Old Apr 02, 2015, 06:17 PM
Updraft67 is online now
Find More Posts by Updraft67
United States, NC, Charlotte
Joined Mar 2014
Which Olympic version did I have?
I have been racking my brain for a long time about this. Back in 1993 I was given a large glider kit. It was the biggest plane I have ever built. I know it had a span of over 100". It had a full flying stab, the wing joiner was a 1/4"(or so) steel rod. It had spoilers that were held down with rubber band. The single spoiler servo was in the fuse and connected to the spoilers with fishing line. The wings came together to the side of the fuse and did not sit on top of the fuse. I am certain this was a version of the Olympic. I thought it was an Olympic II but I see it does not have a full flying stab and the wings mount wrong. This is driving me made. I have looked and looked and looked around the internet and just can't find it. The full flying stab was built with a center spar and the "ribs" were pieces of thin balsa bent over the top and on the bottom of this spar and glued to a leading and trailing edge piece. I also recall the stab being 2 pcs for ease of transport.
Updraft67 is online now Find More Posts by Updraft67
Old Apr 02, 2015, 07:14 PM
Alienmenacet54 is offline
Find More Posts by Alienmenacet54
Alienmenacet54's Avatar
United States, NE, La Vista
Joined Oct 2014
After looking at the plans that I have in pdf format of the Olympic II and the Olympic 650. The plane does not have a full stab tail. Sounds like what you are describing would be the Airtronics Aquila or the Aquila Grande. The Aquila (Standard Class) had a 99 inch wing, wood fuselage and the Aquila Grande (Open Class) is 123 inch I believe and has a glass fuselage. Here is a couple of pictures of my Aquila Grande that I have not yet finished.
These are pictures of the stab of both Aquila's.
Would you have a picture of it?
David
Alienmenacet54 is offline Find More Posts by Alienmenacet54
Old Apr 02, 2015, 07:18 PM
Joined Mar 2014
David,
No that's not it either. What I had was a balsa/ply fuse.
Old Apr 02, 2015, 07:37 PM
tkallev is online now
Find More Posts by tkallev
LSF303 / AMA Life Member
tkallev's Avatar
USA, IL, Wheeling
Joined Jan 2003
The only derivation of the Olympic that plugged into the fuselage sides was the American Eagle, it used Thermic 99 wings/stab but the stab was fixed airfoiled shape not flat plate like the Oly.
tkallev is online now Find More Posts by tkallev
Old Apr 02, 2015, 07:46 PM
Joined Oct 2014
Could this be it.
Old Apr 02, 2015, 07:53 PM
tkallev's Avatar
USA, IL, Wheeling
Joined Jan 2003
From your description of the stab build, it sounds like a Mark's Models Windfree ...
Old Apr 02, 2015, 08:09 PM
Joined Oct 2014
Here is part of the plans of the Windfree showing the stab and how the wings fit.
and the plans of the Durex V.
Old Apr 02, 2015, 08:25 PM
Joined Mar 2014
Nope on those too....
Old Apr 02, 2015, 09:17 PM
alexhallmalta is offline
Find More Posts by alexhallmalta
Malta & Newport
United States, RI, Newport
Joined May 2010
I may be wrong, but could it have been a Sagitta?
Ply and balsa fuse, central spoiler servo , single wing joiner and full flying stab.
However the stab construction described is similar to a Windfree, just as tkallev points out.
alexhallmalta is offline Find More Posts by alexhallmalta
Old Apr 02, 2015, 09:35 PM
Joined Oct 2014
Ok here is pictures of the Sagitta XC plans.
Old Apr 02, 2015, 09:42 PM
Joined Oct 2014
And here is the Sagitta 900 plan picture
Old Apr 10, 2015, 01:23 AM
Esprit2 is offline
Find More Posts by Esprit2
Minnetonka, Minnesota, USA
Joined Jan 2005
Skybench Aerotech owns the rights to the Oly II, and has taken the liberty of producing an Olympic III. It's a more modern design, and only shares the intent or spirit of the Oly II. The 132" wing uses an S3014 airfoil, D-Tube construction, and a built-up trailing edge. The wing Area 1066 sq in. The wings mount to fuse sides with pass through wing rod.
Go here and scroll a bit more than half way down the page:
http://www.skybench.com/index.html?h....com/home.html
Look familiar?
Regards,
Tim
Esprit2 is offline Find More Posts by Esprit2
Old Apr 14, 2015, 02:35 PM
Roy_N is offline
Find More Posts by Roy_N
Roy_N's Avatar
United States, WA, Burien
Joined May 2014
Originally Posted by Updraft67 View Post
David,
The standard class Aquila (99" wing span) came with a wood fuselage.
Roy_N is offline Find More Posts by Roy_N
Old Apr 14, 2015, 05:31 PM
HIR/Cer is offline
Find More Posts by HIR/Cer
HIR/Cer's Avatar
Joined Apr 2005
Could be an Aquila. The Aquila's flying stab construction is what you have described. Plan courtesy Outerzone:
HIR/Cer is offline Find More Posts by HIR/Cer
Old Apr 14, 2015, 05:43 PM
Joined Oct 2014
I mentioned that earlier in the post, and he said it wasn't that. But, I really think it might be. In less someone had designed their own and it was never published. I have had the Aquila 99" and I have the Aquila Grande now.
Help! Which version of 808 did I get? wilykat Aerial Photography 0 May 05, 2014 02:40 PM
Discussion Dymond D47 servo, Which version do you have on hand, how can you tell??? TDboy Hand Launch 5 Apr 21, 2012 02:26 AM
Discussion Which version Naro servo do I have? pmjass GWS (Grand Wing Servo) 10 Aug 03, 2007 05:46 AM
Cool Which Wing Profile did the P-80 Shooting Star have? ralf dvorak Scale Kit/Scratch Built 7 Oct 13, 2005 02:59 PM
Which version Pheonix 45 do I have? bfraser Castle Creations 1 Nov 17, 2004 08:47 AM
