Old Jun 22, 2016, 02:18 PM
ReeceEngineering is offline
Find More Posts by ReeceEngineering
Joined May 2016
Help with motor selection for 120mm EDF
After looking at the market for quite a while its seeming like building an EDF fan is cheaper than buying a prebuilt unit. This is the fan Im considering using at the moment:
http://www.hobbyking.com/hobbyking/s...e_4_5inch.html
Interpreting the product description is something I am having a hard time with. This fan says its recommended motor is: "36-50 4 Turn"
I dont know if this means 36mm up to 50mm diameter, or a 36mm diameter/50mm length motor. In addition to this many of the EDF motors HK sells arent rated for 100amps, which doesnt make sense to me for the fans they state in their descriptions. The KV rating I understand correctly. Can anyone shed some light on what motor I would need for this fan? Thanks
ReeceEngineering is offline Find More Posts by ReeceEngineering
Old Jun 22, 2016, 05:19 PM
Chris True is offline
Find More Posts by Chris True
St. Mary, Maryland, United States
Joined Dec 1996
If $25 is your budget play with something smaller!!
Chris True is offline Find More Posts by Chris True
Old Jun 22, 2016, 05:35 PM
Knife Liddle is online now
Find More Posts by Knife Liddle
Lee Liddle
Knife Liddle's Avatar
Carrollton, Tx
Joined Dec 2006
RE, I did a whole thread using that fan as the starting point. There were lots of people who said I was wasting my time, but the results speak for themselves.
You can build a fan/esc system for about $225 that will give you up to 15lbs of thrust on12s. All the details are in the thread. Also many people duplicated my efforts with much success.
It's a lot of power, so take proper safety precautions. Happy reading and good luck. You can do it.
http://www.rcgroups.com/forums/showthread.php?t=1324088
Knife Liddle is online now Find More Posts by Knife Liddle
Old Jun 23, 2016, 10:26 AM
Joined May 2016
I dont know where you are pulling this $25 number from, this fan alone costs that much. Im going to have to pair it with an ESC and Motor along with the rest of the Jet. No one is thinking about a $25 EDF build here lol
Well I dont need anywhere near 15 lbs of thrust lol. Can you take a look at the specific question I asked in regards to how the motor selection is made from the product description? There are 2 possible interpretations I can see being made, they are outlined in the OP. Can you take a look there and tell me which is correct about choosing a motor?
Old Jun 23, 2016, 11:49 AM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
Any motor up to 50mm dia will fit. So it looks like they are sayung 36mm-50mm, but the 4turn info is usless. You need to pick a motor based on what voltage you want to run and what power level you need.
You have much to learn about edf power. Either duplicate someone's tested setup, or plan on much trial and error and expense
Old Jun 23, 2016, 11:53 AM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
No one can help you pick a motor without a bunch of info such as v, a, thrust, durration, flying style, ect that you plan for the fan. There is a ton of info in the thread. Read up.
Old Jun 23, 2016, 09:45 PM
phantomphan is offline
Find More Posts by phantomphan
Design.Build.Fly
phantomphan's Avatar
United States, NC, Huntersville
Joined Jun 2009
Guys. The OP was looking for a 3-4.5kg setup in another thread. I assume that hasn't changed.
Reece. If I recall correctly that fan has been on the market a while, for years. The motor numbers HK put up are junk imho and at present I dont see any motors listed that are suitable for that fan. 49mm max diameter and <1000 kv.
phantomphan is offline Find More Posts by phantomphan
Old Jun 24, 2016, 12:07 AM
Bob Reynolds is offline
Find More Posts by Bob Reynolds
Tucson, AZ, USA
Joined Nov 2000
I run that fan in my Bruce Tharp's Reaction 54 that I redesigned to 82% specifically for this fan. Wing span is 64 inches, area is 970 square inches
Fan: Turnigy 4.5"
Motor: Scorpion HK-4035-630
ESC: Turnigy 100amp
Battery: 12s 5000 25C LiPo
Thrust : 10 lb
Amp draw: 62
Model weighs 14 pounds, timer is set for 8 minutes, has been radared at 140mph.
Bob Reynolds is offline Find More Posts by Bob Reynolds
Old Jun 24, 2016, 05:12 PM
Joined May 2016
Ok 36 to 50mm as possible diameters was what I was leaning towards, that really opens up motor selection. On that note the goal was 3-4.5 KG of thrust mostly aiming for maximum duration in flight for a good distance traveled per MAH used. I was thinking of running 8S and setting up to carry 10,000 mah.
However at this point Im thinking I should do a prop setup to reduce complexity; I'll need to have this wrapped up to the point I can fly for fun by the Fall. The impending School Year is going to prevent me from developing an amazing EDF Jet at this early on.
Loosing the complexity of developing the intakes, thrust tube and battery compartments packaged neatly inside the fuselage will speed up construction by a lot, and should reduce cost as well. Ive seen many documentaries of Military Jets in development where cost overruns sank the project or ran far higher than expected. I'm assuming its not much different in the RC world.
Old Jun 24, 2016, 05:16 PM
Joined May 2016
Fan: Turnigy 4.5"
ESC: Turnigy 100amp
Thrust : 10 lb
Amp draw: 62
Thats amazing. Im aiming (or was aiming) for a 3 foot wingspan at maximum. I would really expect that to pull more than 60 amps but it seems the larger fans work really well compared to the smaller ones. How much MAH do you fly with to yield 8 minutes? What is the average speed traveled in that 8 minutes?
Old Jun 24, 2016, 11:19 PM
Tucson, AZ, USA
Joined Nov 2000
Don't know the answer to either question. full power for take off and any speed runs. Rest of the time is just having fun goofing off. 14 pounds with 970 square inches says it floats fairly well and being a clean model says that energy is not lost very quickly, so not much power is needed.
I will say that the cross wind leg to final turn when the barn door flaps go down you can see the plane almost stop in midair and settle in at a brisk walking speed for a nose high landing.
Found 120mm edf unit with motor klmehaffy Aircraft - Electric - Jets (FS/W) 6 May 06, 2016 11:02 AM
Found 70mm, 110mm or 120mm EDF fan w/motor installed and balanced klmehaffy Aircraft - Electric - Jets (FS/W) 0 Apr 18, 2016 10:50 PM
Discussion Please help with motor selection. redjeep Multirotor Power Systems 2 Mar 05, 2016 10:51 AM
Discussion Help Selecting Replacement Motors for 7kg Octo Hybrid lar9 Multirotor Power Systems 4 Feb 07, 2016 06:25 PM
Sold New Unassemble TamJets 120MM Edf Unit With Nue 1915/1Y Motor $700 Shipped FlyBoyTha1 Aircraft - Electric - Jets (FS/W) 2 Nov 02, 2010 08:09 PM
