Old Jan 11, 2006, 01:10 PM
Strykaas is offline
Find More Posts by Strykaas
Strykaas's Avatar
Joined Nov 2004
DIY jet : anyone tried this ?
Looks cheap quick and fun !
http://grenadeindoor.modelisme.com/diyjet.htm
Edit : I've uploaded SCALE pdf plans of this thing, available on page 3...
Strykaas is offline Find More Posts by Strykaas
Old Jan 11, 2006, 02:29 PM
2LL is offline
2LL
Find More Posts by 2LL
2LL
2LL's Avatar
France, Ile-de-France, Paris
Joined Nov 2004
I have just finished mine, test flight next week i hope.
Mine have a 3S/1000mha, flyware rex220 motor, graupner 5.5*4.3
With the 1000mha pack i had to put the motor more forward to have the corect center of gravity.
Christophe
2LL is offline Find More Posts by 2LL
Old Feb 16, 2006, 05:49 AM
2LL is offline
2LL
2LL
2LL's Avatar
Joined Nov 2004
First flight
Firsts flights 2 days ago!
No problem it flies very good. I think it's a good first pusher, very fast to build!
If i build a new one i would desing it with a narower fuselage.
Old Feb 17, 2006, 05:11 PM
aerod is offline
Find More Posts by aerod
aerod's Avatar
Joined Oct 2005
pdf plans please!
aerod is offline Find More Posts by aerod
Old Feb 20, 2006, 11:29 AM
2LL is offline
2LL
2LL
2LL's Avatar
Joined Nov 2004
pdf plan
Here it is!
I'am not shure if it is to scale.
The wingspan is 50cm
Old Feb 22, 2006, 10:58 AM
PhantomII is offline
Find More Posts by PhantomII
Phantom Mechanic
PhantomII's Avatar
Westpoint Utah
Joined Jul 2005
Would any one be able to tile that PDF for us?
PhantomII is offline Find More Posts by PhantomII
Old Feb 22, 2006, 12:46 PM
gravitic anomaly is offline
Find More Posts by gravitic anomaly
Freezing my Lipo's off.
gravitic anomaly's Avatar
Princeton,Minnesota USA
First pass at a tiled version. Should be about a 520mm wingspan.
The resolution isn't the best. The original was quite small.
gravitic anomaly is offline Find More Posts by gravitic anomaly
Old Feb 22, 2006, 01:03 PM
Phantom Mechanic
PhantomII's Avatar
Westpoint Utah
Joined Jul 2005
Thanks!!!
Old Feb 23, 2006, 02:55 PM
10Thumbs is offline
Find More Posts by 10Thumbs
Motor Maniac
Orange County, CA
Joined Feb 2002
What material are you using in the construction? I didn't download the plans yet, so that would probably answer my question if I weren't being lazy.
10Thumbs is offline Find More Posts by 10Thumbs
Old Feb 24, 2006, 02:07 PM
2LL is offline
2LL
2LL
2LL's Avatar
Joined Nov 2004
the original plans, dxf format are here: http://grenadeindoor.modelisme.com/diyjet.htm
If you can do thomething with .dxf
Old Feb 26, 2006, 04:13 AM
stephan_ska is offline
Find More Posts by stephan_ska
pforzheim, germany
Joined Feb 2006
hi there,
i've tried this pusher jet.
because it's nice looking, easy, to built and small
btw, it's my first depron-jet i have built and i'm not very prooved in building with this material, but it seems to be an easy way to get a new model
ok
it's cold outside windy and snowing, but i've seen no reason to do no maiden.
hmya....it should have been better to choose an other day i gues.
i am using the GWS 2050, powered by 960 mah 11.1v 3s in combination with a 6"x4" prop ... maybe a little bit to rude for this model..
throwing the bird with half of possible of thrust, with a soft angle to the sky...
....the first *flight* took not more then 10 sec. untill it crashes because of turning around because of it's motor.
no chance to do something against it. *grumph
but no matter what happend, i will try it again.
greetings
stephan
stephan_ska is offline Find More Posts by stephan_ska
Old May 03, 2006, 11:41 AM
2LL is offline
2LL
2LL
2LL's Avatar
Joined Nov 2004
A problem: it is fun to fly
Too low inverted pass result...
But the plane is already repaired
Old May 03, 2006, 12:27 PM
Vintauri is offline
Find More Posts by Vintauri
MN WATTS Master
Vintauri's Avatar
United States, MN, Mankato
Joined Jul 2003
Looks interesting anyone have some video of thiers flying? I'd like to see it's slow speed and landing charateristics.
Vintauri is offline Find More Posts by Vintauri
Old May 13, 2006, 10:11 AM
pforzheim, germany
Joined Feb 2006
hi there !
what abaout the cg ? ....i am asking because i can`t translate *...105mm du bec avant l'emplanture*
so help is needed ! thanks !
best regards
stephan
Old May 16, 2006, 09:23 AM
2LL is offline
2LL
2LL
2LL's Avatar
Joined Nov 2004
CG : 105mm from the leading edge (at the wing root including the apex)
Mine is about 115mm and flies great
http://marilyne.christophe.free.fr/o...L/MVI_7954.avi
The video is at low speed, wind about 10kt
Has anyone tried this Li-Ion charger IC? simingx Batteries and Chargers 72 Feb 09, 2003 08:47 AM
Anyone Tried This Cable Yet??? ArcherAce Electric Plane Talk 1 Oct 17, 2002 11:36 AM
Has Anyone Tried This? nr5a Parkflyers 1 Aug 22, 2002 07:49 PM
Anyone Tried this Charger? mt_100 Parkflyers 3 Jun 26, 2002 09:28 PM
Anyone tried this? lensrc Foamies (Kits) 1 Mar 21, 2002 07:27 PM
