Old Jun 08, 2016, 08:35 AM
ScratchBuildrSAM is online now
Find More Posts by ScratchBuildrSAM
United States, OH, Middletown
Joined Dec 2011
Drop-Off-Motor Sailplane Launching
Looking for input:
Have several sailplanes, and numerous sizes of diesel engines that I like to use.
Limited ability to walk/move around. Retrieving winch line too tiring now.
Want to use drop-off motor that is tethered, ala a winch/high start line.
Interested in underslung motor on slender pylon strut, that is parachuted, then retrieved, via kite reel (very fast retrieve) etc,
Don't want fuel residue on model gliders, hence 6: O'clock downward strut.
Don't want to buy electric system, yet want any system to not weigh down model's wing loading.
My thinking is the motor/parachute retrieve system could be generic to similar size models.
This system, being contemplated, could allow me to fly thermal-type soaring gliders, and old timers, much more. No energy (walking) to do either winch or high start retrieves.
Servo-released .061, .15, .19 engine units would launch any size sailplane, with COMMON take-in reel eliminating walking for this handicapped flyer.
Fully understand up-thrust necessitating trim changes from under model engine location.
This seems so obvious a way to fly sailplanes/gliders , I wonder why it is not commonplace to launch models in this manner.
Engine struts would mounted @ CG, or slightly forward, to keep system more simple.
Just sounds fun, as well as doable.., to my limitations!
Any thoughtful discussion/input appreciated.
ScratchBuildrSAM _____AMA # 28854_____SAM # 1312
ScratchBuildrSAM is online now Find More Posts by ScratchBuildrSAM
Old Jun 08, 2016, 10:08 AM
SteveK123 is offline
Find More Posts by SteveK123
Hates Palm Trees
United States, CA, Torrance
Joined Jan 2013
Why not just hit the easy button on this and build an E-fuse w/ electric motor?
SteveK123 is offline Find More Posts by SteveK123
Old Jun 08, 2016, 10:22 AM
dankar04 is online now
Find More Posts by dankar04
Tucson, Az
Joined Feb 2007
+1 on that save your self effort and go electric. Folding prop no mess and done right easy as pie. No need to find motor and chute/ or what ever.
dankar04 is online now Find More Posts by dankar04
Old Jun 08, 2016, 10:33 AM
LJH is online now
LJH
Find More Posts by LJH
LJH
Moths do not fly inverted
LJH's Avatar
Greenwich CT.
Joined Sep 2000
I agree with the above two comments. Having a drop away motor sounds like a PIA not to mention the noise of an engine. I electrified an old Oly 650 and the total investment was less then $50 and maybe 5 hours of my time and that included repainting the fuse and it came out pretty nicely and weighs less then it did when it was a pure glider.
Cheers,
Jim
LJH is online now Find More Posts by LJH
Old Jun 08, 2016, 11:47 AM
GliderJim is offline
Find More Posts by GliderJim
GliderJim's Avatar
Michigan, USA
Joined Jul 2006
It's sounds somewhat complicated, although solving problems is part of the hobby. I'm picturing a glider sitting upside down on the ground while you start the motor, then having to flip the whole thing over and launch it all without cutting yourself up. Gonna be tricky with the motor directly below the wing. Dragging the motor back through the grass/dirt doesn't sound appealing.
GliderJim is offline Find More Posts by GliderJim
Old Jun 08, 2016, 01:08 PM
ejett is online now
Find More Posts by ejett
TLAR Black Belt
ejett's Avatar
Athens, LA, United States
Joined Apr 2002
Jim, this sounds a lot like a government project.
I'm in agreement with the folks recommending that you convert your plane to electric power.
I do understand your feelings and thoughts on this, but I don't think it is particularly easy to manage the issues to do it.
Kudos to you though for thinking outside the box. Most of the best ideas are never in the box.
EJ
ejett is online now Find More Posts by ejett
Old Jun 08, 2016, 01:56 PM
ZAGNUT is offline
Find More Posts by ZAGNUT
supreme being of leisure
ZAGNUT's Avatar
Tel Aviv, Israel
Joined Jul 2004
OP said that he likes to use diesel engines...
could even be done without any servo release: pod hangs on a pair of tandem tow hooks, engine thrust keeps it there, when the fuel runs out drag and maybe a bit of up elevator makes it slide off.
pretty sure this has been done in the distant past.
ZAGNUT is offline Find More Posts by ZAGNUT
Old Jun 08, 2016, 02:54 PM
Steve 0 is online now
Find More Posts by Steve 0
Slope-a-Dope
Steve 0's Avatar
United States, UT, Draper
Joined Dec 2012
Other idea.....OP sells said diesel engines, invites Flying Buddy who happens to own TowPlane. Tows gliders up, release, fly!
Steve 0 is online now Find More Posts by Steve 0
Old Jun 08, 2016, 03:55 PM
Joined Dec 2011
Thanks, guys.
The engine would be on a parachute that is reeled in on a kite reel.
Engine not supposed to ever hit the ground.
Sounds too altitude limiting.., dragging the retrieve line and all.
Do have an electric motor and prop. These from deceased flying buddy.
Only have heavy NiCad packs from car/boat applications.
Would need latest LiPo battery packs, but do have modern smart charger to handle every battery chemistry.
ScratchBuildrSAM
Old Jun 08, 2016, 03:57 PM
John O'Sullivan is offline
Find More Posts by John O'Sullivan
John O'Sullivan's Avatar
Nova Scotia Canada
Joined Jan 2004
I flew R/C sailplanes with both diesel and glow motors on pods in the 70's and 80's and enjoyed them very much. However, today it's a whole new ball game and the simplicity of electric power, either on pods or "winch-in-the -nose" is an order of magnitude more efficient than messing with diesel or glow.
John O'Sullivan is offline Find More Posts by John O'Sullivan
Old Jun 08, 2016, 08:31 PM
Joined Dec 2011
Yes..., modern electric probably really is the only real choice to be made.
ScratchBuildrSAM
Old Jun 08, 2016, 09:20 PM
Alienmenacet54 is offline
Find More Posts by Alienmenacet54
Alienmenacet54's Avatar
United States, NE, La Vista
Joined Oct 2014
Don't forget cleaner. I fly electric sailplanes because I can't walk the distant for a high start either.
Alienmenacet54 is offline Find More Posts by Alienmenacet54
Old Jun 08, 2016, 09:42 PM
mlee8249 is offline
Find More Posts by mlee8249
Fly R/C writer
Redlands, Ca
Joined Dec 2004
Hi, Sam,
There are inherently several hazards you may have to contend with.
* with a bottom pylon engine mount, you may have to start it with the plane upside down. Whether you hand start it or electric starter ignition, you may find yourself pushing hard or flipping hard to do the start. Depending on the model and how well built it is, you could crush the plane just trying to start it. And diesels have more compression
* once the engine starts, you have to flip it over....very hazardous with a running engine
* the launch: depending on how you hold the plane, you could have problem depending on the design and size of the motor pylon. fuel tank position would also be a problem. The engine may do well inverted, as long as the fuel pickup stays where the fuel is. BTW how do you hold the plane now?
* what do you do when you reach altitude and the engine won't stop? And if you dare to pull it off while the thing is still running....might have some serious untangling time to do.
Electric is the way to go. Modern power systems are powerful, lightweight, very easy to maintain and service , reliable and perform well. It is no secret that many electric models are just as light as their engine powered cousins and mondo strong . Their quiet systems make them perfect for use in the suburb fields. One man, one plane, a transmitter and a few battery packs makes for a morning of quiet fun. And, there is no oily, slimy mess on the plane.
Question: you are flying along in pure glide....no engine running and you hook a thermal. It carries you out and then turns to sink. No problem, just throttle up the electric model. But I'm afraid it may be the walk of shame for the diesel powered model. Are you convinced, yet?
Mike Lee
Fly RC Magazine
mlee8249 is offline Find More Posts by mlee8249
Old Jun 08, 2016, 09:58 PM
Tucson, Az
Joined Feb 2007
You could go old school and mount diesel on front of glider. Original Oly 650 showed this omn plans. Craft ait had Buttercup etc. Set prop on compression stoke and be out of the way. Ni-cads/ Fuel engines kinda out dated with new bl motors etc. Motor/ esc is about $40.00. Small 3 cell li-pos are cheap and on add all the time.
I know some will do it their way and thats fine, but in the end bl motor will smoke and fuel motor[engine].
Old Jun 09, 2016, 09:15 AM
rdeis is offline
Find More Posts by rdeis
AMA 353531
rdeis's Avatar
United States, CO, Colorado Springs
Joined Aug 2003
Not hard to come by- hobbyking and rcfoam have suitable packs for under $20. Probably lots of other places, too.
Better or larger packs can be had for a bit more.
rdeis is offline Find More Posts by rdeis
Discussion JR9303 Sailplane Launch Switch Programming screamin' eagle Hand Launch 4 Jun 02, 2016 11:41 PM
Off Site Bob Owens 'Zephyr', 52" vintage RC hand-launch sailplane, Model Aviation 1981 sdrob15 Aircraft - Sailplanes (FS/W) 0 May 15, 2016 10:35 PM
Discussion Launch electric sailplane with stabilator xiaoyu80305 Electric Sailplanes 7 Apr 28, 2016 02:04 AM
Off Site DSC 'Ariel', 59" span hand-launch sailplane, rare new unbuilt kit! sdrob15 Aircraft - Sailplanes (FS/W) 0 Nov 07, 2015 07:37 PM
Sold DG808s 4-Meter Sailplane with Launch Engine & Pod too TomTerrific Aircraft - Sailplanes (FS/W) 1 Nov 03, 2015 04:36 PM
