Old May 26, 2015, 02:37 PM
gkyle840 is offline
Find More Posts by gkyle840
gkyle840's Avatar
United States, OH, Westerville
Joined Jan 2014
funjet ultra motor selection
I am looking for advice on selecting a motor for my funjet ultra. I am using ezuhf and 1.3 video on it. I would like to run it on 4s but if I can get more flight time out of a certain motor on 3s, that is ok. I want a motor that gives a little more flight time at the cost of speed. is there a motor that would get me 10 min+ out of this air frame with fpv gear if flying conservatively? I want to get some time under my belt with this airframe before putting my dr madthrust inrunner in it.
gkyle840 is offline Find More Posts by gkyle840
Old May 27, 2015, 10:02 AM
parajared is online now
Find More Posts by parajared
no guts no glory
parajared's Avatar
United States, AZ, Prescott
Joined Oct 2013
I think you should put your madthrust inrunner on it at the expense of having a heavier than useful motor weight and buy a lower voltage battery instead of a different motor. When you are ready to make the leap to 6s lipo go for it, but for now run 4s. Ten minutes sounds reasonable.
parajared is online now Find More Posts by parajared
Old May 27, 2015, 10:56 AM
gkyle840 is offline
gkyle840's Avatar
Joined Jan 2014
Its the big madthrust 3000kv. I'm not sure I am comfortable with that much weight and having to land at a fairly high speed. Do you think it will be alright for my first experience with a plane that will do over 80mph?
Old May 28, 2015, 11:36 AM
no guts no glory
parajared's Avatar
Joined Oct 2013
Oh 3000 kv. OK don't run 6s on that motor, lol!
A "small" but reasonable funjet motor will still weigh a good 100 grams or so and a big fast motor will weigh close to 200 grams.
Your fast setup will want to gobble a good 80 amps or so on you (and require a heavy esc) and according to my math at the absolute very least you would need in amp hours is a 2.7ah 30c battery or 2ah 40c battery.
I predict a "slow" setup will want to eat something like 35amps or so. So you can get away with as small as 1.17 ah (if such a thing exists) @ 30c which will be fairly light.
I predict you can save a good 140grams or so by using a smaller esc and motor but you can very easily shave off more than 140grams in battery weight with a lower cell count lower amperage setup maybe as much as 250 grams or so.
You still won't gain a whole lot in endurance but this will work nicely to train you up for your fast setup.
Old May 28, 2015, 04:31 PM
gkyle840 is offline
gkyle840's Avatar
Joined Jan 2014
What size and kV would be a good slow motor? Out runner I'm guessing?
Old May 28, 2015, 04:32 PM
gkyle840 is offline
gkyle840's Avatar
Joined Jan 2014
And thanks for all of the stats, that is very helpful! The batteries I have to work with right now are 3s- 2200, 3600, 4200 And 4s-1800, 3600, 4000
The escs I have are a 60 amp and an 80 amp
Old May 28, 2015, 06:50 PM
no guts no glory
parajared's Avatar
Joined Oct 2013
If you are really going to push for light weight I bet something as small as the 50 gram D2826-6 and your 3s 2200 could push a Funjet around, but you will have more fun with a larger motor.
Old May 28, 2015, 09:59 PM
gkyle840 is offline
gkyle840's Avatar
Joined Jan 2014
Something that will push it between 75 and 100mph would be fine.
Sold Multiplex Funjet Ultra + 3000kv NTM Propdrive Motor and Metal Gear Servos manogamez Aircraft - Electric - Airplanes (FS/W) 1 May 04, 2015 04:08 PM
Discussion funjet ultra motor setup hobaoe Pusher Prop Jet Models 1 Jan 10, 2015 07:24 PM
For Sale Aluminum Motor Mount for Multiplex FunJet and FunJet Ultra sotog Aircraft - Electric - Power Systems (FS/W) 0 Feb 20, 2011 12:39 PM
For Sale Aluminum Motor Mount for Multiplex FunJet and FunJet Ultra sotog Aircraft - Electric - Power Systems (FS/W) 0 Feb 17, 2011 10:00 PM
For Sale Aluminum Motor Mount for Multiplex FunJet and FunJet Ultra sotog Aircraft - Electric - Power Systems (FS/W) 4 Feb 12, 2011 07:02 PM
