thinking of trying a 22mm fan size. It also has bearings ... OR ... I'll just keep playing with 30mm fans, they're frustrating enough ....
20160417 120211 (0 min 49 sec)
Old Apr 17, 2016, 12:18 PM
AntiArf's Avatar
Joined Feb 2013
Still not bad, considering how little power used. You could use a really light lipo for 1A. I'm hoping the light weight GP motor pays off in the Comet, when I get around to flying it. Waiting for a bit more grass growth. There's more powerful motors, but not much lighter in the 10mm size.
Old Apr 17, 2016, 12:21 PM
Bare is offline
Find More Posts by Bare
Canada
Joined Nov 2000
Perhaps you might consider grinding concentric points on either end of your balance axle.
Stick a dime sized Neo magnet to each Vise Jaw..then open the vise to acomodate the axle length.. only one end needs touch a magnet.. for an even more accurate and dead simple to use Balancer?
Bare is offline Find More Posts by Bare
Old Apr 17, 2016, 12:56 PM
ksqm is online now
Find More Posts by ksqm
United States, VA, Hampton
Joined Mar 2009
The unknown factor is the efflux. Try mounting the EDF in a simple profile test bird. You may be surprised.
ksqm is online now Find More Posts by ksqm
Old Apr 17, 2016, 01:49 PM
jumo004 is offline
jumo004's Avatar
Joined Apr 2010
I've all but given up on the magnetic balancer. I know the boat guys use them for their props and seem to get good results but everyone I tried left me pulling my hair out.
The problem I was having was grinding a PERFECT conical shape on the balancing rod. Anything less then PERFECT (at least in my case) didn't work. Another thing was that the balancing rod would get magnetized and would fight the field in the disc magnet. They would eventually align but always in the same spot which was never in the balance position. I admitted defeat and moved on ...
This was an early magnetic balancer that I made ...
Sold 12 x 20mm x 20mm Square Hook & Loop Sets irun4fundotca Aircraft - General - Miscellaneous (FS/W) 5 Dec 10, 2013 05:05 PM
Discussion EDF 40 and 50 with 20mm motors Adrianh GWS (Grand Wing Servo) 0 Jun 11, 2008 03:22 PM
Sold Two GWS EDF-64+gws BL motors 20mm 3900kv NIB darmar Aircraft - Electric - Jets (FS/W) 6 Feb 01, 2008 11:00 AM
For Sale Two GWS EDF-64+gws BL motors 20mm 3900kv NIB darmar Aircraft - Electric - Power Systems (FS/W) 0 Jan 03, 2008 09:32 AM
MPI 20mm EDF heatsink Mac8 Electric Ducted Fan Jet Talk 9 Oct 16, 2005 03:56 AM
